Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Dvbt tuner maximum t-102fta stays on one chanel,
Why chanell changes frequently?
Change the tuner module.
Feb 20, 2015 | Televison & Video
My toshiba lcd is 5 years old and i been using it in uk now iwant to watch australian free chanels model no is 42x3030d
You have to select analog tuner to scan for the antenna signals.
You can select this in the menu.
Regards GJ
Jun 22, 2014 | Toshiba Televison & Video
Tuner will not change chanels line inside broken
Tuner strings are available online, there are several vintage suppliers
Mar 06, 2012 | Marantz 105 Tuner
Once the tv is on for a short time it starts flipping Chanels by its self and will not stay on one chanel. what to do?
fishmill1,
Fist remove the batteries from the remote to eliminate that as the problem. Next if the problem exists replace the up/down tact switches on the TV control board. They are available at http://www.digikey.com or http://www.mouser.com . If this does not solve the problem look at replacing the tuner or the board that the tuner is on. I have a tip at http://www.fixya.com/support/r6981868-replace_circuit_board_in_modern_tvs which will help with the board change.
Thanks for using FixYa and for the great rating.
hardrocko
Jul 01, 2011 | Televison & Video
Digital chanels will not come through
have aq service tech come and check your digital tuner. first check and see if you are using that particular tuner. some tv's come with two types a digital and an analog tuner.
Nov 06, 2009 | Broksonic CTVG-5463GVC 19" TV
Satelite tv through my dvr-550h
satellite tuners and DVDs have different remote,unless your using a universal remote with satellite tuner command available.to program recording, you'll need to program the time especially the allotment.then make sure you sat tuner is tuned to the station you want to record.after setting the time and station, its all set.you don't need the DVD's remote to change the channel.
May 27, 2009 | Pioneer DVR-550HS HDD Recorder
Got a new Dell Studio 17 laptop with TV Tuner, but TV wont go
if it is not finding channels, it could be a physical connection problem from the antenna or the antenna lead on the device.
Mar 10, 2009 | Dell Studio 17 Laptop
Blue screen
the problem of ur tv is tuner,try to solder the tuner
Sep 28, 2008 | JVC AV-27120 27" TV
Problem with chanels on Magnavox LCD 20in TV/Monitor
check the tuner or the IF circuit they could be defected.good luck.
Apr 19, 2007 | Philips 20MF605T Television
DVBT-100 Digital TV Tuner PCI Card
Normally, the driver you have with the hardware is the driver you must you, as it may cause all sorts of conflics trying to use others. Intervideo would not have written a driver for your dvbt card, only their own.
Oct 30, 2006 | KWorld DVB-S 100 (DVBS100) Video Capture
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
