Wolfgang Schmuck Total Scooter Logo
Stuart Sieber Posted on Apr 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for the correct spark plug gap for a 40cc sthil fs 250 z weed eater
David Bennethum
Level 2:
Scholar:
  • Expert 69 Answers
  • Posted on Apr 09, 2014
David Bennethum
Expert
Level 2:
Scholar:
Answers
69
Questions
0
Helped
55740
Points
146
0.02 in (or)
0.5 mm
Here is a link to the full manual. Spark plug info is on page 50.
HOPE THIS HELPS!
David
http://www.stihlusa.com/admin/webcontent/cmsfilelibrary/instructionmanuals/fs120_200_250_manual.pdf
The diagram of how to replace the throttle cable on a Stihl 55 weed eater
I'm sorry, but I can't provide a visual diagram as I can't display images or diagrams. However, I can give you a step-by-step guide on how to replace the throttle cable on a Stihl FS 55 weed eater.
Before you begin, make sure you have the necessary replacement parts and tools.
Materials and Tools:
  • Replacement throttle cable
  • Screwdriver
  • Pliers
  • Allen wrench
  • Socket set
Procedure:
  1. Safety First:
    • Ensure the weed eater is turned off, and the spark plug is disconnected to prevent accidental starts.
  2. Remove the Air Filter Cover:
    • Locate the air filter cover on the weed eater's engine and remove it. Typically, this involves loosening screws or clips.
  3. Access the Throttle Cable:
    • With the air filter cover removed, you should be able to see the carburetor and the throttle cable attached to it.
  4. Disconnect the Throttle Cable:
    • Carefully disconnect the throttle cable from the carburetor. This might involve loosening a screw or bolt holding it in place. Note how it is routed and attached.
  5. Remove the Handle Housing:
    • Locate the throttle trigger on the handle housing and remove it. This may involve unscrewing parts of the housing or loosening screws to access the cable.
  6. Replace the Throttle Cable:
    • Feed the new throttle cable through the handle housing and reattach it to the throttle trigger. Make sure it's properly connected.
  7. Reconnect at the Carburetor:
    • Reattach the other end of the throttle cable to the carburetor in the same manner it was originally connected.
  8. Adjust the Cable Tension:
    • Adjust the cable tension to ensure it operates smoothly. There should be some slack when the trigger is released but no excessive play.
  9. Reassemble the Weed Eater:
    • Reattach the air filter cover, making sure it's secure.
  10. Connect the Spark Plug:
    • Reconnect the spark plug and ensure it's properly seated.
  11. Test the Throttle:
    • With all the components reassembled, test the throttle to ensure it's working correctly.
  12. Start the Weed Eater:
    • Reconnect the spark plug and start the weed eater. Verify that the throttle is responsive and functions as expected.
This is a general guideline for replacing the throttle cable on a Stihl FS 55 weed eater. Keep in mind that specific models may have variations in their design and components, so refer to the user manual or consult with a professional if you encounter any difficulties during the replacement process.
2answers
1helpful
2answers
What is the spark plug gap for 18cc weed eater?
search
What is the correct spark plug gap?
The spark plug gap on all products is .025-inch.
What type of spark plug does the unit take?
The size of the plug varies from unit to unit. On trimmers, blowers and hedge trimmers is RCJ-8Y or RCJ-6Y. Follow the spark plug recommendation and replacement procedures in the operator's manual if you are doing the work yourself.
Sthil fs 85 trimmer runs only on starting fluid
check for breaks in fuel line, check fuel filter.
SPARK PLUG GAP
0.02 in (or)
0.5 mm
HOPE THIS HELPS!
David http://www.stihlusa.com/admin/webcontent/cmsfilelibrary/instructionmanuals/fs120_200_250_manual.pdf
My sthil fs 80 has new carb and new rings. has spark but wont start
Is fuel getting into the cylinder.? Is the spark continuous, check gap between flywheel and ignition module. 0.25 filer guage.
Top Wolfgang Schmuck Apps Experts
ADMIN Andrew
ADMIN Andrew
john h
Marty Warge
Are you a Wolfgang Schmuck App Expert? Answer questions, earn points and help others
