Question about Minolta Office Equipment & Supplies
Minolta cs pro 2080 Has a code 0200 What to look for to fix. Thanks in advance for your help!
  • h20damg Jun 17, 2009
    Thanks thanos0550
    I used to be with Monroe Systems for Business some time back when they sold copiers. The technichans were always a great help and I know where the corona wires are at on those old systems. Can you tell me where to find the wires on this minolta. Are they close to the fuser section? It is the fuser section on this model that does not appear to be going down all the way.....
    Thanks again
Hi !
check for the corona wire if its not broken.....you have a charge problem.
Posted on Jun 17, 2009
  • Pat Jun 18, 2009
    the corona wire is under the image unit. And there is the scorotron grid on the top of the drum itself.
    Take a quick look at the corona wire first to see if its broken. Then take a look at the scorotron on top of the drum. If it is dirty, clean it with hand soap and clean it with hot water......make sure its realy clean and then put it back on.
    Should work.
Access code needed
Access to what service mode or admin mode, pin#
Mar 29, 2015 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
Error c0000
Main Motor of the machine. Mite be because of fusing unit or drum issue or just bad motor
Jun 23, 2014 | Minolta Office Equipment & Supplies
Book Maintenance Copiers Konica Minolta cspro ep300
Exposure lamp the bright light under the big glass is burned out, try reset, by opening front door look to your upper left small access plate remove it this must be done with machine on. press the reset button if the code goes away OK. If not replace the exposure lamp if you can find one a very very legacy Minolta machine!
Nov 27, 2013 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
I have a Minolta cs pro 2080 copier, shading on copies
3 possible causes:
1) The optics are dirty thus making your copy darker. The test for this is to manually lighten the copy using the exposure control on the panel of your copier. Lighten the copy several positions and see if the copy gets better. If it does then the optics need to be cleaned.
2) The copier is overtoned. This means that the toner to developer concentration is to high. This will require a trained technician to lower the toner ratio and then recalibrate the toner/developer ration using the F8 mode.
3) If the shading gets much worse as you run say 10 copies in a row then the drum cleaning blade would be the cause. So run 10 copies of something and compare the first copy out with the tenth copy out. Do you see a dramatic difference in the amount of background or "shading"?
Good Luck and thank you for using Fixya.
Mar 16, 2010 | Minolta EP4000/5000 CS/PRO Copier
Code c 0200 minolta cs pro ep 2050
A c0200 deal with the scanner. You may have a blown scanning lamp. Dose the scanner find HP & does the scanning lamp turn "ON" it could also be the Lens HP. Was this code before or after you were there? If it was showing upafter you.. it could be that the Black Box is installed wrong.... Good Luck
Feb 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
ERROR CODE CO5OO FOR MINOLTA CS/PRO 2080 ????
This is a lamp error, check that is not burned, or the thermal fuse.
1. Press the soft initialization on the right side of the control panel.
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
Warning: Be advised that with fuser codes, some RISKS are involved, PLEASE SEEK PROFESSIONAL HELP to reduce these risks.
Thank you and good luck!
Jun 18, 2008 | Minolta EP4000/5000 CS/PRO Copier
C0071 error code minolta cs pro 2080 copier
this code is for toner motor rotation abnormal timing. check for any loose toner inside the toner hopper rotational path, clean the sensor for toner motor. check the toner bottle inserted is for the same model
Nov 21, 2007 | Office Equipment & Supplies
155 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
