Question about Fuji FinePix S602 Zoom Digital Camera
Battery compartment cover
My battery compartment cover is chipped and won't clip shut. The hinge is perfectly intact, it's just the plastic cover (which slides off the hinge) that I need to replace. Fuji won't send one out "for health and safety reasons" and they want £99.00 to do a "repair". Does anybody know where I can get a cover?
  • d7tlf Jan 21, 2008
    I have exactly the same problem and fuji must know its a problem as it is so easy to change if the part was available, this is really putting me off Fuji as all they want to do is charge £99 for 10 seconds work its that easy to change
    D Telfer
  • kenwatson Sep 22, 2008
    My S602Z battery cover is also cracking up, two of the three anchor points have gone, and the third is cracking. £99 is extortionate and probably reflects the value of the whole camera now. Thin plastic cable ties, aren't pretty but do the job but are prone to 'pop off'. A new cover is the answer.
The plastic cover is attached to a metal hinge, but the plastic bit that stops it coming adrift is worn, you can bend the metal part that slides into the cap so as to enable plastic cap to hold on
Posted on Mar 08, 2008
Hi how u going? I just brought a new cover for AUD24.01 which includes postage n tax from Fuji here in Australia.
Fujifilm Australia Ltd 114 Old Pittwater Rd Brookvale NSW 2100 Australia Ph (612) 9466 2600 www.fujifilm.com.au
Freecall 1800 226 355
All the best
Paul
Posted on Nov 19, 2007
    Novelist:
  • 233 Answers
They really want you to buy a new camera instead!
TAPE it shut!
Otherwise you can sometimes find equipment sold 'as-is' for parts on eBay or other internet sites.
Do a web-search for it.
Posted on Nov 01, 2007
Where do you replace the battery on this safe and what kind of battery
Although the following is applicable to most Safe, you model may differ.
The hardest part about changing the battery in a digital safe is finding where it is. But don't worry, it's not inside. The battery compartment is under the keypad, and has a little tiny hole for removal. If you don't have a jeweler's screwdriver that is small enough, you can use a straightened-out paper clip. The battery is a 9 volt.
Things You'll Need
  • Jeweler's screwdriver or paper clip
  • 9-volt battery
  • Insert the jeweler's screwdriver or paper clip into the small hole in the plastic panel, just below the keypad and to the right of the keyhole.
  • Slide the panel to the right.
  • Carefully pull the old battery out.
  • Carefully unsnap the wire connector from of the old battery. The connections are like clothing snaps and just pull off.
  • Snap the connector onto the new battery. Be sure to observe polarity--it will fit only one way.
  • Carefully put the new battery into the battery compartment, storing the wires out of the way of the cover.
  • Insert the cover in its slots, and slide it back into place with the jeweler's screwdriver or the paper clip.
Mar 09, 2016 | Home Security
Tip
What to do when the "replace system battery" message displays on a Partner ACS...
The Partner ACS system uses 2 AAA batteries to retain programming from 45 to180 days, in the event of a power outage. When these batteries fail, a system warning (replace sys bat w/ power on) will display on the screen of extensions 10 and 11. Replacing the system batteries doesn't require a service technician and is fairly simple to do providing you know the proper steps.
With new batteries in hand, go to the phone system cabinet and find the system processor. The system processor will be marked on the top third of the card with a label marked "Partner ACS processor".
On the bottom of the processor module,below the extension jacks, there is a battery compartment. With the power on, Push in slightly on the battery compartment and slide the black locking latch up to cover the"+" icon. Remove the battery assembly by pulling the tab at the bottom of the compartment cover.Place the batteries into the metal battery clips fully. Make sure the polarity of the batteries is correct by looking inside the metal battery clips for the "+" and "-" icons cut into the metal of the battery clip. With the locking latch in the unlocked (up) position slide the battery assembly back into the processor card far enough that the edges of the assembly slip behind the plastic housing of the processor card.Slide the locking latch down to secure the battery compartment. The message on your screen will disappear if the batteries are inserted correctly.
on Jun 17, 2010 | Lands Phones
Add ram Satellite u845
Power down your Toshiba Satellite.
Unplug it from the wall.
Turn the machine over and remove the battery.
Locate the RAM compartment cover, which is usually located somewhere in the middle of the underside, and is about 4-by-4 inches.
Unscrew the RAM cover screw with a Phillips screwdriver and set aside.
Ground yourself by touching a metal object.
This will release any static electricity built up in your body, which can harm computer chips and components.
You can also use an anti-static wristband while you are working.
Remove RAM modules if needed.
This is most likely if you are upgrading the present RAM capacity with a larger RAM chip.
Press your fingers on the clips on either side of the chip to pop it out of the socket.
Pull the chip out of the RAM compartment, holding it by the sides of the circuit board rather than on the chip.
Insert the new RAM module into the socket. Align the RAM module so that the notch lines up with the tab on the side of the socket.
Gently lower the module into the socket. Press into place with your fingers.
Replace the RAM compartment cover. Insert the screw and tighten.
Replace the battery and secure with the lock.
Plug the Toshiba Satellite laptop back in and power up the system.
