Have a videoseven display / monitor model s17ps that is going bad. The screen is scrolling and occasionally goes completely white. I need a replacement, either that same model or compatible model.
Saigua
  • 981 Answers
SOURCE: Monitor displays white screen when connected and powered.
Does the OSD settings menu work or (say, contrast) controls work? It could be a control circuit that somehow gets as far as switching the backlight on but can't get the video detection or further (resolution data interchange, etc.) stuff going. There might be a reset jumper for that somewhere in the monitor, or via holding Power for a few seconds, or a Power/brightness-down combo.
Without going to open it up for reset and test connections; there might be a utility (if you can borrow another monitor to get it going) supplied with the monitor to provide settings for it from the PC end! Wacky, but true.
Posted on Feb 23, 2008
tantong
  • 138 Answers
SOURCE: My Videoseven monitor
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burning spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 07, 2008
skotkolr
  • 558 Answers
SOURCE: Samtron 73v white screen
you need to have some one open the flat panel up and check the capacitors on the vga/ inverter card and see if they are domed shaped if so then you have blown capacitors and they are not a difficult fix but pricey as the electronics guys don't come cheap
Posted on Apr 27, 2008
  • 31 Answers
SOURCE: Same problem- SyncMaster goes on/off, bad TV image, needs reset
try to update the monitor driver tehn check the same with the cables from cpu detached if no signal comes for long then the monitor is fine also try to check the monitor on bios screen
Posted on Sep 15, 2009
leighblue31
  • 77 Answers
SOURCE: monitor goes dark after a few seconds
it looks like the video driver needs to be chcked. can you try to go to the bios of your omputer by pressing f2 on boot and let it stay there for 5 minutes? if it still goes to a black screen, its either your video card or lcd thats having a problem. but if it doesnt goes to a black screen in bios, its just the video driver. go then to safe mode by pressing f8 on boot. then uninstall and reinstall the video driver. or run system restore. restore it back to a working date thts by clicking start, then click all programs, go to accessories, go to system tools, click system restore, choose an earlier date and hit next, follow the prompts,wait for the computer to restart and that should work!
Posted on Sep 18, 2009
Screen goes dark
Had this problem on a Philips 170X6 display. When switching on the LCD lighted a few seconds and then went dark. Other displays may have similar problems.
Cause= bad electrolytic capacitors in the power supply. Had to replace 4 x 470 µF/25V and 1 x 125 µF/25V.
(in many cases you will see trace of leakage or a bulged top)
Access is by removing 3 screws on the back and pulling of the front frame (which fits very tight). Then you can lift out the LCD and you will find the power supply on the back of it. Carefull, the mains section can have high voltages.
Sep 21, 2015 | Videoseven V7 R19W11 19 inch Monitor
White screen on hp w2007 LCD monitor.
Troubleshoot an HP LCD Monitor
HP makes a number of liquid crystal display, or LCD, monitors.
LCD monitors create an image by passing light through a liquid crystal solution that either blocks the light or allows it to pass through to a color filter.
LCD monitors are ideal for use with a computer as they present an excellent still image and cannot suffer pixel burn-in like other flat-screen display technologies.
Even quality monitors run into the occasional problem and need some basic troubleshooting before sending them in for service.
Check the power cord to make sure that it is plugged in securely to both the monitor and the outlet. If you are using a surge protector, remove it and plug the power cord directly into an outlet that you know is working.
Detach and reattach both ends of the cable running from your computer to your monitor.
If your HP LCD monitor has more than one connector, use the other one to make sure that the connector isn't the issue.
Remove any switch or extension cable that may be present between the computer and the monitor.
Restart your computer. A fresh start will correct many software issues.
Check the documentation of your video card to make sure that it supports HDCP, or High Bandwidth Digital Content Protection, since the screen may be blank when you are trying to watch high-definition content through a video card that doesn't support it.
Some older HP LCD monitors also do not support HDCP, so check your monitor documentation as well.
