Question about 2wire 2700HG-B Router (2700HGB)
Could not find an ATM circuit
I have a 2700HG-B router it was working fine until Monday,now i cant get the internet to work and when i go through diagnostics i come to PVC connection : could not find an ATM circuit. please help
    Sergeant:
    Champion:
  • 306 Answers
Turn the router and the PC off, turn the router on 1st, wait for all the lites to turn on...if you have DSL wait for the DSL lite to be on .....no blinking. then turn PC on.. IF problem still there then its either the router or the NIC that needs replacement.
Posted on Nov 10, 2007
    Problem Solver:
  • 13 Answers
This is an issue of the power supply not delivering enough amps to the router/ gateway, got to AT
Posted on Sep 09, 2010
This can apparently be also caused by router "forgeting" your user name and passward to log onto network.
When I connected directly to the router and reentered the usr/passw for my DSL connection the problem went away.
Posted on Mar 07, 2008
2 Suggested Answers
  • 3 Answers
SOURCE: could not find ATM circuit
This Issue Pertains to your line being connected to a bad DSLAM port in your ISP's "Central Office" I am a computer technician, and have dealt with this issue about six times, two of which were on my lines. there is nothing to troubleshoot, stop power cycling, you are wasting your time, call your isp techs and have them get thier ***** out there to the office and fix your line.
Posted on Sep 07, 2009
I have upgraded from MS windows 8 to 8.1 Now I have lost my internet connection. The router is working fine
Sounds like your WiFi isn't connected. Pop the charms bar out of the right hand side by putting the mouse in the upper right hand corner, and go to settings.look for the WiFi icon, click it, is it connected?
Nov 30, 2013 | 2wire 2700HG-B Router (2700HGB)
When I run diagnostics on 2wire 2701hg-b gateway I get pvc connection could not find an atm circuit
Hi William,
I have this same router from AT&T. First thing you need to do is make sure all phone line devices have filters on them. If that doesn't work, try a different phone jack. It could be the internal wiring on that phone jack that's causing a connection disruption (this happened to me with the jack in my room). If that still doesn't work, then call your ISP's tech support line. They'll check their network status & make sure the servers in your area aren't down for any reason, which could be a strong possibility as the ATM circuit is located at the servers. Otherwise, there could have been a screw-up on their part, which they need to correct on their side. The only way to resolve these latter issues are by calling your ISP.
PVC Connection Could not find an ATM Circut simply means you do not have an internet Connection to your Router/PC
Regards,Suhail
Nov 12, 2011 | 2wire (2701HG-B) Wireless Router
2wire 585 forgot password and need 2 config have no phone number to change password
f you don't know the system password for the twowire it has a factory reset button near the lan ports
* Hold down the reset button on the back for 30+ seconds.
* Upon releasing the reset button, the router resets itself to factory settings.
* Connect a computer to the 2700HG-B and browse to the URL http://192.168.1.254/
* Enter a new password, confirm it and enter a password hint at the bottom of the page, in case you forget the password.
* At this stage you might receive a "Page Not Found" error, but the password appears to be set successfully.
* To continue, manually browse to the url http://192.168.1.254
* Home Page (summary)
* Run System Setup Wizard
* Enter key code 5225 2374 WG62 22AS BJ7P (from http://www.2wire.com/?p=268) to set up manual config
-> Next
Choose TIme Zone -> Next
* Enter ISP set up details
* For most UK ISPs this will be
Connection type = PPPoA
VPI = 0
VCI = 38
ATM Encapsulation = VC-Mux
For Be /O2 users only
VPI = 0
VCI = 101
ATM Encapsulation = LLC
Exit Registration when connected to Internet
If this helps you plese rate and vote
Feb 25, 2010 | 2wire 2700HG-B Router (2700HGB)
Wireless Internet stopped working. Can't reconnect.
If restarting the router and restarting computer did not work (unplug both power cables), then you need to log into the router and check network settings.
To log into router type the router IP on internet explore bar, then enter user id and password.
You find details on how to do this, IP and passwords listed on the owner manual.
If wireless security settings on router are fine, then you can reset router to factory default using the pinhole switch. You will need to enter all your broadband settings to have the router working afterward.
Apr 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Internet conection
ATM means Asynchronous Transfer Mode. it's a protocol used to transfer data. it could be that when you are running the setp cd, ATM mode is selected. and if the connection provided by your ISP is not on ATM mode, it'll provide the message that it can't find it. you can check the type of conenction you need to use from your ISP or you can provide me who is your ISP and the model of your modem so i can check it out for you.
ciao!
Jul 10, 2008 | 2wire 2700HG-B Router (2700HGB)
Use 2700 as router only?
there's a way to make the gateway act as a router only but it's not really recommended since there's a possibility that the connection will not be as stable as it should.
anyways you can try the following steps in making your gateway act as a router (not really a router but just a switch and a wireless access point).
- access the router's web user interface by typing http://192.168.0.1 on your web browser
- then click on the "Advanced Configuration Settings"
- select the "Transparent Bridging" option (note: you must configure your wireless settings first before trying these steps since you might not be able to access the gateway's page anymore once you save the changes)
- set the vpi to 0 and vci to 32 if it asked you for those settings. next to 'ATM PVC Search' select the radio button next to Disable. ensure Bridged LLC is selected next to 'ATM Encapsulation'.
- then save the settings
- connect now the new modem to one of the ethernet ports of the 2700hg-d using an rj-45 or an ethernet cable
hope this'll help you.
Jun 09, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG - B
Log on to the routers interface and look for MTU size. Once you get there, reduce it to 1492. This will help.
- Ranjit
ranjit@supportminds.com
Nov 02, 2007 | 2wire 2700HG-B Router (2700HGB)
Could not find ATM circuit
Nov 01, 2007 | 2wire (1000-400108-001) Router
2wire 2700HG-B Router (2700HGB) Logo
4,104 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
