Question about Freezers
Whirlpool AFG 7080 Freezer - Relay noises
The temperature seems to overshoot and then it sounds like a relay is oscillating at between 1sec and 1/2 sec . Then it can settle down again and control the temp.
The freezer has been defrosted to ensure the sensor is clear.
Is it a control board fault & is it repairable, or likely to be uneconomic?
  • 1 more comment
  • wraitda Nov 03, 2007
    Had a Freezer engineer call yesterday. He agrees with you & is getting me a price for the board. May have a look at the joints to see if any dry joints.
  • wightweb Nov 18, 2007
    Exactly the same symptoms and it started this November (2007) same month!!!
  • hyperbole Feb 17, 2008
    afg 7080 started to make rapid clicking noise as if mechanical relay faulty. Initially noise stopped and freezer worked OK but over next few weeks display began to indicate -24. (Tried complete defrost etc but no good). Decided that a new PCB is probably required
I had the same problem last year and changed the miniature relay - £3.50 from Maplin. That cleared the problem for 18 months until a couple of weeks ago when the clicking started again. So I changed the relay once more but this time it hasn't cleared the problem. So looking at £146 for new control board from Whirlpool.
Posted on Dec 17, 2009
  • 146 Answers
It sure sounds like you have a problem with the board. It may just be a dry joint or a faulty component. Normally one would replace the board.
Posted on Nov 03, 2007
Whirlpool Chest Freezer Not Cooling Properly After Brown Out
work should be performed by a qualified service technician. verify that there is proper voltage at the wall outlet using a voltage meter. if it is ok check for voltage to the compressor relay. if it is ok unplug the freezer and check for continuity at the start relay and overload. if it is open you have a relay or overload. if it is ok check for the ohms rating at the compressor. common to start/common to run, start to run should be the total of both. also start/run to ground if any of these are open you have a system problem.
Apr 30, 2017 | Freezers
How To Replace Relay On True T-72 Reachin
If it's mounted inside a box along with the capacitors there is 1 screw holding it from the back. Often you have to unmount the box from the compressor to access the screw.
Apr 04, 2012 | True 72 cu. ft. / 2039 liter Commercial...
Moter seems hot,freezer also makes a loud clicking sound every 30 secound
The clicking noise is the overload and relay trying to start the compressor. If you continue to let it click it will eventually break your compressor. Replace the over load and relay.
Dec 28, 2011 | Freezers
After loading freezer a loud buzzing sound started
Is it coming from inside the freezer or outside? If outside either the auto defrost timer is a problem. If the noise comes from the compressor, almost certainly the starter relay inside the electrical cover needs to be replaced. It can be purchased at most refrigeration outlets. If coming from inside, you need to defrost the freezer properly for 12 hours then restart. The noise should go away then.
Jun 12, 2011 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer is around 3 years old. When set at -17 degrees the freezer clicks very noisely, a relay operating I think. When the fast freeze button is pressed this clicking stops but the display reads -27...
In my opinion, since your going for the fast freeze mode, your freezer sets to its lowest operating temperature to fast tract the freezing process.
and about the noisy clicking sound it is probably a thermostat or relays depending on your system which starts and stop the compressor.
i think your freezer is just doing fine.
Dec 29, 2010 | Whirlpool Freezers
Whirlpool freezer AFG 8060 indicates red light and sounds alarm. Temp always held at -16 to -20, though now indicates only -1.
Please check : - Your door for small leak ( gasket / seals) - Temperature sensor for malfunction. A failed sensor will show wrong data.
Dec 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer drain freezes, and constant clicking noise
This clicking noise is a bad relay.
Get it serviced before you run in to a real problem
Jan 29, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
No digital readout
Hello derek143
You Said,
I have a Whirlpool upright freezer AFG 371/H there is a digital display and lights and buttons, on/off temp alarm etc running across the top of the freezer. None of this works but the freezer is still freezing. i have no idea what the temp is.
I think you should try unplugging it for 5 minutes and then try restarting it and see if it reset.
Sep 11, 2008 | Freezers
Philips whirlpool AFG 027 freezer
The orange button is the "turbo boost" - for reduzing the temperature the fast way. Mostly used when first time use or you put in a lot of unfrozen things at once. When reaching optimal temperture it goes off automatically. The red one is the alert button. Not sure about the green one. Under normal conditions none of the lights is on.
Apr 02, 2008 | Freezers
Temperature Control
check if that condenser's dirty first. i suspect that... try that first
Dec 23, 2007 | Freezers
Freezers Logo
483 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
