Question about Philips Audio Players & Recorders
Philips Home Theatre HTS3578W no sound
New worked for 2 days then suddenly no sound, reads all information but I can not get into set up
4 Suggested Answers
  • 1779 Answers
SOURCE: Philips LX3600D Home theatre always returns to standby mode
There is a 1ohm resistor on the 4x4 pcb as soon as you take off the cover. ( I forget the ID # ) It supplys the -15volts to the control bd. The resistor will not looked burned. It was under rated. An ohm meter will find it ( open ). Rreplace it with a 1/3 watt. I believe the orig. was a 1/4 watt.
Posted on Apr 11, 2008
SOURCE: Region Unlock code for Philips HTS 3152
Power on the system
Eject the disk tray
Press Stop for around 2-3 seconds
Type in 7,3,4,4,6,6,0
You should get a message saying your player is now Region 0.
Posted on Oct 20, 2008
SOURCE: Just bought a Philips home theatre system HTS3544 low sound?
You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
ST
Posted on Mar 27, 2009
HOW TO FIX SOUND ON MY ANDROID TABLET
Did you swipe down from the top right hand corner of the screen and check your sound settings in there?
Jan 08, 2014 | Cell Phones
Fridge and freezer suddenly not working only 1.5 yrs old
I guess the culprit in this case is the compressor.. Do you hear a sound when you are near the refrigirator.. it will be like a fan rotating at a high speed...
Mar 07, 2008 | GE GSL25LGTBS 25.4 Cu. Ft. Side-By-Side...
Sharp LC-32P70E TV: EPG suddenly not showing
hello, this sounds more like a cable or satelite problem. hame you tried reseting your cable or sat box? usually when you reset the box it will download the guide again...
Oct 16, 2007 | Televison & Video
Cannot read DVD but can CD?
Could be just a dirty lens. Try :-
1) Blowing some compressed air through it. You can get cans, may already have one.
2) Running a CD lens cleaner. Its practically the same mechanics.
After that, its taking it out and cleaning it.
Jun 06, 2010 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Sound system is not working last two days
you can do a system restore back to the date it was working fine. If it was working fine 2 DAYS ago then restore back to the day before. read this to walk you thru the system restore
http://support.microsoft.com/kb/306084
Feb 22, 2010 | Compaq Presario Notebook
Sound all of a sudden stopped working
Remove any games from unit. Remove unit from charger, if that is its condition. remove battery from unit. Allow unit to sit for 5 min. replace battery. Power up unit, re-set initial settings and check for sound. No sound? wire inside unit going to slide switch for volume has come detached, or switch itself gone bad.
Check setup and setting to make sure sound is not muted, although I do not recall that being one of the options.
Mar 25, 2009 | Nintendo DS Lite
2 blinks, power supply
could be a shortin the power supply
Jan 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SMS Problem
I do have solution. Please read and follow information mentioned below. 1) go nd throw your sony ericsson phone to any toilet 2) flush the toilet nd den do **** on it happy now
Apr 21, 2008 | Sony Ericsson P1i
Ps3 does not recognise any disc
man i too have a proble mm mine ps3 stopped reading ps3 disc but it reads only ps2 and other disc. but wont read ps3.. disc i tried getting a new one but it didnt work
Dec 12, 2007 | Sony Playstation 3 (PS3) Console
172 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
