The waste bin full message appeared. I am still on the started toners for this printer. I've cleaned all the ports and nooks in the printer. Also tried to reset the NVM but am not sure if I did that right. I did notice that in daig mode > print info> an engine 2 error message appears. Don't know what to do fix my printer
SOURCE: Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
SOURCE: Phaser Imaging Unit install error
Worked like a charm! Thank you for the detailed information. The step by step instructions were right on target.
SOURCE: Xerox Phaser 8400N Printing Stripes
When you go into the eliminate light stripes there is also a mode called Jet Substitution. You can sometimes bypass the bad jets.
If that does not work then the print head will most likely need to be replaced.
You can replace the printer for less than the cost of a print head normally..
SOURCE: how do I replace the
On the left side of the machine, where the pages come out, Behind the catch tray or finisher there is a small door that pulls open, it flips downward. Tilt it open, slide out the filled bottle and put in the empty on, One waste bottle comes with a box of toner.
SOURCE: xerox phaser 6250 is not printing black
I did a combination of the things listed in the below link.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=180,E=0000000000023462887,K=8165,Sxi=16,Case=obj(19377)
