Question about Taylor Chrome & Glass Lithium Digital Scale, Model 7507
Taylors 7507 bathroom scale missing the battery cover
I have the above scale but during a move I lost the battery cover and now the scale doesn't work.
Does anyone have any suggestions as to where or how i might be able to get hold of a replacement??
Many thanks
4 Suggested Answers
r321567499
  • 74 Answers
SOURCE: ERROR message
This link allows you to troubleshoot directly with the company...I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
  • 5 Answers
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Posted on Mar 26, 2010
How do I remove the batteries to replace them?
Hello, Joanne -
WeighMax manufactures more than one model of bathroom scale. See:
http://www.weighmax.com/products/bathroom-scales-1.html
Not all the WeighMax bathroom scales take the same kind of battery. If your scale is one of them listed on the web page cited above, click or tap on the link for the information on the scale and look for the information on Power to find out the kind of batteries needed.
I do not find any instructions for where to find the battery compartment on any WeighMax bathroom scale. Therefore, I suggest you contact WeighMax Technical Support and ask. You will probably need to provide the model number of your bathroom scale. This is the link to the WeighMax Contact Us web page:
http://www.weighmax.com/contacts
Best wishes.
May 15, 2018 | The Health & Beauty
HOW DO I CHANGE BATTERIES IN OZERI BATHROOM SCALE MODEL ZB13
On the back of the scales under the Ozeri sticker, you will find the battery cover. Remove the cover and replace the two CR2032 batteries (model ZB13).
Sep 04, 2014 | Ozeri Scale. Touch Digital Bath Scale in...
How do I reprogram my bathroom scale? It got wet and lost the dataI had put in.Thanks
take out the battery for 24 hrs. then reinstall it and see if it resets. it should do so
Jun 09, 2014 | Homedics SC540 LCD 400 lb180 kg Capacity...
Model 9114 salter scale shows Lo. I have changed the batteries but it still only shows Lo.
I had the same problem and, suspecting that the metal contacts weren't making proper contact with the batteries, I used a long nosed pliers to gently bend all ten contacts towards to the batteries (there are eight small tabs in the battery compartment, and two on the battery cover). If you don't have a long nosed pliers a small screwdriver should do it if you held the fixed part of each set of contacts so it doesn't detach during the process.
Unfortunately, it worked, but only for one weigh, and then it reverted to "Lo". This happened twice, so I telephoned the Salter Customer Service Helpline (01732 360783) who recommended a reset, which is done by removing the batteries, standing on the scale for 20 seconds, and replacing the batteries. That also only worked for one weigh, so they are looking into it further and I'll post the results here, but in the meantime I hope one of the above solutions will work for others.
Jan 21, 2014 | Salter Stainless Steel Electronic Bathroom...
I need a manual for simply bathroom body analysing scale
Could someone tell me the battery needed for the Simply Bathroom body analysing scale - model 4528?
Thanks
Apr 16, 2012 | Health & Beauty
Changed the lithium battery 6 weeks ago it was
Remove the batteries and clean both ends of the batteries with a pencil eraser. Do the same with the contact points in the scale. This should help. Bathrooms are damp, you may want to set it elswhere for reliable use.
Jun 06, 2010 | Taylor Chrome & Glass Lithium Digital...
The numbers on the digital readout are partly
If the display is showing "partial digits" on the display, it means a scale is excessively shaken (sometimes during shipping) it's possible for the LCD to become partially separated from the PCB (Printed Circuit Board). On many models you can gently press on the LCD and it will reconnect. However on many scales it's difficult to reach the LCD (without removing the cover) and thus the scale will often have to be returned to the manufacturer for repair. Contact them at 1-800-326-6247 for the Conair appliance customer service center.
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
ERROR message
Jan 02, 2009 | Taylor 7506 Precision Tech Lithium Battery...
Taylor Chrome & Glass Lithium Digital Scale, Model 7507 Logo
186 people viewed this question
Top Taylor Health & Beauty Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
