Question about Fujitsu Siemens Computers & Internet
Memory upgrade for laptop - not sure what to unscrew
Fujitisu Siemens AMILO Li 1705 - I am not sure where to find access to ugrade memory slot underneath. Can you help me please.
  • 21 Answers
Most laptops are this way, but yours may be a special case.
Most have two ports one is underneath a removable panel on the bottom of the computer, and the other is under neath the keyboard. To remove, look to see if you can remove the area between the keyboard and screen, if not find a screw or screws on the bottom of the keyboard labeled "k", once those are off the keyboard is loose and is just lifted off.
Always remember to not prey to hard,if it is going to come off it will come off without struggle, and have your battery and power disconnected first, and the computer is off...
Posted on Jun 17, 2009
Hello I have laptop Fujitsu-Siemens Amilo Li 1705 It's no display on screen With 5 beeps 1-3-1 I am replace ram but no worked
If you remove the hdd, ram and dvd drive. Power up and then shut down. Place one ram chip in the slot, (ensure correct type and value). Is the error still there? If it is possible GPU issue.
Jan 05, 2016 | Computers & Internet
Fujitsu siemens amilo li 1705 LAPTOP FAN TURNS LED LIGHTS BUT HAVE NO DISPLAY
fan keeps turning or turns off right away?
have u tried taking memory out and putting back in?
if so could be lcd or processor
Nov 25, 2009 | Dishwashers
How to change and upgrade the memory Fujitsu-Siemens Amilo Pro Fujitsu-Siemens Amilo Pro V2010
on the bottom of the laptop is a square plate with 1 or 2 screws, when the laptop is off, remove those screws and you should see your laptop memory, gently expand the two thin metal clips on either side of the memory and it should pop up at an angle, gently remove it and replace with a larger capacty memory module.
Nov 18, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
I have a fujitsu siemens amilo li 1705. when i switch the laptop on the fan kicks in and the lights light up thats it no display at all. a friend of mine looked at it and he removed the hard drive and ram...
Maybe the HDD is having partial contact with the SATA IDE so removing it and fixing it back have solve the problem. Am not sure that it is memory....
Oct 24, 2009 | Dell Latitude C640 Notebook
Fails to start and gives odd beep code.
Hi there.
For some strange reason the beep code you describe is not listed anywhere.
But, you can try this >>>>>
Get a can of compressed air and give short blasts through the air vents and the CPU fan (located under the laptop).
If you cannot get a can of air blow through the vents as hard as you can to get the dust out.
Take the battery out of the laptop, open the ram cover and take out the system memory, clean the contacts and slots with a soft, clean, dry paintbrush, put just one memory module back in the slot and plug the AC jack in (not the battery) and try to power up.
Please post back with the results.
Good luck and thanks for choosing FixYa!!
May 27, 2009 | Fujitsu Siemens Computers & Internet
Fujitsu-Siemens Amilo Pro V2040 Laptop memory locations?
Sorry, This laptop only supports one memory card slot upto 1.7GB
Mar 15, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Please help me what site can i download free for my laptop fs amilo li 1705 audio driver. linoJ
To download the driver you need to follow instructions on website below.
Select your model and proceed to driver download:
Downloads - Support - Fujitsu Siemens Computers
Mar 04, 2009 | Fujitsu AMILO PC Laptops
Laptop memory
hmmm..ok...try them one at a time, and make certain that the laptop can id each of them. if that works, swap them in the sockets..if that does not work, then one of your sockets is unhappy.
also, use F2 when loading up, and see if memory is present in system setup screen..be careful in there, of course, since it's the nerve center of that whole computer.
Apr 27, 2008 | Fujitsu AMILO PC Laptops
Upgrading memory
I have found a link for you from where you can download the mannual for the notebook you are using. This mannual explains that how you can replace the memory of the notebook.
Open link
http://www.fujitsu-siemens.com/support/manuals.html
Under "Select Product" - Select Notebook - Amillo Pro - Amillo Pro V2xxx - Amillo Prov 2000
Download and open
Basic informations on mainboard Technical Mannual
You will find the details in that.
I hope that this resolves your issue.
Sammy
Nov 28, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
220 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
