Dell Inspiron 6000 Notebook Logo
Posted on Jun 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery light flashes 4times orange then 1green
My battery light is flashing orange (4 times) then green (1 time). The laptop will run on either ac or battery power. When I unplug the laptop, it says I have full power on my battery (ie 4hours) but the light won't stop flashing in this sequence. My dell inspiron 6000 has the battery (I think) light - it has a lightning bolt thingy flashing 4 orange and 1 green, the symbol to the left of itis also flashing orange. I have it on ac power but lights are driving me nuts? Do I need a new battery?
  • lennox_6 Jun 17, 2009
    At least 1 hour
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 04, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4445
Points
We had the same problem. I figured out it was NOT the main battery, but the auxilary battery. The batter life WITH the auxiliary was 68% total, when I removed the 2nd battery the battery life shot back up to 98% AND the flashing orange / red lights were gone (both on the power source and off). I then replaced the auxiliary battery with a spar back up to make SURE that it was not a fluke and with the new backup battery firmly in place the lights still did not flash. Problem solved.
Thx_nb
Level 2:
  • Expert 242 Answers
  • Posted on Jun 17, 2009
Thx_nb
Expert
Level 2:
Answers
242
Questions
0
Helped
505890
Points
748
This means something's wrong with your battery. Usually it means you need a new battery.
How long does the battery last, if you use the laptop without the AC adapter?
  • Thx_nb Jun 18, 2009
    And that's with normal use?
    That's more than I expected.
    What happens when you run only on AC, ie without the battery in the laptop? Do the lights still flash?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4445
Points
I have a same problem, when the AC is connected with or without the battery is normal, when i disconnect and connect the AC power, the power led and the battery led are blinkink, and the power led is pink color.
Flashing orange power light
laptop works ok? battery is charging? you have no problem???? do nothing?????
My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
4helpful
4answers
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
Dell inspiron 1100 wont stay on
Normally the battery light will rapidly flash orange if the battery is defective. It will alternate between orange and green if it is too hot to charge. Or it will either flash orange or be a steady orange if the battery is low or completely discharged. Based on this and the fact that you cannot get it to stay on for more than 7 seconds, I would have to say that you need to recharge the battery by plugging the laptop into an AC outlet. After all, it can't run without the juice.
2answers
BATTERY LIGHT FLASHES ORANGE
hi,
if you have tried both batteries with the same laptop and they are giving you the same error code, then it could very well be a motherboard problem, both the batteries cannot be bad, what you can do is try these batteries on some other compatible laptop model to check if they work fine there. Also try swapping the AC adapter as in both case you might be using the same Ac adapter, try using some other good known AC adapter as well.
Further queries are welcome
If you find my solution helpfull please do rate me
Latitude d505 not charging
If the system runs using the AC adapter, but the battery doesn't hold a charge and the battery indicator LED flashes orange, then replace the battery (A battery with an internal failure may flash 4 times orange then once green and repeat)
The normal lifespan of a PC battery is 300 to 500 recharge/discharge cycles (roughly 12 to 18 months)
25helpful
2answers
The LED sequence indicates a failure in the battery. (Like one cell has low charge) As long as the overall battery output meets the minimum for system operation, the battery will work.
The average lifespan for a Portable battery is about 500 discharge/recharge cycles (1 to 2 years) anything after that is a bonus
Replace the battery, issue will go away
2helpful
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
