Question about Kenmore Washing Machines
The basket does not move at all on my Kenmore 70 series washer
I had to replace the motor coupling in my Kenmore 70 series washer. In doing so I mistakenly dropped the transmission. After reading I was able to get the brake to go up and get the transmission back in, but know the basket will not spin at all. I was able to spin the basket manually before I took it apart. Thanks for any help
  • 15,935 Answers
It appears your gear box has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
WAsher BROKE!
lift the lid up and down,if you don't hear any clicking the lid switch broke,if that's not it check the motor coupling,take the two clips off that hold the pump in place,remove the two screws and the two clips that hold the motor in place and the coupling is on the back of the motor,if the washer is dead it's the lid switch,if it makes a grinding noise but doesn't move then it could be the coupling,let me know how you make out
Jul 17, 2010 | Kenmore 22422 Top Load Washer
Kenmore 70 series. It won't agitate, drain, or
Does it make motor noise?
Check for belt issue if there is a motor noise and no spin.
Feb 14, 2010 | Kenmore 22422 Top Load Washer
My washer does not spin or move during wash cycle the moter runs but nothing is moving.
Hi, this motor has faulty windings, causing it to lock up and not rotate the drum/basket. replace this motor asap if possible.
May 29, 2009 | Kenmore Washing Machines
Kenmore 110 Heavy Duty 70 Series Washing Machine won't spin
Can you move the basket by hand...if so you need a basket drive. If not you have a bad clutch or gear case
Jun 07, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Apr 28, 2009 | Kenmore 23822 Top Load Washer
Kenmore 70 series top loader washer machine smells like its burni
you had the clutch coupling replaced sometimes i have noticed that the smell will last a few loads but no more than that
Apr 22, 2009 | Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 Series
check the balance ring on the top of the basket it has either came loose from the basket rim or the fluid inside is not there
might need a new one
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series Washer Spin Cycle Only issue.
It sounds like one of two things 1,A worn clutch .or 2.motor coupler is about gone,
May 20, 2008 | Kenmore 24032\24036 Top Load Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
53 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
