Question about Refrigerators
Can I drill a hole in the side of my westinghouse rj340m fridge .
I want to put a ''BEER GAS LINE'' through the side of my fridge & am hoping not to hit an internal line or something else,thanks..
  • 159 Answers
The most fridges i have stripped the pipes are on the left hand side and the power wires on the right hand side but if the pipe is drilled thru it is only the oil cooled pipes it can be disconnected the important piper are at the back of the frige i hope this will help you
Posted on Jun 17, 2009
  • roosta5 Jul 03, 2011
    You should be able to drill a hole on the side of it, all the pipework is at the rear of the fridge, i have done this is several of my fridges and for customers, 2 for chilled water , another for the yummy beer and the last to keep a laser cutter cool and it worked a treat , but i also use copper tubing inside the fridge as it conducts cold air better than plastic, without leaving a taste behind, however u may need to install a pump and a flow and return set up inside the fridge for it to work to its optimum level, hope this helps
I want to drill a hole for beer gas line in side or back but cannot find a schematic. Is there anywhere to avoid?
YES
the evaporator sections ( most are in the back and some include in the sides as well)
normal fridges do not have evaporator sections in the floor of the fridge as cold air always falls to the bottom so in from the bottom and out through the bottom would be the way to go
make the cooling coils with end connections so that all you need is 2 holes and the pipes straight up and then connected to the cooler colis
Dec 11, 2015 | Refrigerators
Drill side keg
should not b any on either side,remember to insulate the attached beer valves
Nov 23, 2013 | Frigidaire FRT17G4B Top Freezer...
I want to drill a hole in the side of my freezer for beer lines. where should i drill
Somewhere near the center of one of the sides is best.... but it can still be a guess and by golly deal....
Just keep the beer handy and if you hit a refrigerant line just down a few to make you feel better... :-)
heatman101
Nov 07, 2010 | Freezers
I have a Westinghouse frost free fridge with freezer on top.(RJ340M) Freezer part is working great but the fridge is not performing well at all. Thermostat was my first thought but wouldn't that be...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 23, 2010 | Westinghouse Refrigerators
Westinghouse Upside down Fridge Freezer Model #BJ504T-R5. Fridge will not go cold, cannot have a a Cold Beer out of it. Any suggestions on how to fix this problem? Freezer works OK
put the beer in the freezer for 30 mins,that should cool it nicely.....
oh, the fridge aint working, sorry,poss the thermostat or (still thinking about drinking warm beer, ugh...)have you tried cleaning the vents...
Aug 18, 2010 | Refrigerators
Beer tap
Good day,
If it has the condensor coil mounted on the back of the machine.
(black coil) then yes, VERY DANGEROUS. Refrigeration lines run at an angle from the bottom back of the machine at an angle and terminate at the bottom of the freezer door.
This applies to both sides. Hit one of those and your finished.
Jul 21, 2010 | Frigidaire FRT17G4B Top Freezer...
I want to install two beer tap faucets in the side of my fridge
All of wires are located in the bottom. The side walls are just filled with foam. HAPPY DRINKING
Dec 05, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Making Modifications to my Hoover Orchid Collection 480L fridge
if it is a fridge and not a fridge freezer, then there should be no problem in drilling a hole thro the side
Aug 21, 2008 | Hoover Refrigerators
Put together
1 Chrome Rail (for attachment to Worktop)
4 Self-Tapping Screws (to attach chrome rail)
1 CO2 Cylinder Support Stand
1 CO2 Cylinder (empty)
1 CO2 Regulator (high/low pressure gauges)
1 CO2 Air Line Hose (red)
2 CO2 Air Line Hose Connectors (black)
1 Beer Keg Coupler
1 Beer Tower Unit (complete with faucet, hose and wing nut)
1 Rubber Washer (to be installed inside wing nut)
1 Beer Tower (Quick Connect) Bayonet Attachment (beer tower installation)
4 Machine Screws (to attach bayonet to beer tower)
1 Gasket (beer tower base)
1 Pull Handle (beer tower faucet)
1 Beer Keg Stand (required for 30 liter keg installations only)
1 Protective Plate (refrigerator cabinet floor)
2 Cantilever Wire Shelves (conversion to all refrigerator application)
1 Chill 'n Tap Exterior Cabinet Plug (located on worktop)
1 CO2 Air Line Hose Plug (located exterior rear cabinet)
1 Plastic Drip Tray (2 piece)
1. Remove Worktop: Using a Phillips Screwdriver, remove the
three screws located on the front underside edge of the
worktop and the three screws located at the rear (back)
side of the worktop.
See Fig's. 1 & 2
Remove the worktop from the cabinet and position the
worktop on top of the cabinet so that the front corners
are staggered across the front corners of the cabinet.
2. Installation of Top Rail: Attach the chrome rail to the work
top using four self-tapping screws from the underside of the
worktop through the pre-drilled holes. (attach the front ends
of the rail first)
3. Re-Install Wo r k t o p : Install the front of the worktop onto the
cabinet, then lower the rear side of the worktop over the
backside of the cabinet. Secure using the same screws
removed earlier. (the smaller screws at the front the larger
screws at the rear)
4. Installation of CO2 Cylinder Support: Install the cylinder
support onto the four studs located on the exterior back
wall of the cabinet. (no tools required) Align the holes in
the cylinder support with the studs and push down firmly.
See Fig. 3
5.
Installation of CO2 Cylinder: Install your " fully charged"
CO2 cylinder into the support stand. IMPORTANT NOTICE:
ALWAYS EXERCISE EXTREME CAUTION WHEN
HANDLING PRESSURIZED C02 CYLINDERS:
6. Installation of C02 Regulator:
Attach the CO2 Regulator to
the C02 cylinder by screwing the regulator nut onto cylinder
valve and tighten (snug) using an adjustable wrench.
7. Installation of C02 Air Line Hose to Regulator: Attach one
end of the (red) air line hose to the hose barb connection
on the CO2 regulator. Secure hose by using one of the two
(self locking) black plastic snap on clamps provided.
(use pliers to snap the clamp tight to assure that there are
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
CHI
See Fig's. 1 & 2
of the rail first)
screws at the rear)
See Fig. 3
5. Installation of CO2 Cylinder: Install your " fully charged"
6. Installation of C02 Regulator: Attach the CO2 Regulator to
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
LL'N TAP ACCESSORIES (included with this unit)
Jan 07, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Refrigerators Logo
509 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
