SOURCE: Start my fridge on gas
have you ever used it on gas normally theese frige have a glow coil to ignited the pilot is it a fridge in a trailer or in a house also the themocople may me defective not generating electricity i woul need more info thanks from gilles
SOURCE: dometic rm2652 frige just stopped working, gas nor
Check 12V supply and fuses on lower board. If display functions okay, then look for yellow residue on back of refrigerator near burner. If yes, then cooling unit has leaked and needs to be replaced. See if recall kit has been installed, and check for 12V at both sides of limit switch. If no power on either side, then thermal link has blown, and need to be replaced, If 12V on one side, but not the other, than limit is tripped, and needs to be reset, by pushing button, or if not resetting, then replace, Check for obstructions to the bottom and top vent to make sure they are not blocked, On models with top side vent, check cooling fan for proper operation.
SOURCE: Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
SOURCE: my dometic fridge will not turn on
Check to see if you have a switch for storage, on, off etc. usually between doors, or near top right corner of fridge compartment. It may be in wrong position.
SOURCE: Have dometic fridge RM2553. Has
Hi.
The safety mechanism will still be working. The only case it won't be working is when the safety mechanism itself is causing the problem. In that case there will be no risk because flame will be forced to turn off.
The indicator on red is telling you that the fridge is not cooling. It does not affect the safety of your Dometic.
The safety mechanism in your Dometic works using a thermocouple and a safety valve. When either of this will fail the gas flame will turn off, and the fridge will stop cooling. The safety mechanism works even when it is broken, as it does not allow gas valve opening.
About poor cooling, there are a number of reason that may result in insufficient cooling with this kind of fridge.
Check if there is flame, if there is no flame, then testing will start from igniter, coil, flame sensor and safety valve.
Ensure that there is enough ventilation.Thermostat and cooling unit must be tested if flame operations are OK.
On LP gas, check filter. Check pressure regulator and gas from the lines.
I have included a link to the service manual. Please click below to open the file in PDF format:
Service manual.
Regards.
Ginko.
