Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
Honda 400 petrol runs straight through the carb
Into the air filter
  • 3 Answers
Check the carb, in particular the float. make sure there is no restrictions, and make sure there is no hole in it. (Shake it and listen)
Posted on Jul 16, 2009
  • andyandwen Jul 16, 2009
    The float will pivot freely and on the underside there is a small wire that connects the needle valve. When gas fills the bowl, the float rises and pushes the needle valve to seal odd the flow of fuel to the carb.
    If the float's movement is restricted, or the needle is no longer attached OR the float has a hole in it (and is full of gas therefore rendering it useless) gas will flow through the carb into the intake.
    Hope this helps.
    Andy.
    hope this helpe.
    Sergeant:
    Champion:
  • 253 Answers
Go to mechanic and get your petrol pipie changed and for more cntact http://tinyurl.com/m7ghqz
Posted on Jun 18, 2009
My Honda CR-V starts up runs for around 30-40sec then dies. It will start up again straight away but the 30-40sec dies again. What is causing this problem. There are no fault codes
Go back to the basics. Check air supply, fuel supply and spark. Clean or replace the air filter. Check there is fuel getting to the cylinders. Check each spark plug is firing with a clean blue spark. Such a short running time would suggest it's possibly a fuel starvation issue.
Feb 07, 2018 | Honda Motorcycles
I ran out of gas on my Kawasaki ZX9 and it runs not very well now! How do I clean the carbs out?
re-categorized, and tidied up your English. :-)
There are videos. Tank off, air filter box off, disconnect linkages and fuel pipes, remove carbs, clean the bottom float chambers and then the jets. Reassemble and balance the carbs. Not done this for a few years but fairly straight forward.
cleaning kawasaki zx9 carbs Bing Videos
Sep 03, 2015 | kawasaki ZX-9 R Ninja Motorcycles
Why does my yamaha generator ef3000ise petrol run out of the air filter when it is stopped but it will run fine otherwise
Carb float is stuck open. Take the carburator apart and clean it, blow it out with compressed air. put it back together see if that works
Sep 29, 2012 | Yamaha EF3000iSE Inverter Generator
My honda cr 250 idle's high when takin over. and before it runs out of petrol it rev's up on it's own.
The air/fuel mixture is Lean as opposed to rich. Adjust the air/fuel mixture screw clockwise in quarter turns until the idle normalizes. This screw can be found inbetween the carb and air filter. It should be a brass screw with a flat head (not cross or philips).
When you're almost out of fuel cab will go lean and therefore idle up.
Mar 01, 2011 | 2002 Honda CR 250 R
02 Big Bear 400- Hi-idle & backfires while running. Tried cleaning carb & air filter, drained bowl & cleaned with carb cleaner. Could there be aproblem with the choke.
Sounds like the carb could use a cleaning and setting by a professional...install a new plug and a new air filter.. AFTER the professional carb cleaning and setting.,,do this and repost
Oct 16, 2010 | Yamaha 2004 Big Bear 400 4x4
I can't get the compressor to run. As a test poured some gas in the carb. It ran 'til gas gone. Changed plug and inline gas filter still no go any ideas?
float stuck in the bottom of carb turn off petrol unscrew 10mmbolt on bowel remove it and clean out turn on petrol and c if it runs out wit bowel offif dosent take out float and blow out that should sort it
Jul 23, 2010 | Honda Powermate Contractor Pontoon Air...
My honda 400 bros is not runing right 1 plug is wet the rest is sutted up as if runing rich what would think it is
Sooted plugs proves tht the air-mixture is too rich.(too much fuel going to the combustion chamber)
You have to set the air-mixture screw on the carb/s.
Clean the carb/s, replace 'inline' filter , if you don't have one ..install one, reset float level.
It's better to also check the valve clearance too.
Fit in new plugs (gapping them to specs.) and run the engine to its normal temperature thn set the air-mixture screw...standard setting....all the way in i.e. tighten it slowly to the end making sure not to damage the tip of the screw, thn 2 and half turns outwards to 3.
Start the engine....run to normal temperature and thn reset the air-mixture screw +/- either way.
Hope this helps!
Oct 24, 2009 | 1991 Honda NT 400
2006 Honda Shadow Aero starts but won't idle.
check fuel level, u may need to check the flow of petrol to it,,Also if that does not solve you may need to service the carb and check fuel filter,air filter etc...
Aug 31, 2009 | 1999 Honda VT 1100 C3 Shadow Aero
Honda vfr 400 does not idle
gummed up carbs, faulty fuel pump, blocked fuel filter.
all of these will give you that response, fuel starvation.
you are not getting the right amount of gas thru, unles you have the choke on which cuts out some of the air making your mixture a little richer.
if it sat over winter in storage, the carbs probably could do with cleaning. you can try removing the air filter and spraying a bunch in, let it sit over night and see what happens. a good fuel system cleaner (additive) may help. if you can get Berrymans B12 ( dont know what country you in) it may be just american. but if you get some double the dose throw it in the gas tank, run bike til hot and then put it away for the night. then next day hopfully should be better. also if you have an inline fuel filter you could try changing that. does it have an electronic fuel pump.? does it run constantly? http://www.carlsalter.com/motorcycle-manuals.asp
that link will get you a free pdf service manual
Apr 05, 2009 | 1995 Honda VFR 400 R NC30
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
278 people viewed this question
Top Quad Cycling Experts
Marvin
Marvin
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
