Home | Sony | KP-51WS500 51 in. Rear Projection Television | Kp51ws500 color fli...
Sony KP-51WS500 51 in. Rear Projection Television
Problem for Sony KP-51WS500 51 in. Rear Projection Television
Kp51ws500 color flickering
By aschubart on Jun 17, 2009
This set started fading blue, coming back, fading coming back, then straightening up. Highly intermittant. When it does this I turn tv off then back on, and the picture is right again for a couple minutes, then starts to flicker again. Any Ideas?
Solution #1
posted on Jul 06, 2009
Not Rated)
danc417
Rank: Master
Rating: 88%, 7 votes
I'm afraid I don't have good news. This is known as the "Flicker Issue." As a Sony authorized servicer, the shop I worked for was directed to replace all three of the CRT's in the limited number of sets that experienced this issue. The cost per tube is typically around $200. If you decide to take this on, it is best to replace one CRT at a time, power up the set and do the yoke adjustments and electrical alignments to get the new color to line up with the existing ones.
Was this helpful?
Yes
No
Popular Solutions for Sony KP-51WS500 51 in. Rear
Questions and Unsolved Problems for Sony KP-51WS500 51 in. Rear
Do you recommend Sony KP-51WS500 51 in. Rear Projection Television?
Answer
Answer
Screen will begin turning blue, then go black and standby timer light blinks 8x in sequence. I can... (More)
Answer
my sony kp-51ws500 tv red and blue crt go out about ten sec. after i turn it on but the green stays... (More)
Answer
screen has green swirl lines about 2 inches apart all across screen which is only barely visible. ... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KP-51WS500 51 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
