Question about Neff U1721 Double circotherm Electric Oven
We are just about to have the heating element replaced in our Neff U1721 oven for the 5th time in 2.5 years!. Any answers
  • 13 Answers
Have come across this problem before and it can be cured by replacing the fan motor. As the motor gets older it spins with less power and allows the element to get to hot and burn out. Replace your fan motor problem solved.
Posted on Jul 29, 2009
Hi - have a Neff U1721 double oven, the element in main oven went bang cracked the element and blow a hole in fan cover. replaced the element but now temp light comes on but doesn't heat up, can you...
Test element check for continuity across the terminals and it is getting power when switch onon. If both ok, chances are the front selector switch has blown.
Feb 01, 2011 | Neff U1721 Double circotherm Electric Oven
Tip
Common Heating faults Neff U1721 Electric Oven
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1721 Double circotherm Electric Oven
My Neff U1721 oven does not heat up, Element
YOU CAN BYPASS IT HOWEVER BEAR IN MY THIS IS A SAFTEY DEVICE AN MAY HAVE FAILED BECAUSE OVEN OVERHEATED,( FIRE RISK PRESENT) IF THIS IS THE CASE, A BYPASS SHOULD BE CONSIDERD VERY TEMPORARY.
Jun 10, 2010 | Neff U1721 Double circotherm Electric Oven
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
3rd blown element
no connection between lights on fan. problem is that bulbs these days are poor quality (but cheap)
it is common for these circular elements to go. usually last about 2 years. worth checking tho that fan is turning at right speed
Jun 21, 2008 | Neff U1721 Double circotherm Electric Oven
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double circotherm Electric Oven Logo
256 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
