Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Water leaks from under the freezer side once or twice a day - otherwise working fine. Any suggestions?
Try pulling out the refrigerator and turn the trap drain to the right until it stops and then pull it straight out toward you. Take the trap and flush it out good with water and then replace the trap. This is the drain from the auto defrost
Posted on Jun 17, 2009
Refrigerator leaks
If it a frost free fridge it should self defrost every 6 to 8 hours all by its self. If you see ice or frost buildup in side the freezer usually back wall harder to notice if the cooling fins are just under the freezer floor but above the fridge ceiling or better picture it as the fridges taint. Sounds like the fridge is having defrost problems and if it every once in awhile does go into defrost or you do it, all that water flows down a hose and out the back around the compressor. Heat from the compressor or other gadgets evaporate the water. If it only defrost a few times a year it is going to overflow the catch basin. Easy to check some times catch basin or drain hose move check back bottom or remove front cover look if bottom catch basin. Main fault is defrost timer stuck in run, location all over in or out, defrost element around cooling fins,defrost thermostat on cooling fins,wiring to / from / joining the last two.
Mar 17, 2017 | KitchenAid KBRP20ERSS Stainless Steel
My maytag fridge msd2732gr is leaking under front left freezer door at least twice a day.
I was having the same problem with my unit, I removed the back cover in the freezer that covers the coils to find the drain clogged where the water is supposed to drip into.
Sep 30, 2011 | Maytag MSD2732GR Side by Side Refrigerator
Excessive water running down inside freezer and forming ice on freezer wall. Austec appliance your repair company in Austin worked on it twice and were unable. To fix it. How can we get it repaired we...
do you have a ice maker on that side? If so the tray is not level or the water inlet is out of alignment. If not you more than likely have a air leak into the freezer at the top front gaskett but this usually shows up as frost.
Aug 08, 2010 | Refrigerators
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
Water on floor under freezer side csx20ea model hotpoint sems like twice a day a puddle the size of a cereal bowl is under front left hand side of my side by side fridg i have a pergo hard wood floor im...
If you have an ice maker, check for a leak in the water line. If no ice maker, there could be a leak in the pan for the defrost water, or the drain hose is out of position. Also, check to see if the water is actually leaking out from the freezer door. That would indicate a clogged drain. The bottom inside the freezer may have water, or ice on it. If so, suspect the clogged drain.
Jan 06, 2010 | Refrigerators
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
GE Profile TPX24...water leaking from under freezer side...water dispenser works fine, but ice maker not working properly. What could be the problem...and how do I fix it?! Thanks
i had the same issue twice. 2 suggestions 1) Remove the front grill at the bottom and you will see a plastic water line. Inspect it to see if it is leaking. Turn on the water dispenser when you are looking at the line. 2) pull out the refrigerator and remove the lower panel. Follow the plastic water lines to a solenoid valve and inspect the lines when you activate the water dispenser. water may leak from where the lines go into the solenoid value. if may be a simple fix like cutting the ends off the lines and reinserting into the solenoid valve.
Jun 14, 2009 | GE Profile TPX24PBDCC Side by Side...
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaks out of freezer once or twice per day
is there water frozen on the frezer floor.if yes your defrost drain is froze over.it only happens a few times a day because happening when its going into defrost,the water melts on the frezer evaporater then should go in the drain.if blocked it then runs on floor.you could turn of your refer for 8 hours or so.or get to the bottom of frezer behind back frezer panel[remove]and use a hair dryer to thaw drain use a weed eater line with a knott on an end to push thru and pull out the other side.the knott would clean any stuff in the drain line.ps watch out for water and electricty.i hope this helps God bless,tom
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Leak
Is there ice build up under the bottom basket in the freezer??
sounds like the defrost drain is frozen up. especially since your cleaning up once or twice a day. simply defrost the drain and flush the drain line with warm water. you will likely have to remove the freezer cover inside the freezer compartment to do this.
if there is no ice build up under the baskets then its likely there is a leak in the water line for your water dispenser line that runs in the door. if thats teh case you will most likely need a service company to fix it for you..
Dec 19, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
152 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
