Question about RCA P46810LV 46" Rear Projection Television
RCA P46770CK The picture is bowing from the bottom up. Is this a convergence issue or something else, if its the convergence power supply what is the correct part number?
  • ctracy Feb 16, 2008
    I have the same TV, the picture is fanning outward where graphics are cut off in both the left & right sides. Minor screw adjustment or would I have to go to component level repiars?
  • 87 Answers
Check Cr4503 in the vertical circuit for short or leaking. The convergence circuit is most likely fine. Also check for any leaky electrolytic caps in the 500 block. (example) CR4503 will be printed on the PCB as CR503. The vertical circuit is located in the center of the chassis behind the big aluminum heat sink.
Posted on Nov 02, 2007
I have a RCA Rear projection TV and the picture on it looks like a bow tie
This problems u have is known as Convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-$350 for parts and labors.
Aug 16, 2010 | RCA P52929 52" Rear Projection Television
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Bowed Picture; Still have access to convergence. HELP!
The convergence power supply board is usually the cause of that problem. You can get the replacement Convergence power supply board from
Apr 01, 2010 | RCA D52W23 52" HDTV CRT TV
Hi i have a RCA P52937SG with the bowing of the screen
The problem may still be on the power supply board (one of the supplies may be missing and) when you unplug the supply both supplies go missing check the supply voltages and repost
Oct 14, 2009 | RCA P52937 52" Rear Projection Television
Convergence Power supply board. In the television above the cuircit boards there are two curcit boards that sort of hang above. the one on the right is the convergence amplifer board(has metal fin like heat sinks).. The one on the left is the convergence power board. Since you have options and no control, bowing picture. this would be my first choice. Now it still may have convergence amplier trouble. To get these boards you will have to get the entire model with suffix ext. it will be like d52w20...yx1 yx2 or something like that. in small leter on the model sticker on back
Dec 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No adjustment will fix this, what has happened is a power supply board for the convergance has failed and needs to be replaced or repaired
Mar 07, 2008 | RCA P61940 61" Rear Projection Television
RCA Home Theatre System 51 or 52"? Chassis # PTK169PAAS
If it is a "minor" convergence problem you can adjust it by going to the menu and scrolling to convergence and follow prompts A cross will appear when you have reached the correct place and you do the minor adjustments as it says. If picture is bowed you have major convergence problems.
Jan 05, 2008 | RCA 32V420T 32" TV
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
This set might have a convergence power supply that could be out, might have another issue, I suspect something in the power supply on these.
Nov 05, 2006 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
122 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
