Question about Intel D845GVSR Motherboard
Slave master settings
Hi, I have an old computer that is badly infected and want to reset I have the original discs etc but a friend put an extra hard drive in and I think I need to reset it so that my original drive is the master. The documentation on the discs say that i must have the original pieces before I completely restore.  My mother board is a Micro star  MS-6178 10.
One jumper says J26, One other says J3, one other say  J4,  other one says JP1, JP2 but only one jumper there.
So could you please tell me which is the one I need to change or isit best to completely take out the other hard drive?
Hope you can help, many thanks
  • Padds Nov 02, 2007
    I will sort it out as soon as I get back from my few days break. I did get it up and running and found Norton had contained most of the problem but it kept coming up with little boxes telling me of each one and there were hundreds of them! I downloaded AVG let it scan and it found 4 more in the programme of Norton! It is a Trojan and it found some sort of backdoor thing. I am a bit of a novice so you will have to bare with me.
    Plus my restore floppy is corrupt it says and the back up copy I made a few years ago is with the bloke that first did my computer, he has left the area. I will keep plodding on and see what I can do when I get back. Thanks for your help, it is appreciated.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
On your original HDD set your jumper to the closest to the IDE ribbon connection and your new HDD set it next to the closest (that will mark your new HDD as a slave). then reset your bios and resume what you were doing.
Posted on Nov 01, 2007
No sound device, just multimedia device after adding a new hard drive and Windows XP reinstall.
Are you booting in from one of 2 hard drives at start-up .. ie. do you have a dual-boot system?
If your sound works fine when using the original hard drive but not when you boot from the slave, then it sounds like a driver problem -in the slave. You'll need to download the sound drivers for XP/Slave.
I can't think of any reason why your computer should beep after you have opened and closed the case. I don't think it is anything to do with the case. It's more likely that there's a bad connection or fault (maybe you have the slave and master on the wrong cable) - or badly fitted RAM.
Count the error beeps - there is a pattern of long and short beeps. You can find a list of their meanings here:
Though having said that, I would hazard a guess that you've got the master/slave configuration wrong. If you have both hard drives on one cable (ide) the MASTER drive should be at the end of the cable.
Remember there's a primary master (c) and a secondary master - your dvd drive. A 2nd hard drive would be set up to be the primary SLAVE. You cannot have 2 'master' drives on the same cable or bus. That would cause an error beep ...
Nov 28, 2013 | Packard Bell iMedia Computers & Internet
How to remove a virus from your PC's hard drive
Make sure you have an updated antivirus program on an uninfected computer (computer "A") Remove the infected hard drive from the case of the infected computer "B") "Make note of the jumper settings of both drives.(master/slave/cable select) This is so that you can put it back when the virus is gone. Set the infected drive as slave or cable select. And the uninfected \ as Master.Connect drive B to the data cable of drive A then Plug in an extra power cable. After the jumpers are changed.Start Computer A. It then should recognize the B drive and automatically run the antivirus program to clean the drive. When the drive has been cleaned, power down both computers. Return the jumpers of both drives back as they were in the beginning as you noted. Put the drives back in their respectve computers. Start both computers, and the virus is gone now.
on Sep 16, 2010 | Computers & Internet
How can I attach a Samsung hard disk HD080HJ/P to a Dell Optiplex 755 Core 2 Duo E4400 PC computer? There seems to be no master/slave settings on the hard drive.
Newer sata drives do not rely on the master/slave settings that old IDE drives used. Remove the old drive from the bad computer and plug it into an available slot in the new computer. Boot the new computer. Under My Computer/Computer the second drive will show up with the next letter available. Alternately you can buy an external hard drive dock that connects via usb and use that to transfer your files.
Dec 01, 2012 | Samsung (HD080HJ/P) 80 GB SATA Hard Drive
How do I install an extra SATA cd/dvd drive in my PC
Hello, I will be the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Peter Symonds.
Read the big label that the manufacture has put on your DVD drive, you need information regarding Master and Slave jumper positions.
You need to set the main DVD drive as Master and the other as a Slave or secondary drive. However some-times this configuration is set in the BIOS/CMOS of your computer system.
Install the drives by removing an available 5.25" plastic drive cover on the front of your PC tower case. Now secure the new DVD drive to the chassis with the included M3 mounting screws.
