Question about U-Line BI-95
Water leaking from fittings behind the grille. Is it possible to overtighten with a wrench? I;ve tried tightening and it still leaks.
  • 999 Answers
Yes over tightening will make leaks worse. Finger tight and then a half to a turn more is usually enough if things are aligned properly to start with....Eric
Posted on Jun 17, 2009
Why does water filter leak when tightly connected but not when loose?
It makes sense if there is a crack in the filter housing that is made more severe by tightening the fitting. Also, a fitting could be stripped from overtightening.
Aug 11, 2015 | Whirlpool Refrigerators
Waterheater mixing valve leaking
Turn off the main water valve. Undo any fittings that are leaking. Using gas line compound or teflon tape on the threads put it back together and tighten with 2 plumbers wrenches or two crescent wrenches.
Nov 07, 2013 | Washing Machines
How to change transmission lines
Get replacement line at parts store. Unscrew one end from radiator and other end from transmission. Use in-line wrench to tighten replacement line and be careful not to overtighten and strip the fitting. Run motor for a few minutes, when warm check the fluid level. 'DO NOT' overfill.
Jun 25, 2013 | 1999 Jeep Wrangler
I have water leaking from the top of the water heater (where the pipe connections are, from the holes) its small leaks, and if i press on it from the top i can see the water coming out from the holes
remove the nipples( pipe connections in water heater) and replace. be sure to use a good teflon tape and tighten with pipe wrench. they don't need to be torqued to 900 lbs, just tighten until it feels tight to you.
if it still leaks after testing, tighten a little more, don't overtighten!
Jul 28, 2010 | Water Heaters
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
I recently installed 2 Kohler bathroom sinks 16x19". One of them keeping leaking at the bottom of the sink where the 1 and 1/4" pipe connects. I did not put plumbers putty in as instructed. It leaked, so I...
remove the waste fitting and clean off all the putty. Using a clear or white silicon put some under the waste fitting collar then insert it into the basin hole. Next put the washer and nut on and wind it up to about 1/2" from the basin. Using the silicon again put plenty on between the washer and basin ensuring complete coverage of the waste circumference. Hand tighten the nut until silicon pushes out from the sides of the joint. Finally tighten about 1/2 turn using water pump pliers.
Wipe off all excess silicon.
You can tighten a little more if the waste fitting is all metal but i'm guessing its plastic and it is possibly being overtightened.
Feb 22, 2010 | Kohler FANDANGO SELF-RIMMING LAVAVATORY...
Whirlpool dishwasher Leaking water
Hello there:
Troubleshooting Leaks
If the dishwasher leaks, and you know the problem is not related to tub overfilling, the pump, or inlet valve problems, the plumbing connections may be faulty. Most dishwashers are connected to the water supply with metal pipe fittings, and the leak could be at these fittings. If the fittings are threaded, tighten them with an adjustable wrench. If this doesn't work, chances are the threads are stripped or the fitting is cracked or otherwise damaged. In this case, replace the fitting.
Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
I HOPE THAT YOU FIND THIS INFORMATION VERY HELPFUL
BEST REGARDS MICHAEL
Nov 13, 2009 | Dishwashers
I have a leak in one of my transmission lines I am trying to purchase a replacement how do I know which is the pressure line
You don't need to buy a replacement line from the dealer. These are easily repairable for a fraction of the price.Steel brake line is the sameas transmission line and can be bought by the foot at an autoparts store. You need to measure the diameter of the current lines to get the right size. You also need a small tubing cutter and 2 brass unions to complete the task. A splice in a trans line doesn't need to be flared, it will work just fine with a compression fitting.
Cut out the leaking piece of line with the tubing cutter making sure you have a bucket to catch the leaks. Cut the new line to the same length. Slide the nut onto the old line and then the ferrule. Place the union tight to the line and slide the ferrule and nut up to it and hand tighten. Do this with the other end of the union and the new pipe and also the other end of the line. Once you have it in place tighten all the nuts snug with a pair of open end wrenchs. Don't overtighten. Overtightening can squash the line so that the trans fluid doesn't flow properly. Start the car and watch for leaks. Tighten the offending nuts just enough to stop the leaking and you are done. Hope this helps.
Nov 05, 2009 | 1999 Ford Taurus
Leaking Duet Washer
hi there,
looks like you may have a pinched hose or the fitting is overtightened or not tightened enough. turn off the water supply and check the water inlet hose. you can usually tell if the fittings are stripped or not tight enough.
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks from tube at the bottom of fridge for water dispenser only
If it is a plastic compression fitting you can tighten each one a little(careful not to tighten them too much cause they can strip out) Use a small crescent wrench with a back up wrench.
Jan 27, 2008 | Refrigerators
U-Line BI-95 Logo
Top U-Line Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
