Question about Epson Stylus C86 InkJet Printer
Cannot change the ink cartridge.
When I open the top up the ink cartridge remains partly covered. This prevents me opening it to replace the cartridge.
  • Epson Master
  • 511 Answers
Turn on printer, unplug power while head moving. So head carriage not in parking position. Or.. if head is parking, push head locking (leff side of head).
Posted on Jun 17, 2009
How do i change the ink cartridge
    • Make sure the printer is plugged in and turned on.
    • Grasp the front top of the printer. This is the Scanning Unit Cover.
    • Lift the Scanning Unit Cover gently until you hear a click. The cover will remain open by itself.
    • Wait while the cartridge holder moves from the left to the center of the printer. The ink cartridges are located in the cartridge holder.
2. Then from there you just need to remove each individual ink cartridge and replace it with your newly purchased cartridges. Be sure to replace each one in it's appropriate location!
Jul 24, 2011 | Canon Pixma MP480 All-In-One InkJet...
Please tell me how do I change the ink cartridge in my Epson TX650?
1) Looking at the front of the printer/scanner there is an indent on the left hand.
2) Lifting up on this portion should reveal the inside of the printer.
DO NOT touch the flat cable inside the printer, DO NOT force the lid, it should open easily.
3) The ink cartridge is underneath the plastic cover in the back right-hand side of the printer. Gently pull up on the cover until it swings open.
4) pinch the clips holding the ink cartridge in the printer and pull up.
5) Unpack the new ink cartridge.
6) Remove the tape that is on the ink cartridge.
(If you forget this step the printer won't print. If that happens, remove the new cartridge, remove the tape and then reinsert the cartridge)
7) Insert the ink cartridge and push gently until it clicks into place.
8) Close the cover over the ink cartridges, and then close the printer cover.
9) Follow any direction on the front display (hit OK)
May 07, 2011 | Computers & Internet
I just replaced all my inks and it is still telling me to replace my cartridges i also turned it on then off
  1. Open the scanner.
  2. Press the cp_button_14.gif Stop button to move the cartridges to the replacement position.
    Caution: Do not move the print head by hand; this may damage your all-in-one. Always press and release the cp_button_14.gif Stop button to move it
  3. Open the cartridge cover.
  4. Press down all the ink cartridges until they click into place to make sure they are properly seated.
  5. Close the cartridge cover and push it down until it clicks into place.
  6. Close the scanner.
  7. Press the cp_button_14.gif Stop button to begin charging the ink. This takes about 2 minutes.
    When the On light stops flashing and remains on, ink charging is finished.
    Caution:
    Never turn off the Epson Stylus CX while ink is charging or you'll waste ink.
    If the ink light flashes, press the cp_button_14.gif Stop button and press down all the cartridges securely.
    If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
    If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 22, 2011 | Epson Stylus cx7450 All-In-One InkJet...
How to change ink cartridges on an Epson CX 3800
Be sure you have a new ink cartridge before you begin. Once you start replacing a cartridge you must complete all steps in one session.
1. Make sure the Epson CX printer is on.
2 Make sure the document cover is closed, then open the scanner
Caution: Do Not open the scanner when the document cover cover is open.
3. Press and release the " ink " button. The ink cartridge moves to the check position and the
" On " and " ink " lights flash. If one of the cartridges is low or empty, the printer moves the
cartridge to the _ink out mark.
Note: Don't hold down the " ink " button for 3 or more seconds or the printer starts cleaning the print head.
Caution: Do Not move the print head by hand; this may damage the printer, always press the ink
button to move it.
4. Press the " ink " button again
a. If more than one cartridge is low or empty, the next cartridge moves to the_ink out position.
b. If all of the empty or low cartridges have been identified, the print head moves to the ink
cartridge replacement position.
5. Open the cartridge cover.
6. Squeeze the tab at the back of the empty/low cartridge and lift it straight out.
7. Before you open the new ink cartridge package shake it four or five times, then remove it
from the package.
Caution: Do Not remove or tear the label on the cartridge; otherwise ink will leak.
Do Not touch the green chip on the front of the cartridge, this can damage the
ink cartridge.
8. Place the new ink cartridge into the cartridge holder and push it down until it snaps into
place.
a. Replace any other cartridges that need to be replaced.
9. Close the ink cartridge cover and press it until it clicks into place.
10.Close the scanner.
11. Press the " ink " button The print starts charging ink and the " On " light starts flashing. This
takes about one minute. When it's finished the " On " light stops flashing and remains on.
and the " ink " light goes out.
Caution: Never turn off the printer while the " On " light is flashing or you'll waste ink.
Note: If the " ink " light stays on ( not flashing ), the ink cartridge may not be installed correctly.
