Video player Watson VR3731 - how to connect it to TV set
Hello, I 've got an old vidio player from my son without any manual.
I want to know how to connect and synchronize with TVset Sunay HDMI. Synchronization is the main problem . Thank you in advance for help.
Malgorzata
  • 473 Answers
SOURCE: MS Outlook syncs calendar, notes but not contacts
Click on the hotsync icon in your system tray and then click "custom". That will bring up the list of things you are configured to sync with (conduits). For each of the ones you have problems with, click that conduit and then make sure it's set to sync the way you want...desktop overrides, handheld overrides, syncronize, etc. Potentially you have some of them selected as "do nothing". What shows up when I click custom from hotsync are the following Outlook Conduits: Calendar, Contacts, Tasks and Memos. If you don't have those showing up, you need to update your Outlook conduits on your PC. If you have them, click to select the problem conduit, then click "change" and select what you want to have happen.
Posted on Sep 11, 2005
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
You can also use a digital coax cable (color orange) to go into coax 1 for DVD coax 2 for cable box. Just make sure to set the coax in input settings. The coax cables are a little cheaper than the optical cables and work just as well.
Posted on May 10, 2008
3dmaster
  • 183 Answers
SOURCE: No picture when on TV/Sat mode on receiver
Dear Customer,
Try another tv to this bales,
than try another cables with this your tv ,this way you got problem & find out solution on which you can spend time for ,
than try some channels to sets up your tv configuration,
or must not be imported from another country cause its not similar to your country's signal identification,
THNX
Posted on May 18, 2008
SOURCE: Audio/video synchronization problem
I have tried several versions of Pinnacle products over the years, and have had serious problems with ALL of them. Constant crashes, re-boots, glitches, dropped frames, etc. Sound lagging behind the picture is one of many problems, and can be avoided only be capturing short clips and editing them together. A real pain. i finally gave up on Pinnacle and bought Sony Vegas Movie Studio Platinum. It has a longer learing curve than Pinnacle, but in the long run it has more features and is very stable. Sony Vegas also works with Vista. Pinnacle 10 does NOT, depsite what Pinnacle and the salespeople tell you.
Posted on May 25, 2008
  • 290 Answers
SOURCE: HDMI only for video and sound through regular audio input
DVI does NOT support sound unlike HDMI. Hopefully your PC has a Co-axial S/PDIF digital output. If not you might want to spend the $50 and buy a nice one from Creative. Modern motherboards are even coming with HDMI built-in but that's NOT your situation. I use a 15" DVI to HDMI cable but you are probably using an adapter and the a regular HDMI cable. Get co-axial digital audio cable of the right length and connect it to the co-axial inputs (they're in the upper corner). Use the remote's set-up button and select the "Digital Input" option. This is very powerful. You can assign any of the Optical or Co-axial inputs to any associated device.
I have my PC as Video 3 with sound coming in via HDMI which I assign under the "HDMI Video" menu and sound under the "Digital Input" as "Coax1". I use "Coax2" for the DVD player that lacks an optical output. If you use regular analog you are screwed as you found out. I usually use the headphone jack and an extension cable with the Computer and watch on it's monitor.
All HDTV sets are **** compared to a decent computer monitor. The deliver MUCH clearer video and much higher resolutions that shitty the 1080 HDTV maxes out at. ATSC is **** compared to a PC. Grated, cable is junk compared to ATSC at 1080i but that's another story. Yet, comparing ATSC to a computer is like comparing NTSC or digital cables' crappy 480i with ATSC at 1080i. It that much greater. At least 720p is wide screened unlike 480i garbage that's most of Comcast's "HD" digital junk.
Posted on Mar 01, 2009
Hi I've just got my son a relisys tv model
I thought they only made computer monitors, but you are right they make televisions as well.
relisys tv model Google Search
Apr 01, 2017 | Video Game Consoles & Games
Hello,i have a new sony BX2D Bravia tv for my son and a new PS3 , ive found an old immaculate amp/receiver Sony STRDB940 I used to use ,how can i connect it all together so my son can have great sound for...
Just plug the Red,Yellow,White into the receiver in one of the inputs. Doesn't really matter which one they are labeled just to keep it easy to keep track of.But for ease lets do video one. There should be two sets within the video one input. Put the PlayStation on the set to the right and then run the identical red white yellow from the tv to the set on the left within the video 1 box. Tune your reciever to the Video 1 channel and then the tv to what ever input you have it on probably video 1 as well and your son will be good to go.
Apr 17, 2011 | Audio Players & Recorders
Philips DVP 3020 Wrongly set to Component
Use the yellow composite plug to connect to your tv..this always gives out a signal..
Jay
Feb 02, 2009 | Philips DVP3020 DVD Player
Connection cord problem from VR375 to TV set?
Page 18 of the user manual for your device shows that there are normal video (yellow) and audio (red/white) connectors underneath the A/V out column of connectors - Since your son's TV does not have an HDMI cable (all you would need if that were the case) make sure you connect the A/V out column to the RCA type inputs of your son's TV.
The manual can be found here:
http://downloadcenter.samsung.com/content/UM/200802/20080229102004125_01613A-01-VR375-XAA-ENG-BM-0228.pdf
Dec 31, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
DIGITAL ANALOG CONNECTION
if the tv is showing the same worse quality without connecting any external device.then its the tv problem.and new tv is much advisable.
Nov 23, 2008 | Televison & Video
Set up problems
is this a dvd/vcr recorder combo? or is it just a dvd player? if it is only a dvd player, there wouldn't be a rf input. you won't be able to record or burn recordings.just hook up the audio/video cables to your tv to watch dvd's. if it is a recorder combo without a rf input or output, you may need a rf modulater they sell at radio shack for about $25.
good luck.
wg
Feb 11, 2008 | Televison & Video
Connecting to front inputs of a Toshiba tv
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable.
Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
Oct 12, 2007 | GPX PDL805 Portable DVD Player
Set up for channel 3 on 27gt616
for watching video tape select a/v mode and connect audio & video wire from vcr to tv
Sep 28, 2007 | GE 27GT616 27" TV
Hooking up a dvd player
as you say that it is old tv so there is a possibility that there may not be audio video socket where dcd player can be connected. OR You will have to purchase one video RF converter.RF converter contains one video input in yellow color & two audio input in red & white colour & one cable connector as output. Connect the dvd output to this converter & tune tv program in which place you receive dvd signal.
Sep 17, 2007 | Zenith Z25X22S 25" TV
Televison & Video Logo
182 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