Use two screws on each side to ensure that the drive is secure.
Insert both the SATA power and Data connections into the drive and the SATA data connector into an available SATA connector on the mainboard.
Once completed power on your computer and enter the BIOS/CMOS by tapping the delete key as soon as your computer powers on.
Your will get to the BIOS/CMOS screen where you need to find the heading for Master and Slave drives. You should see your primary hard drive and both DVD drives.
Enter into the DVD drive settings and set the one to master and other to slave.
Save and exit setup, usually F10. Read options at the bottom of the BIOS/CMOS screen.
It's as easy as that.
Take care!
Jan 30, 2012 | Dell Dimension E520 PC Desktop
I purchased my old computer in 2009 and it came with the Hitachi HD, HDS721010CLA332 (0F10383). That computer has failed and I purchased a new HP Pavilion. Can I take the old Hatachi HD and make it a slave...
Hi there.
Since your hard drive is a SATA drive, there is no such thing as master and slave drive anymore.
All you need to do is plug it into your new computer (assuming there is an extra slot for a hard drive in there). You will need an extra plug from your power supply that will plug into the hard drive as well as a SATA cable that will plug your hard drive into the motherboard.
Another thing you can do is get an external hard drive enclosure and put it in that. Just make sure you get a SATA one, not an IDE one. I hope this helps.
Sep 08, 2011 | Hitachi HDS721010CLA332 Deskstar 7K1000C...
Im just wondering why i might need a slave drive, i have a 80 gig master and a spare 80g drive should i put them both in or does it realy matter
slave drive is very handy in backup files you can store data and other software and drivers. it does matter becouse master drive always has the operating system that the virus and error always happen. hard drive with IDE connector has two jumper setting slave and master. connected to IDE cable. sata disk has no master slave..
Aug 18, 2011 | Computers & Internet
How do I replace a harddrive on VGC-LT32E sony computer, I can see how I add a harddrive but not how to replace the excisting hard drive
Hard drives have jumper settings on them on the back if you can see the original hard drive pull it out by removing screws look at the rear of the drive the jumper settings for the drives are called master, slave, and cable select. If your hard drive is on a cable by itself it is more then likely set as cable select, if it has a hard drive and cd rom etc on one cable the hard drive will be set to master and cd set to slave if you have more then one hard drive on one cable the new one will be master load windows on the drive then you may set the old drive to slave hook it to the cable and restart you could save some of your things on old drive by pulling them to the new drive. This is really complicated for someone who has not done it before but if you follow the rules above you will be successful. If this helps leave feedback if it does'nt you want to consider taking your machine to a proffesional it is a ten minute job to them. Thanks have a nice day hope this helps if not repost and we will help you.
Jan 31, 2010 | Sony VAIO VGC-LT32E 22? All in One Desktop...
I was installing a dvd drive, unhooked main power supply in computer, now when I turn on computer it says it needs a systems reboot disc can you help
The computer can't see the hard drive. IF the hard drive is on the same IDE ribbon as the DVD then you have a jumper problem. You need to look at the old cdrom if there was one and jumper new one the same as old one. (Master, slave or cable select) Also while you were digging around inside your computer did you pull the IDE ribbon to hard drive loose from the drive or the motherboard? Are the power connectors still hooked up? Every hard drive ribbon can have one slave and one master drive. Your hard drive should be the master and the cdrom the slave. Some systems are now set to "cable select" that means that the hard drive ribbon has a master connector and a slave connector and that the device (hard drive or cdrom) becomes a master if connected to one connector or a slave if hooked to the other one. If you go into your bios setup when you turn on the computer you should be able to look an see which of the drives or cdroms is hooked up as master or slave. Some will display this information during bootup posting.
Oct 04, 2009 | Computers & Internet
2nd hard drive on Dell Dimension 8300 ( both ATA)
setup the original harddrive as master and the new one as slave then the drive that comes up as c will be the master and the others will follow suit and when you install the games just change it in the install
Jul 20, 2009 | Western Digital Caviar SE16 WD5000AAKB -...
Which jumper is slave on my disc drive?
Greetings my friend...Put it to cable select mode(CS) so that the cable will automatically set your existing HDD as master and the new one as slave!
Oct 19, 2007 | Computers & Internet
Intel D845GVSR Motherboard Logo
77 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
