Question about Dell 1815dn All-In-One Laser Printer
The glass is dirty underneath. How do I clean?
    Problem Solver:
  • 12 Answers
A peace of flanel with white alcohol.
Posted on Jun 22, 2009
How to check exposure lamp on ricoh sc101?
Clean the true white on the slit glass housing. Check for a dirty scanner mirror or that the scanner mirror is out of position. Also, check if the scanner is blocked or if the dirty white plate underneath the glass is obstructed. Try cleaning the glass with water. To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
Jul 15, 2014 | Ricoh Aficio 1013 All-In-One Laser Printer
Dirty copy when scan through ADF
clean the all glass areas and also use compressed air to blow out the adf area on top and underneath the part you lift up, normall there is a white strip underneath try and clean that good with air as well.
Jul 26, 2012 | Samsung SCX-4828FN All-In-One Laser...
I have a Canon CLC 4000, I have put new drums, and developers the fixing unit its OK. the glass(clean inside) too, but when i print o copy the colors are ok but a little Clear in some parts white spots...
If you haven't cleaned the optics and the coronas, do it. Always clean the machine, first. It'll save you money in the end. Not just the original glass. There are 3 optical mirrors in the optics cavity(underneath the original glass). One above the drum, and there are thre high voltage corona wires that get dirty.
White usually means that light is being blocked, and black usually means dirty coronas.
Don't know your technical level. if you need instructions
Let me know
Jan 16, 2011 | Canon CLC 4000 Copier
BLACK LINES APPEAR WHILE SCANNING WITH hp SCANJET
mirrors underneath the glass are dirty or "fogged up" . Remove the glass if possible and clean the mirrors carefully with q-tips.
Dec 25, 2010 | HP ScanJet 2300C Flatbed Scanner
Receiver end of faxes shows vertical black line. I changed drum and toner also cleaned glass scanner. I do not have a glass flatbed scanner only an automatic feeder.
The cause of this problem is usually a dirty scanning glass (there might be ink or white out on the glass). Check the glass really closely or the cause could be dirty optics or a bad CCD board. There are mirrors underneath the scanning glass. Dirty optics can cause lines when faxing or copying. If you can not access these mirrors, they would have to cleaned by a technician.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Sep 08, 2009 | Brother MFC 4350 All-In-One Laser Printer
Copies are printing out light on the top half of page
The developer needs to be changed in your copier. It should be done by a service technician since the the toner developer sensor has to be recalibrated and all developer has to be removed out of the machine including the mag roller. If it isn't done properly the problem will continue.
Mar 19, 2009 | Gestetner Copier
Ricoh Aficio 1232 c SC-101 and SC-142 codes what do they mean?
It is a scanner problem....could be lamp, lens defect, or as simple as the lamp, and lirrors undeer the glass being very dirty, because the code refers to the 'white level"....a calibration that the machine does when switched on. It could be as simple as, the white plate which is underneath the left scale (beside the main contact glass) is dirty (or missing). Try cleaning this (2 screws), and while you're at it, try removing the main contact glass (3 more screws)and cleaning it as well as the scanner bulb, and mirrors (slide scanner to the right with the machine unplugged).
Good Luck
Mar 02, 2009 | Ricoh Aficio 2015 Copier
AFICIO 551 BLACK AND WHITE
Which feeder? Is it in the document feeder or the paper tray?
Could need a pm to replace the drum, cleaning blade, and possibly developer to get rid of the dirty copy and/or the scanner section should be cleaned as well by cleaning the glass as well as the mirrors underneath the glass.
Dec 10, 2008 | Ricoh Aficio 450 Copier
Grayish prints
Try cleaning the optics and scan lamp.Use normal glass cleaner
clean the underneath the copier glass.
If the problem is still there the developer probably need a change.
If you need any more assistance please get back to me.
Thank You
Feb 19, 2008 | Ricoh Aficio 2015 Copier
HP 6110 All-In-One Printer
there should be two screws on the right side of where the glass, take them out, some models you also have to take the screws off of the left side since it is one piece, lift the whole unit With the glass and set aside to clean. ( With power off)
Oct 21, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Dell 1815dn All-In-One Laser Printer Logo
215 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
