Question about Creda W100FW Front Load Washer
My washer does not empty
I have a creda simpicity 1000 washer it was bought second hand from a proper shop so dont know exact age but it fills ready to rinse and spin it spins but the water does not ever empty i have tried to find a pipe to see if it is blocked but being a newbie at diy am struggling please help
  • Creda Master
  • 3,463 Answers
Hi. Remove bottom rear panel of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage as well.
Please rate my solution.
Thanks.
Posted on Jun 27, 2009
I had the same prob when i had a new kitchen fitted. . all i did was put the pipe that goes to the sink part in the shape of a n , that will solve it.......
Posted on Jun 20, 2009
Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Apr 08, 2010 | Creda W100FW Front Load Washer
I have a creda simpilcity 1000 which has 3 sections to the drawer, i dont know which i put washing liquid in and which softner?
The smallest compartment is for softner. Or another way is to just pour a small amount of softner into compartment and ensure it stays there for wash.
Mar 15, 2010 | Creda W100FW Front Load Washer
The suspension spring came undone and fell accross the circuit board shorting it out. Now it will not change cycle and does not wash. I don't think it is filling properly and it doesn't seem to drain...
That sounds like you have right idea. Call your service provider and give them your model and serial number of your washing machine and they can order you a new board. Unplug your washer and switch the board wire for wire.
Feb 03, 2010 | Creda W120VW Front Load Washer
We have a second hand Creda Simplicity W100 washing machine and want to know if it needs to be connected to both the hot and cold water supply or if just the cold can be connected
yes you can just connect the cold water side however you will need to cap off! the hotwater side due to a reverse flow issue when the tub is filling
Jan 17, 2010 | Creda W100FW Front Load Washer
Need instructions on how to convert Simpicity
I don't know if this is the exact same but it is for an Ellis Crib
You can download the instructions at
www.craftedbylittleme.blogspot.com
Click on the link on the right hand side. You have to use picasa if you want to download, which is a free software. Just to view the photos you don't need to download and you can print them if you look at the photos individually.
Oct 11, 2009 | Simplicity for Children Ellis 4 in 1 Sleep...
My washer isn't emptying it keeps filling up and flooding
Pressure swith not cutting off, think this is clogged feed tube to switch.. happens often with this.could be rarely faulty fill valve......Good luck
Sep 29, 2009 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
Where is the filter
The filter is located at the rear`of the washer.
To access it, remove the rear lower panel.
You will see a large black hose, remove hose from bottom of tub, and you will find the plastic filter inside, remove filter and clean.
Refit filter and hose, and test.
If it still does not spin, then you need to check the brushes.
If you require info on how to check and change them, then let me know.
Please rate my fixya solution.
Thanks.
THanks.
Feb 10, 2009 | Creda W100FW Front Load Washer
Creda 1000 simplicity washing machine
try
www.theservicecentre.co.uk
creda and hotpoint website
good luck and rate me
Feb 17, 2008 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer Logo
122 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
paul
paul
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
