Question about Whirlpool Washing Machines
No spin cycle
My washer will not go into the spin cylcle. I noticed the switch has fallen. I need to get in to get to the switch and i'm not sure how. I don't know the model # of my machine. It is full of water & I can't move it. Can you explain to me how to get to the switch?
Its a top load, switch in on the right as you are facing the washer. It's an extra large capacity. We bought it new between '99 & '00.
  • 999 Answers
Whirlpool? The model number should be under the lid or on the back of the console. If you have a floor drain you can drop the drain hose and water (not all) will run out. The cabinet is removed to repair this. The console will have 2 screws either in the back corners or the front corners that go down into the top. The console will flip back giving access to the switch harness and the cabinet clips.Unplug the harness remove the 2 clips and tip the cabinet towards you. Switch is underneath. If you remove the plug end off the old switch and tie the black and gray wires together (Green should be the one connected to the cabinet) it can be used as a temporary jumper to get the water to drain while you get another switch.
Eric
Posted on Jun 17, 2009
Xqb90-701clps
Some where at the bottom there is springs that can be broken or out of position, or the jockey pulley might need replacment
May 10, 2017 | Washing Machines
NTW5400TQ
I just had that problem. The repairman pulled the front off the machine and found a small nail that had fallen through the holes in the washer tub. I didn't watch him do this, so I don't know where inside the machine it was, but he found it right away. Hope this helps.
Oct 14, 2012 | Amana NTW5400TQ Top Load Washer
Washer fills and goes to agitation cylcle, but weak to no agitation. Upon final spin cycle, began making a loud rapid ratcheting sound and did not spin at all. Machine did drain. I did not observe the...
The direct drive coupling between the motor and transmission has stripped out.
It must be replaced.
This video will help in the repair.
http://www.youtube.com/watch?v=WLPGs2UMUJc&feature=player_embedded
Feb 03, 2011 | KitchenAid KAWS750L Top Load Washer
My washer will work on everything except the spin cylcle...it will not drain the water out. Please help....don't know what to do
Replace the defective lid switch,it is under the control console. their are screws in the back of each end cap securing the control panel to the top. Also make sure the screws holding the left side hinge to the lid are tight because they also move the arm that activates the lid switch. very easy repair Good Luck
Sep 28, 2010 | Roper RAX4233PQ Top Load Washer
Washer fills up agitates then when it should drain ,nothing.motor dosent come on to pump water out.
In most cases all brands will fill and agitate with the lid open, but will not drain or spin with the lid up.
It sounds to me like your lid switch is either bad or misaligned.
The first thing to check is the actuator plunger on the lid. Make sure it hasn't fallen or been broken off. Look for a piece hanging down from the lid that looks like a little finger that when the lid is closed, would hit and depress the lid switch ,which is under the top of the washer.
If it looks like the actuator is good shape then the lid switch is either bad or misaligned. Take a pencil or a bic pen and depress the lid switch. Making sure your washer is plugged in and in the spin mode. If it begins to rotate to spin and drain then see if a screw has fallen out that holds it in place or became loose not letting the actuator hit it correctly.
If the switch does not seem loose and it will not start the machine when depressed with a pencil it is probably time to change it out.
Apr 09, 2010 | Kenmore 24032\24036 Top Load Washer
How do I fix my Kenmore washer spin cylcle? It
if your machine is a top load , less than 15 yrs. You most likely need a new lid switch. The machine will not drain or spin if the top lid is open.
Dec 12, 2009 | Washing Machines
Machine won't spin
you need to check your lid switch. open the lid then listen for a clicking noise when you lower it closed. the lid swtich is a safety device.( if no click no spin)
Oct 29, 2009 | Kenmore 22422 Top Load Washer
Washer is not washing the clothes properly. Skipping cylcles
If it's new - check if it's under warranty. Let them solve it. Save you money. You've already paid for it once.
Mar 21, 2009 | Whirlpool Washing Machines
Kenmore 700 series top load washer problem
Take the washer back. We just bought the same one and have the same problem
Feb 18, 2008 | Washing Machines
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
32 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
