Question about Acer X193W LCD Monitor
This morning my monitor looked all blue, I could see the desktop picture but it seemed not to be displaying red. I have speakers that have always been in the same spot, approx a foot away. I thought maybe they might be interfering but when I moved them there was a blink on the screen but no real change in the display. This monitor is less than a year old. what is wrong?
  • 73 Answers
Press alt+ctrl+del key alltogether....you will get the task manager..on the top of task manager you will find the file option..click...on the dropdown menu select New Task...Type explorer.exe in new task and click ok...you will get back your desktop icons
Posted on Jun 17, 2009
Monitor looks like right half blue shade
Either your monitor or the video card inside the computer is going bad. To isolate the problem connect another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok that means your video card is ok, but your original monitor is bad. If the Borrowed monitor displays the same blue shade then your video card inside the computer is bad.
Jun 05, 2012 | Lenovo Computers & Internet
I'm running dual Princton Monitors.This morning in booting up my computer one screen stayed completely blank with the message"For best picture quality change resolution to 1280x1024. This monitor...
possible that the video card has packed it in and is not responding for duel monitors
you could always try going to control panel , display section and check the settings of both monitors and the drivers for both monitors
to check the problem monitor change the setting from main display from the good unit to make the other monitor the main display
it should change over and the first monitor will then go bad
Apr 23, 2017 | Princeton Digital VL1514 Monitor
My monitor stays white it wont show any display
black-icon.gif This icon indicates the BRIGHTNESS control, more properly called BLACK LEVEL. It adds or subtracts an offset, or bias, into the red, green, and blue signals. This control should be adjusted so that black picture content displays as true black on your monitor. Misadjustment of this control is the most common problem of poor quality picture reproduction on computer monitors, video monitors, and television sets. Later in this document, I will explain how to set this control properly. The setting is somewhat dependent upon ambient light. Modern display equipment is sufficiently stable that frequent adjustment is unnecessary.
picture-icon.gif This icon indicates the CONTRAST control, preferably called PICTURE. It applies a scale factor (gain) to the red, green, and blue signals. It affects the luminance (proportional to intensity) that is reproduced for a full white input signal. Once BRIGHTNESS is set correctly, CONTRAST should be set for comfortable viewing brightness.
The gamma can be controlled through Video Card utility which can usually be accessed by going to display properties.
Depending on your video card software you may be able to right click your desktop, select properties, select settings tab and then choose advanced, towards the bottom. In there you may find a tab called Monitor and under that tab you may or may not (depending on your video card software) be able to adjust your color correction settings(gamma & brightness & contrast).
. Right click on the desktop and then select Properties
2. Click on the Settings tab and then click on the Advanced button.
3. Click on the Color Correction tab and you will see settings for Brightness, Contrast, and Gamma
Jan 29, 2010 | Computers & Internet
Dell Vostro 1710 display problem
Hello My Dell Vostro Laptop Display Not Working Correctly it showing Dim but in other desktop when i connect to the Laptop Of Mine it showing Correctly With No Dim Problems? How can I fix the Problem?
Nov 19, 2008 | Dell Vostro 1500 Notebook
Color on monitor is pink
I hope u have a CRT monitor. If not just post ur type.
For CRT, the reason for the monitor displaying in pink is that PICTURE TUBE MAY HAVE BEEN DAMAGED.
Inside the monitor there will be RGB (Red Green Blue) picture tube . If any one of them gets affected it will display in some oddcolors like in your case. So, that may be your problem.
Hope my info is useful. Bye . Take care
Sep 17, 2008 | Computers & Internet
Faulty LCD Monitor ?
off hand it sounds like a power supply issue. sometimes fixable sometimes not.
Robert
Aug 26, 2008 | Scanport Computers & Internet
Video display driver
It's not your driver. It's the video cable from the computer to the monitor.
Move it around at both ends and your colour will return to normal.
Either replace the cable or find where it is happy and then hold it in that position with something.
It's a common fault to all monitor cables..and nearly always the red wire.
Apr 30, 2008 | IBM NetVista PC Desktop
Verticle blue lines, left side
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new one.
Mar 07, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
My TEAC PL-D2100 home theatre system, is not showing all natural colors in display since yesterday.
the red rca jack of the component output on your dvd player or the red input on the Avr component input is not plugged in properly ( loose ) or the the component monitor out to the tv may be loose. there is also possablity of cable cut. check it with another component cable or interchange the red to green to find if the problem perssts ,... to ascertian weather it is the cable.. this info should solve your prob.
Jun 30, 2007 | Teac PLD-2200 System
Acer X193W LCD Monitor Logo
78 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
