Question about Nokia 2300 Cellular Phone
Work for some hours and auto & power off
The set after power on works only for a few hours and then auto powre off what shell i do i have already done flashing
    Scholar:
  • 76 Answers
What you are waiting for there can be two types of problems:-
1. the firmware or S/w gets corrupted or you need upgradation or reformating and installing of the mobile o.s again or also you can try by resetting your phone to factory settings.
But these type of problem is very rare.
2. the most possible cause is the failure of your battery. I have the same problem and when i replaced the battery the phone is working properly
Posted on Jun 17, 2009
  • 73 Answers
Try to change the battery
Intermittently my 2009 kia optima will not start
I'm pretty sure that the charging system was checked by now & they should have checked it for an electrical short & the ignition system should have been checked. It may be an electrical short in the ignition system, bad/ erratic starter or relay. I advise u to get in touch w the dealer & inform them the problem is still happening & see what they have to say, or get a auto tech to check it & get a warrantee w the work. The dealer should be standing behind their work already. Good Luck. CALL BACK THAT DEALER, U PAID THEM TO FIX THIS PROBLEM ALREADY. Ive dealt w consumers for 21 years & auto repair.
Mar 25, 2017 | Kia Optima Cars & Trucks
ZILLA POWER CENTER
The yellow outlets are controlled for 12 hours, and you can determine when those hours occur when setting current time.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 21, 2010 | Coralife Zilla Aqualight Power Center
Lenovo Y410 auto shutdown
go to system properties & disabled system auto restart
Aug 30, 2009 | Lenovo 3000 Y410 Laptop
I need to change the timing belt and a few more...
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.png Removal & Installation
  1. Disconnect the negative battery cable.
  2. Rotate the auto tensioner clockwise to release tension, then remove the drive belt.
To install:
  1. Install drive belt (A). Route the belt over the components in the following order: Crankshaft pulley → A/C pulley → idler pulley → generator pulley → water pump pulley → P/S pump pulley → tensioner pulley.
  2. Rotate auto tensioner arm in the counter-clockwise moving auto tensioner pulley bolt with wrench.
  3. After putting belt on auto tensioner pulley, release the auto tensioner pulley slowly.
    93581gy2.gif Accessory serpentine belt routing—3.5L engine
    42050_sedo_g0020.gif Accessory serpentine belt (A) routing—3.8L engine
Aug 20, 2009 | 2003 Kia Sedona
JVC 36
Hi Dave: "My JVC 36" TV will not power on and has a blinking power light."
That means that the protection circuit has started because a fault had been detected.
If this happened after a power surge it is likely a faulty PSU board.
Try first leaving the set unplugged from power outlet for few hours, this will drain power, reset the protector, and fix problem related to accumulation of electrostatic charges on PSU power capacitors.
If unplugging does not work, that means that there is an internal fault.
If this happened after a power problem of some kind, that means that probably one of the capacitors on powr board had blown, and must be replaced.
The TV must be tested by a technician to find the fault.
Jan 05, 2009 | JVC AV-36D303 36" TV
Why does my KAC-8404 cut off at high volume bass?
amp 101
1/0 wire to the amp or the amps will loose power
check the connections mainly the negative
wiggle the wires see if you get a cut out or not
a cap will help you give constant power to the amp and not allow them to drain on long bass notes
hope this helps
Dec 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
My Amana Model NDG5800AWW dryer has ceased to dry clothes dependably. The Only setting that still sort of works is HIGH timed drying, and this heats up to what used to be the "delicate" setting....
if you are using the auto dry setting and the dryer is still running after 5 hours you either have a timer issue or a thermostat problem.
The timer is driven by a motor, if the timer motor is bad the timer wont time out.
in the auto dry cycle the thermostat has to cycle off and on which then sends power to the timer again advancing the timer.
set the timer in a timed dry cycle for say ten minutes, if the timer advances and turns off then you know the timer works. if it doesnt advance you have a timer motor issue,
if the problem is the auto cycle, you could replace the thermostat, about $20 american. however a clock timer would be cheaper.
Based on how old is your machine and do you want to stick a timer in it after already paying the service man is up to you.
A basic bath towel load should be dry in about 50 minutes, this varies on how good your seals are and how long a vent you are running, if the dryer vent was plugged you already have shortened the life of your heating element.
Sep 22, 2008 | Amana Dryers
Honeywell HZ-705.....HELP!!!!
Should have oil in it. I don't think you can refill it. If it has leaked out, it's probably no good. Anyway, here are the instructions.
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Aug 17, 2008 | Heating & Cooling
Nokia 2300 Cellular Phone Logo
53 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
