Question about 2wire 2700HG-B Router (2700HGB)
L have aproblem to find my ip when l l put cmd and then config it show me the ip after that when l try to write the ip it dose not show up that for the router 2wire 2701 hg-b belong to at@t l try to figre out the port for utorrent to speed up my adsl please if you find out a Solution
  • ali_alrahem Jun 17, 2009
    l thouhgt that free to solve
    Problem Solver:
  • 11 Answers
You can find your ip address here
My IP Address | Tejji
Posted on Jan 17, 2010
    Sergeant:
    Novelist:
  • 198 Answers
Go to mywanip.com to know your WAN IP address. sine you are behind a router, you most likely have a private/LAN address issued by your router.
Posted on Jun 23, 2009
I have been having issues with my internet connectivity for a while - its been fix after fix and i feel like im slowly fixing the problem but adding more onto it. The exact problem from the top - Spee
Problem is that ipv4 config.
For any computer on a home network an automatic IP-address is handy. So the ipv4 config should be set to DHCP.
But then there should be a router that hands out IP-addresses and the IP adress of this router should be given in the ipv4 config as Standard gateway.
That is for home, but to resolve internet adresses your computer needs DNS, you can use common dns servers, or the ones given by your internet provider.
Fill these in under DNS in the config.
Aug 23, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How to change a ip through command prompt
Netsh” is a nifty utility to change system networking settings, locally or remotely.
To run Netsh click on start then RUN and type CMD press ENTER.
When the command prompt comes up type Netsh, now you should be ready to execute commands. Simple huh. Just to warm up type “interface ip show config“ that will show up the TCP/IP network settings.
Now, how you change the IP address and Default Gateway settings? To change the Local Area Connection TCP/IP settings type the following command:
interface ip set address name=”Local Area Connection” static 192.168.10.42 255.255.255.0 192.168.1.1
on Dec 20, 2009 | Computers & Internet
Cant get printer to send scanned documents to replacement laptop
you have to go into the address book and switch the ip to the ip of the current computer (open the run program type cmd the in cmd type ip config look for ipv4 settings the number you get is the ip you need in the address book of the machine
May 09, 2014 | Kyocera Office Equipment & Supplies
I want to factory reset my nortel AP 7220, how do I reset? What would be default IP after reset?
There is probably a reset button somewhere on the device, it is probably a small pinhole that you put a paper-clip into the reset.
If it has its own http web page, there is likely a reset to factory defualts option.
The ip of the computer connecting to it should not change.
On a computer connected to it, open cmd start>run then type in cmd, and type 'ipconfig'.
It will display details about your connection. Where it says 'default gateway' is the ip of the device.
You could try to put the ip in your browser and see if the device has a web page.
May 02, 2011 | Nortel Networks 7220 (NTE350BG) 802.11...
I want to change my security code from no code to a secure code. I have put http://192.168.0.1 into my browser and get an error page. i have gone into cmd and the config to see if this is the correct IP...
HI,
In the cmd prompt type ping 192.168.0.1 and hit enter and see whether you are getting 4 replies
and then try to open the router setup page.
Regards,
Prema
Nov 13, 2010 | Computers & Internet
I cant set up my linksys wireless-G ADSL, my laptop recognizes linksys but i still cant connect to the internet, when i clicked on troubleshoot to correct the problem, it says DNS isnt recognized
    Go to a cmd prompt. To go there, simply type cmd in the search. You can access it by going to your C hard drive, find Windows folder, in the folder locate System 32 - look for cmd.
When you are in cmd:
    Type IP config and see if you have an @ssigned IP in the range setup in the router. If not try C:\ipconfig\release then C:\ipconfig\renew Likely that this won't work.
    The steps I took were:
    1.) Go to Start/Control Panel/Network Connections. Right click on the wireless connection. Go to TCP/IP in the components section and click the properties button. Make sure Obtain IP and DNS address are both set to automatically.
    2.) I had WEP enabled, make sure your wireless card and the router are both set to the same encryption 64 or 128 and make sure they are both on the same channel.
    3.) Try C:\ipconfig\release then C:\ipconfig\renew again and hopefully you'll get an IP address.
Nov 10, 2010 | Cisco Computers & Internet
Tried 192.168.1.1 to get in also tried 192.168.1.254 cant gain access to the router to adjust some configs
You do need to find the IP....
Using a Windows Computer.... Get to a C: Prompt...
"Start", "Run" ...in white space.... enter "cmd"
At the C: prompt..... Type "arp -a" and hit the enter key.
Above command will show all IP's on your network.
Nov 05, 2010 | Netopia (3347NWG-VGX) Wireless Router...
What's an IP address?
internet provider address. ring your provider and they will sort it
May 24, 2009 | Acer Aspire One PC Notebook
Unable to access the internet
try doing a ip config on that system
1. go to start menu
2. go to the run option
3. type in cmd
4. a box will appear then type in ipconfig
5 this will display your host ip numbers if it shows 125.0.0.0 then its not established on the router
Jan 03, 2009 | Linksys Wireless-G Broadband Router
Port Forwarding - can't access router management
normaly you can gain entry to the router
via an ip adress you would put into internet explorer
you can get the ip adress from the manual you got with the router
failing having the book then a google serach will tip up the info you need
Nov 10, 2007 | D-Link AirPlus DI-524 Wireless Router
2wire 2700HG-B Router (2700HGB) Logo
173 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
