Question about Troy MIG100 90-Amp. Wire Feed Welder
Cigwed 195 mig welder diagrams
I am looking for an exploded diagam of my CIGWELD 195 mig welder wire feeder motor ( 24 VDC ), can ot find a manufacturer name on it anywhere either.any asistance would be great
CarlGehrke
  • 169 Answers
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Posted on Dec 03, 2008
  • 3 Answers
SOURCE: mig welder tripping power supply
the breaker could be bad. try to change the breaker
Posted on Jan 16, 2009
luxur4
  • 92 Answers
SOURCE: lincoln mig welder
Check the earth clamp, make sure all the cables or in good condition and secured, if the unit is three phase, get an electrition the ensure all the phased are functioning. test the fuses with a meter, get back to me if all is OK
Posted on Jan 23, 2009
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
  • 4 Answers
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Posted on Apr 08, 2009
I have a cigweld wire wasp gasless mig I have opened it up to make it positive ground but all I see two transformers and no terinals to swap over .how can I do it . Can anyone help ???
the change over is outside on the face of the machine
a == terminal and a + terminal on which to attach the ground /earth strap
Oct 25, 2016 | Welding Tools
Ihave a cigweld wire wasp gasless mig welder it gives me a lot of spatter how do you change it to positve earth?
change the position of the earth strap at the front of the unit
there should be two terminals one marked - and one +
normal gas welding is -, gas less welding is +
How to reverse polarity on transmig 195 for gasless wire
just take the lead for the wire and attach it to the ground terminal and attach the ground wire to the + terminal
there will be diagrams in your user manual and if you don't have a manual then go google and type in--- user manual for mig welder 195 model( model not included in your question)--- and there will be a psd version to down load
Dec 30, 2015 | Welding Tools
Wire feed problem with snap-on mig welder
There are two wires comming from the circuit board to the wire feed motor. You can try running the motor directly from a 12v battery or two for 24 volts. You might want to look at the name plate on the motor to check the normal DC current it draws. If you do not have an ammeter, you could use a fuse close to or just under the normal current. If it runs and draws too much current, then you know you have motor problems.
If it runs well and draws a fraction of normal current,you know the motor is good. Before you condem the circuit board, check that it is receiving the correct input voltage. If the welder is dual voltage,then somebodys mistake making voltage change could send 240 v to the board that is meant to receive 120v.
Hope this helps, Robert
Aug 21, 2012 | Hobart Handler 140 Mig Welder
Cigweld wire wasp mig welder wire feeder worn need replacement also operation manual and plastic feeder cable holder is broken need new one located in Mandurah W.A.
http://www.thermadyne.com/IM_Uploads/DocLib_1498_43-59.PDF
http://www.thermadyne.com/IM_Uploads/DocLib_1673_CIGWEL56.PDF
http://www.thermadyne.com/IM_Uploads/DocLib_4168_0-4949.pdf
http://www.thermadyne.com/IM_Uploads/DocLib_4143_0-5072.pdf
If your gun end is a Tweco, those are pretty much standard and readily available from welding supply houses. If the retainer for holding the liner is broken you would get that through Thermadyne.
Jan 08, 2012 | Welding Tools
Can the lincoln 305 d 1727-3 mig weld
If it has a setting for constant volatge, that is for wire feeders, flux cored or mig. Constant current is for stick welding. Some wire feeders have a switch to use them with a constant current machine, but that doesnt work very well, and , in my opinion, is hard on the computer in the feeder.
It looks like the ones we use in the field with a ln-25 wire feeder and flux cored wire. for mig you will also need a bottle of sheilding gas.
Jan 28, 2011 | Lincoln Electric Ranger 305D K1727-2...
How do you hook a miller s-22p8 wire feeder to a lincoln ranger 10,000 plus engine driven welder?
you can't, the S-22P8 it's not a volt sensing wire feeder, it requires 24V or 115 with an adapter. FOr CV machines only.
Dec 08, 2010 | Miller Electric Mfg Co 903376 Deltaweld...
The wire feed on my welder will not work.
Maybe you can get lucky like I did . Some times the acr volt selector switch gets corrosion in it and wont let the circuit board know to send power to the wire feed motor. You can cycle this arc volt. switch in my case it is the a,b,c,d,e, switch back and fourth a few times and this will brake the corrosion and your wire might feed again as mine did . This corrosion build up happens from not using and or sollecting the switch much usually on a welder at hm that gets very little use. it is common good luck .
Jul 24, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Wirefeed slips, i have the correct size o.9mm flux cored wire, I think there may be too much play in the driveshaft/wheel (single drive wheel only) If so can I get another wire feed for it..?? (gassless...
It sounds like the feed spool is too loose or worn out.There should be a tension adjustment. What wire size are you using? On those off brands they usually use .035. and make sure the spool is not dragging. The wire spool also has a tensioner, or should have, in the center. Good luck.
Jun 07, 2009 | Welding Tools
Troy MIG100 90-Amp. Wire Feed Welder Logo
94 people viewed this question
Top Troy Welding Tools Experts
Bill Boyd
Marvin
Marvin
Are you a Troy Welding Tool Expert? Answer questions, earn points and help others