Press the " ink " button again and reinstall the ink cartridge until it clicks into place.
Feb 09, 2011 | Epson Office Equipment & Supplies
Ink cartridges will not move in place error # 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 - Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont...
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn't move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Jan 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
HOW DO I CHNGE THE CARTIDGE.?
Replace the print cartridge
When you notice that the print becomes light or ink low or when install new ink cartridge appears in the display, replace the print cartridge. The part number for replacement cartridges is HP 20.
1. Take out a cartridge from its packaging and carefully remove the tape covering the printhead.
Hold the cartridge by the colored top or black areas only. Do not touch the copper area.
2. Press the Access Cartridge button on the control panel.
The cartridge carrier moves to the install position.
3. Open the control panel and cartridge compartment cover (it will click and remain open).
4. Pull the cartridge toward you and remove it.
3 To load the cartridge insert the cartridge as shown below. When the cartridge is pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
5. Close the cartridge compartment cover and control panel.
6. Press Start/Enter.
7. Press 1 for new cartridge, or 2 for the old one.
• When you put in a new cartridge, you must choose 1:New
• When you put in a used cartridge, choose 2:Used. This helps you to check the correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount of remaining ink. Once you have put in a new cartridge, use it until it is completely exhausted.
Dec 22, 2010 | HP 1040 Plain Paper Inkjet Fax
Ink Cartridge replacement
Downloadable Manuals please refer this manual.....
Sep 16, 2009 | Epson Stylus C48 InkJet Printer
Replaced Yellow Cartridge, Red light on, close lid, not working,
Hi ...
I would suggest that you follow the below stesp to install the ink tank ..
. Ensure that the printer is on, and then open the Top Cover.
The Print Head Holder moves to the center.
Note: If the Top Cover is left open for more than 10 minutes, the Print Head Holder moves to the right. Close and reopen the Top Cover to return the holder to the center.
2. Open the Paper Output Tray.
Put your fingers in the notches in either side of the Paper Output Tray and pull down to open it, and then pull down the Inner Cover forward to open it.
3. Remove the ink tank whose lamp is flashing fast or is off.
Push the tab and remove the ink tank.
Do not touch the print head lock lever; remove only the ink tank.
Caution: Handle ink tanks carefully to avoid staining clothing or the surrounding area. Discard empty ink tanks according to the local laws and regulations regarding disposal of consumables.
Note: Be sure to replace ink tanks one by one when replacing more than one ink tank.
4. Prepare a replacement tank.
* Do not touch the electrical contacts on the ink tank. Doing so can cause the printer to malfunction or become unable to print.
Unpack the new ink tank and completely pull off the orange tape. Then, remove the film. Remove the orange protective cap from the bottom of the ink tank and discard it.
Important:
  • Be sure to remove the clear film from the ink tank in the exact order shown in step 4, as failure to follow this step may cause the ink to leak and stain your clothes and hands.
  • Do not squeeze the side of ink tanks as this may cause the ink to leak out and stain your clothes and hands.
  • Do not re-attach the protective cap once you have removed it.
  • Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
  • Ink on the removed protective cap may stain your clothes and hands.
  • Ensure that all the orange tape has been peeled off along the perforation. If there remains a part of the orange tape, ink may not be output correctly.
5. Install the ink tank.
(1) Insert the ink tank into the Print Head.
(2) Press on the 'PUSH' mark on the ink tank until the ink tank snaps firmly into place.
(3) Ensure that the ink tank lamp lights red.
Important: Ensure that all the ink tanks are installed in the order directed by the label. The printer cannot be used unless all the ink tanks are installed.
6. Close the Inner Cover.
Note: Ensure that the Inner Cover is closed. Printing will not occur if the Inner Cover is open.
7. Close the Top Cover.
The Print Head Holder moves to the right. The ink tank installation process is now complete.
  • The ALARM lamp still flashes orange after the Top Cover is closed if an ink tank is not installed properly. Open the Top Cover and make sure that all the ink tanks are installed in the correct order directed on the label.
  • To maintain optimal print quality, use an ink tank within six months of first use.
  • Once an ink tank has been used, do not remove it from the printer and leave it out in the open. This will cause the ink tank to dry out and the printer may not operate properly when it is reinstalled.
  • Color ink consumption may occur even when black-and-white or gray scale printing is specified.
    Color ink is consumed in the head cleaning and deep cleaning, which are necessary to maintain the printer.
  • When you start printing after replacing the ink tank, Print Head Cleaning is performed automatically. Do not perform any other operations until the Print Head Cleaning finishes. The POWER lamp flashes green during cleaning.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Epson Stylus C86 InkJet Printer Logo
64 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