Go to your video card manufacturer's website and install the latest drivers for your video card. Instructions for installing the drivers will vary by manufacturer, but they should be listed with the driver software.
Change your resolution to a preset video mode to make sure that you aren't trying to operate the monitor in an unsupported resolution.
Different models of HP LCD monitors support different preset video modes.
All of the preset video modes for your monitor are listed in your monitor's manual.
Resolutions of 1024 x 768 and lower are supported by almost all HP LCD monitors.
Press the "Auto/Select" button on the front of the HP LCD monitor to correct any images that are dark or blurry.
If this does not correct the image, press the "Menu" button on the front of the monitor to bring up the on-screen display menu, where you can use the "+" and "-" buttons to scroll through the options and "Enter" to select the option that you want to change.
Adjust the brightness and contrast as needed by selecting them and using the "+" and "-" keys. Press the "Menu" button to exit the menu.
Press the "Menu" button to enter the menu, scroll to "Image Control" and press "Enter."
From here you can choose the "Auto-Adjustment" option and the HP LCD monitor will automatically adjust the horizontal and vertical positioning to center the screen.
The ability to adjust these settings is available only if you are using VGA inputs.
Contact your retailer or manufacturer for any additional troubleshooting steps for your particular model of HP LCD monitor.
If your monitor still has issues, you may need to send it in to be serviced.
HP Support
http://welcome.hp.com/country/us/en/support.html
Fix a White Screen on an LCD Monitor
When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty.
You will need to troubleshoot these possibilities to determine which problem you have.
If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it.
Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot.
If your computer display does not show on the functioning LCD screen, try rebooting your computer.
If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance.
If your computer display shows normally on the working LCD screen, proceed to Step 2.
Unplug the LCD monitor with the white screen.
Disassemble the rear panel of the monitor with the small screwdriver.
Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor.
Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen.
See the References section for photos of the video cable for assistance.
http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/
Unplug the cable, checking for any debris or blockage.
Reconnect the cable firmly.
Reassemble the LCD screen. Plug it in and connect it to your computer.
If the screen is still white, you have a defective LCD screen.
You will need to replace it or take it to a professional repair service for assistance.
Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1).
After that you connect another working screen and test video.
For this purpose I'm using one of my test LCD screens.
My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image.
After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it's still white.
CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced.
Aug 04, 2013 | HP W2007 20.1 Widescreen Monitor
This monitor gives me a complete blank white screen when plugged in even after checking with multiple computers what part would need fixing or replacing for it to function properly?
check first any broken ribbon wire going to lcd panel or broken screen display. if those are good, the cause of white screen would be bad lcd controller board.
Dec 28, 2012 | Computers & Internet
Hi, I have a Dell 23 in monitor. Everything was working fine but one day we turned it on and it's completely white. The whole screen is just white. Is it there a simple solution?
please remove the vga cable from the back of the monitor, make sure that you don't remove the power cable from the back of your monitor.
If you see the power on self test or any other pattern of colors in the screen, if the screen display remains white or goes black it would mean that the monitor has gone bad.
Hope it helps.
Thanks and Regards
Anand Sachan
Oct 25, 2010 | Computers & Internet
Sep 15, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
My Videoseven Monitor is just displaying a white screen (or sometimes grey) It does not respond to the computer.  I know its not the wires or computer as I have changed the monitor to another one and the...
Thank you,
Mar 06, 2008 | Videoseven V7 E17PS 17" LCD Monitor
White intermittant horizontal lines
Sure it can be fixed, I think some components on the main board needs resolder on their soldered joints. Try this first before thinkig of getting a new one.
Nov 30, 2007 | Videoseven W17PS 17" LCD Monitor
Screen goes blank
Hi jkm007, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 12, 2006 | Videoseven V7 L19PS 19" LCD Monitor
Computers & Internet Logo
133 people viewed this question
Alun Cox
David Payne
David Payne
