Question about Apple iPod nano
Iopd wheel not responding
Ipod nano is stuck on chose language. followed all the 5 Rs. tried holding all buttons at once nothing. It is fully charged.
Re: iopd wheel not responding
I have the same problem and since mine was out of warranty, I decided to try and fix it. I ordered a new ipod nano wheel from ebay for roughly 15 dollars. Search youtube for how to open your nano, which is pretty straightforward. Not as difficult as I thought actually. You can then remove the wheel circuit pad and replace it. It peels right off of the plastic part of the wheel and the metal back part also peels off. They used some sort of sticky back tape, which sounds bad when you try to take it off, but reallty not all that bad. Mine is Gen1, so yours maybe different, just be sure to search fro the right model.
Posted on Jul 08, 2008
  • 322 Answers
To be honest with you all you all have the same problem so id get in touch with exsplain your problem and see if they can help as it seems it a fult on there part with seven pepole with the same model all have the same problem/ if not id take them back if under waranty and try a nother model
Posted on Mar 03, 2008
0 characters
3 Points
Won't turn on
Is your iPod fully charged? Sometimes the batteries become so depleted of charge that an accessory charger won't turn it on.
-Try plugging it in to your computer or a wall charger for a while, time will vary but it may turn on.
-If it is not turning on your computer will never recognize it, thus you won't be able to do a restore with iTunes.
-Try a hard restart as well this could help you.
Sep 02, 2010 | Apple iPod nano 4th Generation
Ipod not responding
You may be doing the reset wrong. Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps you!
Apr 18, 2009 | Apple iPod nano
My i-pod nano chromatic 8 GB is stuck!:S
Press and hold the Menu and Centre buttons at the same time until the apple logo appears. (This usually takes between 5 and 10 seconds.)
Information from:
Feb 01, 2009 | Apple iPod nano MP3 Player
Change language to english
You have to reset your iPod. (Note: This is for the 3rd generation iPod Nano)
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
If iPod nano won’t turn on or respond
- Make sure the Hold switch isn’t set to HOLD.
- The iPod nano battery might need to be recharged. Connect iPod nano to your computer or to an Apple USB Power Adapter and let the battery recharge. Look for the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving a charge.
Dec 22, 2008 | Apple iPod nano
check this website for the forum and there are people that has a few tricks to make it work
but it is not a guarantee.. chances are it might be a mechanical problem with the device already.
Aug 25, 2008 | Apple Ipod Nano Second Gen. Green (4 GB)...
What I would do is just plug it in to your computer and leave it there ,.  leave till it is fully charged and then eject it and see what happnes .,  it might work
Aug 24, 2008 | Apple iPod nano
Send it in. Call apple or go to
Dec 20, 2007 | Apple iPod nano
Ipod frozen on language screen
you have to hold the the menu and middle ong for 10-20-30 secs
hold the menu +center button and it will turn off and reset
Nov 24, 2007 | Apple iPod nano
Nano recognized, but click wheel frozen?
great you solved your own problem and posted it!
kudos! =P
Apr 05, 2007 | Apple iPod nano
Apple iPod nano Logo
1,726 people viewed this question
Top Apple MP3 & Digital Media Players Experts
 Mike M
Mike M
Ron Dufek
Ron Dufek
Raisin Brann
Level 1 Expert
Are you an Apple MP3 and Digital Media Player Expert? Answer questions, earn points and help others
