Question about Panasonic KX-MB781 All-In-One Laser Printer
Can't scan in WIN2000 Server OS.
1. Print & Fax can be work properly.
2. Only Scan Facility response nothing.
What are the factors affected pls guide...
  • 73 Answers
Try reinstalling the printer software and driver.
Posted on Jun 17, 2009
I was sent avistation packet(document) from a correctional facility that need to be printed filled out & returned how do I do that
Step 1
Print Document
Step 2
Fill in Document
Step 3
Fax the Document and/or scan and e-mail the document after completing step 1 - 2
Step 4
If Step 1 - 2 is completed , and step 3 is a failure try step 5
Step 5
Take filled document to correctional facility manually
Aug 24, 2014 | Office Equipment & Supplies
US-4A Keyspan USB Server
if urs is a 3 in one u wil have scan and copy functions also included in this sir.
is urs a 3 in one?
Jun 21, 2008 | Keyspan USB Server US-4A (d47710) Print...
Epson scan when the scan icon is clicked nothing happens
Simply re-install the drivers it is the problem of some dll files or in second case your printer driver is not compatible with win7 so run the application in compatible with lower OS my clicking the icon go to the properties and run in compatible mode choose winxp
Aug 05, 2012 | Epson Stylus Office Bx635fwd Inkjet Copy...
Fax and print buttons dont work konica minolta 7235
FAX is option do you have the FAX kit installed???, Scan is normally a kit also on that legacy Konica machine. if you have the IP address to the machine place it in your url box, if the machine is networked you should see the copier own web page
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 19, 2017 | Konica Minolta Office Equipment & Supplies
Scan wont work on mac psc 1410v
First are you trying to scan using the scan button on the all-in-one or from the computer? If you are trying to use the scan buttons, you need to install the HP full-feature software package: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=219&lc=en&cc=us&dlc=en&sw_lang=&product=458978#N193 . (If you need to expand the section marked drivers.) Uninstall the printer and disconnect the data cable before installing this full software.
If you installed the basic drivers that came with the Mac OS, you can scan using Apple Preview and Image Capture software. You can also acquire a scan from the Print & Fax > Printer browser. Open the software from the dock or from the Applications folder. In Apple Preview, choose File > Import from Scanner. In the Image Capture program select the all-in-one from the list of devices.
For the Print and Scan. Open System Preferences from the Apple Menu. Click Print & Fax and select the all-in-one. Click the Scan tab and Open Scanner. Then click Scan.
With the HP software you can launch a scan from the computer or from the scanner (but only if the monitoring program is running). You need to set up the HP Utility for the scan task manager.
This site has the full set of steps: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02456650&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=458978#N2158 .
Sometimes an all-in-one will work for printing but not for scanning due to a damaged cable. Scanning requires bi-directional communication with the printer. Try replacing the data cable. If you use a USB hub or print server, try a direct connection to the computer.
I hope this helps.
May 14, 2011 | HP PSC 1410 All-In-One InkJet Printer
I am trying to scann some documents to my computer but the Dell 926 All in One keeps telling me the scan failed, first it telss me it has to download applications then it tells me to use the defaults....
Try a new data cable and a direct connection (if you have a print server or USB hub connected). Scanners require bi-directional communication and can fail when the printer itself works.
Do you have the full software installed or a generic driver? What OS do you have? To see what software/drivers are available: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=PRN_ALL_A926&os=WLH&osl=en&catid=&impid= and choose your OS in the drop down menu. Did you launch the scan from the computer or from the all-in-one? Are you running the monitoring program on your computer (to launch a scan from the unit, this must be running to "listen" for the button press)? Did you set up the software for the destinations for those buttons? Launch scans from the computer first.
Uninstall any generic driver from the OS and unplug the data cable (USB). Then install the software or driver from Dell. Generic drivers often only run the printer.
The full software (and the monitoring program) are not available for Win7. You need to use Windows Fax and Scan (New Scan) or Paint (File > Import from Camera or Scanner) to acquire scans. XP and Vista can also use Paint. (Some versions of Vista also have Windows Fax and Scan as well as Photo Gallery that can acquire scans.)
I hope this helps.
Aug 10, 2010 | Dell 926 All-In-One InkJet Printer
HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Oct 20, 2008 | Office Equipment & Supplies
Hp laserjet 3050 scan problem
You should go to HP.com and look for a TWAIN scanner driver the works for that printer in Vista.
Jun 14, 2008 | HP LaserJet 3050 All-In-One Printer
Problem with Canon I-SENSYS MF 4150
After several days of researching the same problem for the MF4150, the conclusion is that you have to use an Axis or Silex brand print server developed specifically for Canon. Both have been reported to provide Print/Scan/Fax multi-functionality, but it seems Silex is the one Canon really supports (it's only sold on their website) and is most likely to be the least problematic.
Jan 05, 2007 | Edimax PS-1205UWg (PS1205UWG) Print Server
Panasonic KX-MB781 All-In-One Laser Printer Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