The upgraded RAM should be automatically recognized.
hope this helps
HOW TO INSTALL MEMORY UPGRADE TOSHIBA SATELLITE LAPTOP
not sure if this is the right laptop
http://www.youtube.com/watch?v=RdCzsjDp_lc
Oct 12, 2012 | Toshiba Satellite U845-S402 14" Notebook...
How to change the cooling fan in a toshiba laptop model p200d-139
Instructions
Shut down your Toshiba laptop, and then disconnect all cables. Close the LCD lid, and then place the laptop face down on a flat surface. Position the laptop with front edge facing you.
Locate the battery pack near the top section of the laptop's bottom casing. Press on the battery release button. Remove the battery from the laptop.
Locate the cooling fan compartment cover. Its location varies from laptop to laptop, but it will be the only hardware cover with a vent in it. Remove the Phillips-head screws securing the fan's cover in place. Remove the cover from the laptop.
Disconnect the fan's cable from its connector on the motherboard. Remove the Phillips-head screws securing the fan in place. Lift the old fan out of the fan compartment and set it aside. Removing the old fan will reveal the processor chip. Apply a thin coat of thermal grease to the processor's surface using a clean paper towel. This will prevent your new processor from frying once you power on your laptop.
Place the new cooling fan assembly inside the fan compartment. Align the screw holes on the new fan with the screw holes inside the compartment. Replace the four retaining Phillips-head screws, and then reconnect the fan's power cable to the motherboard. Replace the fan compartment's plastic cover, and its retaining Phillips-head screws.
Replace the battery pack and reconnect all power cables and external devices. Turn on your laptop to test the new cooling fan
Jul 28, 2012 | Toshiba Computers & Internet
Replace system battery,with power on?
The Partner ACS system uses 2 AAA batteries to retain programming from 45 to180 days, in the event of a power outage. When these batteries fail, a system warning (replace sys bat w/ power on) will display on the screen of extensions 10 and 11.With new batteries in hand, go to the phone system cabinet and find the system processor. The system processor will be marked on the top third of the card with a label marked "Partner ACS processor".
Dec 21, 2010 | Lucent PARTNER18 Corded Phone
How to replace ribbon on nokia 6085 my phone works but screen is blank!
Well, you need to remove the hinges that are in the middle where you flip the phone. The correct method would be: 1. Open the top panel (One covering the small blue LCD) 2. Remove the screws connecting the chip. 3. Remove the chip by removing the connector. 4. Open the battery cover. 5. Remove the plastic guard that's above the battery cover - you can do this by hand. 6. Remove the 4 screws here. 7. Remove the back cover and the chip. 8. Remove the connector connecting the chip. 9. Carefully press the hinge on the left side through a small hole in the side with a thin strong device. Now you should see a pin slide out towards the middle of the phone. Hold this pin in place with a screwdriver - if you don't, it'll slide back into place. 10. Pull out the top panel now. 11. You should easily be able to remove the ribbon connector. Work backwards to fix it all back :) Hope you fix it :)
Apr 22, 2010 | Nokia 6085 Cellular Phone
How to replace cr2016 from 450d/XSi or 500D/Xt1
The other bloke doesn't know what he is talking about..this is plainly obvious.
Looks like the CR2016 is inside the battery compartment under a small cut-out plastic piece (on same side as hinge). Use a torch and you can see it under this plastic piece.
You either need to dissemble it to get access or break off this plastic cover to replace...or take it to canon.
Dec 22, 2009 | Canon EOS 450D / Digital Rebel XSi Body...
The little clip on the battery cover on my Nikon Coolpix 4300 has broken. I see I can buy a new one online, is it worth it?
Mine has broken as well. It appears this clip is just to keep the battery from falling out as you open the battery door. It will function perfectly fine without the clip. Just be careful not to drop the battery when you open the battery compartment.
Hope this helps,
-Tor
Nov 21, 2009 | Nikon Coolpix 4300 Digital Camera
PASSWORD
Remove the RTC battery for at least 15 monutes then replace. Get into BIOS and reset date and time. Removing the Coin-Cell Battery
  1. Follow the instructions in Before You Begin.
  2. Remove the hinge cover (see Removing the Hinge Cover).
  3. Remove the keyboard (see Removing the Keyboard).
  4. Insert a plastic scribe into the guide on the side of the coin-cell battery compartment, and pry out the battery.
Replacing the Coin-Cell Battery
  1. When you replace the battery, insert it at a 30-degree angle under the clip with the positive (identified by a plus [+] symbol) side up, and then push it into place.
  2. Replace the keyboard (see Replacing the Keyboard).
  3. Replace the hinge cover (see Replacing the Hinge Cover).
Oct 02, 2009 | Dell Inspiron 1501 Notebook
Optio 555 Battery Compartment cover problem
My Optio 450 has the same type of cover and I am surprised how tough the cover is. I thought it would have broken by now. I suggest a call to Pentax would answer your question about getting it fixed. Alternatively, just leave it. The Plastic hinge should keep it closed
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Fuji FinePix S602 Zoom Digital Camera Logo
814 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
