Question about Mitsubishi WS-55613 55" Rear Projection HDTV
Tv not responding to remote and now will not turn back on!
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
  • 1 more comment
  • mits_ws55613 Nov 01, 2007
    Exact repair info would be greatly appreciated. How sure would you say you are on a scale from 1-10, 10 being 100% sure? Just curious and I just wanted to stress that my picture has no and has not had any issues, just what I stated about the volume and the tv not coming on at all now. Thanks!!!
  • Anonymous Nov 29, 2007
    TV will not turn on with the remote or without. The cable is on.
  • Anonymous Mar 26, 2014
    Top of the remote control shows "audio" when the power button is pushed. Usually it shows "TV "
  • 27 Answers
If the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at rjp5765@msn.com if this helps
Posted on Dec 06, 2007
  • 3 Answers
Front panel buttons (switches) are the usual suspect. Disconnect the wires going to the front panel, plug Tv in, wait a minute, use remote to turn on. This has solved many equivalent problems.
Here is how to do so for similar model WS-65611:
1. Remove the Speaker Grilles and Unit Front by pulling forward.
2. Remove 2 screws (a) to remove the Control Panel.
3. Remove the Board Front by removing 4 screws (b).
4. Remove the 4 screws (c) holding the Screen Assembly.
5. Lift the Screen Assembly up and away from the cabinet.
Posted on Jan 11, 2011
    Genius:
  • 1,694 Answers
Bad DM module = expensive repair
Mits rebuilt = 1-800-553-7278
PS. Exact repair info available if you want it.......T.
Posted on Nov 01, 2007
  • Vista Electronics Nov 02, 2007
    Download a copy of "Blink of death" from ------------
    Chris@ChrisAndNat.com
    Note: Use 1000mf / 25v capacitors to avoid fit problem
    Note # 2 --------changing four caps might be prevent
    maintenance only, don't know
    until you try.....T.
    PS. You might try clean / lube volume up tactil switch first-----
    located behind vol up button on front of tv.....T.
Dell TV not responding to remote
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Jul 20, 2017 | Dell W4201C 42 in. Plasma HDTV
Bush lcd42f1080p100hz remote will not turn tv on
Nov 02, 2012 | Televison & Video
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
Goog day. I have a Samsung LE40A559 LCD TV and about a week ago it stopped responding to the remote. Remote itself is working as when the TV is off and I push buttons on the remote the blue light on TV...
The flashing blue light shows that the TV is receiving I.R. from the remote but doesn't mean that the signal being received is recognized by the Samsung. If you have a "universal" remote then your TV code may need to be re-entered/reprogrammed...changing batteries in a "universal" will usually require it to be reprogrammed.
Also...because of the remotes construction (rubber membranes with carbon dots that short across PC traces) I've seen certain buttons stop working altogether.
Nov 05, 2010 | Samsung TV Remote Control
My remote Stopped working with my TV but still works with DVD player. I have a new universal remote and it will not work as well, what part Do I need to replace?
You may want to try a “Hard Rest” by unplugging the power from the TV.
While the TV is without power, one at a time, push on each of the buttons on the TV & listen to hear them click (there may be a button stuck down).
After at least a few minutes have passed, plug the TV back in. Sometimes the TV may power on by itself and other times it will may not. If the TV did not power on by itself, push the button on the TV to power on the unit.
After the unit has power on wait about 30 seconds. Now point a known working remote at the TV and see if it is working correctly. You could test your LG remote on another LG TV at home, a neighbor’s house, and or at a store.
If the TV does respond by using the buttons on the TV but not with remote control, the problem could be with the following.
Remote Eye board and or the Main board.
I hope my information has helped you.
Good Luck.
May 28, 2010 | LG 42LC2D 42 in. LCD HDTV
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
The TV will not turn on.
I have the same problem, push button to turn on tv but it only does a click like it is going to turn on and then another click bit it wont turn on. Finally a red light is just blinking.
Any suggestions, is there a freeze button or code that I need to push.
Jul 03, 2009 | RCA HD52W140 52" Rear Projection...
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
Westinghouse TV - Issues
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/..
Mar 10, 2017 | Westinghouse LTV-19W3 19 in. LCD...
TV remote will not work properly
I have a Mitsubishi WD-52725 TV, too, and have experienced the same problems with it. My solution to the remote not responding is to push the reset button on the front of the TV (to the left of the Power button) with a paper clip and wait for the green light to stop blinking (about 1 minute). Then, turn it back on and try the remote again. Recently, my remote stopped responding when pushing certain buttons on it. I removed the batteries, and all of the little screws including the one inside the battery compartment and gently cleaned the contacts inside the remote and the circuit board with a cotton swab dipped in alcohol. After putting it back together, it works fine now.
Feb 28, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
1,026 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
