I turn on the i70 printer and it fails to come ready. In fact, previously when you opened the blue cover, the ink jet cartridge holder would position itself to the center and now it makes a couple of faint sounds but doesn't do that. Iy seems locked into plave at the right side of the carraiage
  • Lewis Kirschner Jun 17, 2009
    That isn't the problem. Th erubber "band" is on both gears. Something electronically is not allowing the carriage/cartridge head to movre
  • 1,800 Answers
Most likely the rubber chain that moves the printheads+cartridge must being jammed.
checked that out?
Posted on Jun 17, 2009
  • Jalal Sordo
    Jalal Sordo Jun 17, 2009
    well try to unplugg it for 20 mins and plugg it.
    also uninstall and install drivers.
    and reboot.
I recently made my canon iP2770 a continuous ink one. It as going well, untill it said "The holder is in the ink cartridge replacement position.Close the printer's cover.Ink has run out. View the
Throw it in the trash and buy a laser jet.
People who print a lot, and do I, would be better off buying a new printer every time I went to buy cartridges.
The printer I bought was a brother HL 3140 cdw.
~$200 at staples
The cartridges are expensive ~$200 and lasted me for a year.
I said a year!
Jan 27, 2018 | Canon PIXMA iP2200 InkJet Photo Printer
E15 keeps flashing and wont let me use printer
issue: ERROR LED: E, 1, 5
Solution: Reseat ink cartridge (MP150 / MP170 / MP450) Reseat Ink Cartridges Reseat (remove reinstall) the ink cartridges if an error appears Removing Ink Cartridges: After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.Press down on the semi-circular tab to release the cartridge and then remove it.Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.nstalling ink cartridges after confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position. Note: After confirming that the scanning unit support is fixed into position, release your hands.Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.) Confirm that the ink cartridges are installed properly <1> The ink cartridge is not installed properly.<2> The ink cartridge is installed properly.Fold the scanning unit support and close the scanning unit (printer cover).Wait until the preparatory operation is complete; it takes about one to two minutes
Oct 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
Where is the toner cartridge and how do I find it?
Plug the Lexmark 2600 into an electrical outlet and press the power button. Allow the unit to power up. The power button will turn green when ready.
Turn on the Printer and Open the top cover of the Lexmark 2600 by lifting the cover upward. you will find all cartridges down there.
Now you see how to replace them
Remove the black ink cartridge from it's packaging. Remove the tape from the black ink cartridge first and place the cartridge into the left ink cartridge holder. Press the cartridge down into until you hear it lock into place. Close the ink cartridge holder lid by pressing it down firmly. This secures the ink cartridge in place.
Remove the colored ink cartridge from the packaging and remove the tape from the cartridge. Place the cartridge into the right cartridge holder and press down until it clicks into place. Push down the cartridge holder lid.
Close the lid of the Lexmark 2600 and allow the print cartridges to align. The power light will be blinking while the cartridges are being aligned; once the power light turns solid, the printer is ready for use.
Do rate, if found helpful
Nov 27, 2010 | Lexmark X2600 InkJet Printer
How do I load the ink cartridges into the Canon Pixma printer MX320?
1. Make sure that the power is turned on, and open the Paper Output Tray.
2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support on the right side.
The FINE Cartridge Holder moves to the replacement position.
3. FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
(E) Closed correctly
(F) Not closed correctly (the cover is tilted)
6. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
Oct 05, 2010 | Canon Office Equipment & Supplies
I can't seem to install the ink. Am I missing a piece, do the ink carts go into something?
You are not missing anything. The cartridge holder should automatically position itself at the one of either side of the printer when you open the cover, whereby you can remove the old ones and install the new ones. If the cartridge holder fails to place itself at the proper position, turn the printer off and DISCONNECT THE POWER CABLE then try to manually move it to the proper spot (far right or left depending on the type of your printer) and install new cartridges.
Apr 06, 2010 | Canon PIXMA iP1800 Printer
How do u change the ink in the epson 6000?
Things You'll Need:
  • Replacement cartridge (black, cyan, magenta, or yellow)
  1. Step 1 Turn on the printer and press the Color button.
  2. Step 2 Lift up the scanner and wait for the ink cartridge holder to move into position. Remove the ink cartridge holder's cover.
  3. Step 3 Push the tab at the back of the empty ink cartridge to free it from the cartridge holder. Lift the empty cartridge out and dispose of it.
  4. Step 4 Prepare the replacement cartridge by shaking it gently while still in its packaging. Remove the cartridge from its wrapper, taking care to hold it by the sides.
  5. Step 5 Insert the replacement cartridge into the appropriate slot of the ink cartridge holder. Push down on the replacement cartridge until it clicks into place.
  6. Step 6 Close the cartridge cover and lower the scanner until it clicks into place. The printer is now ready for operation
Nov 15, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Cannon MP830 Printer cartridge jam
So you cant get the ink tanks in place properly?
Have you tried this method to ensure they're properly seated? Is the printer on or off when you try to seat the tanks?
Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Apr 04, 2009 | Office Equipment & Supplies
Cannot remove ink cartridge
usually there are are buttons on the printer on has a drop of inkt benath it one is for the paper and one is on and off
open the plastic cover of the printer
turn printer on and press the ink button for 2 -7 seconds (depending of the model) than release it , wait for the cartridge holder to "park" open the holder and remove the cartridge wich was empty by a new one and put the cartridge in the correct place, than close the cartridge holder, than close the cover, press the inkt button once and wait until it is ready
Nov 26, 2007 | Epson Stylus C42UX InkJet Printer
Hoffice jet printer 4215 ink
open the right side of the printer by lifting up. the cartridge holders will come to you. slide them in and lift up to fully install them. put the cover back down and you're ready
Oct 24, 2007 | HP OfficeJet 4215 All-In-One InkJet...
35 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
