Question about Bulova Watch
Had a new battery fitted to my baskerville radio controlled watch now it is 50min fast and wont catch up wit itself please help
Watch wont reset itself . a new battery has been installed and it still won't set it self any help would be greatly appreciated
I don't know what the problem is but the most common problem is a poor reception area. Yep, just like your tv used to have problems picking up that distant signal, so can your watch. The solution is the same for both problems. Get your watch into a better reception area. The signal is a relatively weak AM radio signal coming from Colorado Springs, Colorado. Find the least obstructed spot you can to place your watch, for example, if you live in Seattle, place the watch in a east facing window that doesn't have a building or mountain or some obstruction the radio waves will have trouble with and turm on the function in your watch that searches for the signal or if you don't know how to do that, leave it in the window over night. Other things like cloud cover and meteorlogical events can also affect the signal strength.
Alas, you may also have a watch problem for which I have no idea. Good luck, Michael, Watchmaker to the Stars!
Mar 17, 2011 | La Crosse Technology E. Howard Ambassador...
I have a TCM radio controlled mans watch , I have replaced the battery now I cant put the watch at the right time can you help please
Sep 13, 2010 | Watches
I love my E. Howard radio controlled watch. I recently had the battery replaced by a local jewelry shop but it no longer keeps accurate time!It is about 55 minutes fast and remains that way. What do I do...
mcdevito75 here, Return to the shop that changed the battery for adjustments, possibly a new battery or the factory recommended type battery.
Jul 22, 2010 | Watches
I have a Carne & Viceroy Radio Controlled Watch reset time
I went to How To Mend It Site and I fixed the watch in ten minutes and it was free I expected fast response from you because of the charge.
Dec 18, 2009 | Watches
The digital display shows the correct time but the hands do not.
hi there when you replace batteries in wave ceptors all hands have to be set to the home position (straight up at 12 oclock), as the instructions vary wildly from watch to watch you will have to download the manual from www.casio.co.uk you will need to put in the module number (found on the back plate of the watch), this will be in PDF format, you can download adobe reader for free from www.adobe.com to read PDF files. good luck
Aug 20, 2009 | Casio WVA105HDA Wave Ceptor watch
G force radio controlled watch instructions Need instructions to reset watch after battery installation Watch produced by Aroa HK Ltd. Imported by AROA marketing USA
I have an ehoward&co radio controlled wrist watch and I'm having difficulty in setting the correct time on the dial. can you help?
Jul 24, 2009 | Bulova Watch
Crane and Viceroy ladies RC watch
Hi, Klik and Crane & Viceroy are excellent and robust watches, but due to the radio control batteries need to be changed more often than ordinary watches. Instructions for resetting the time on a Klik or Crane & Viceroy watch. With the watch face upwards and the buttons on the right assume the buttons to be; top button - "A", middle button "B" For setting the watch to GMT all hands need to point to 12 oclock exactly. To achieve this press Button A until the hands start spinning. Stop the spinning when the time reaches a couple of minutes before 12 oclock by repressing A. Inch the time forward by repressing Button A until all hands are at 12 oclock.(EXACTLY). Press Button B within 10 seconds and the time will advance 1 hour and stop. The radio signal will be picked up automatically and time will set itself in a few minutes. Notes: If you have radio dead spots avoid these when resetting the watch and do it away from magnetic or large metal objects. i.e. trays etc. If you are refitting a new battery and have a battery that isn't quite dead, do the advancement of time with the old battery and fit the new one near to 12 oclock to get the best life out of the new battery. If for any reason you want the watch to be in radio mode but read a time other than GMT ( no adjustment is needed for BST ), then instead of stopping the watch at 12 oclock stop it at the time in relation to 12 oclock. i.e. if you wanted the watch to read 30 minutes fast then stop the watch at 12.30. if you want any other info my email is; Charles@adept.fsbusiness.co.uk
Jul 15, 2008 | Watches
Klik r c watch.
problem solved.
regards.
Matt.
Apr 17, 2008 | Watches
Klik radio controlled watch
First, you need to set the hands at midnight. Press the upper button for 3 secs and let go. The hands will start to advance. Watch them, and when you are almost at the position of 00:00:00, press the upper button again briefly and the hands will stop. Then pulse the upper button to finish advancing the second hand to a perfect 00:00:00. Within 10 seconds, press the middle, knurled, button briefly (if you don’t, the watch will just to back to where it was). When you have done this, the watch will start to run (albeit at the wrong time).
Now you need to tell it to set itself from the time signal. Press the upper button and the lowest one *at the same time* for 3 secs and let go. The watch will acknowledge your request by moving the second hand (only) to 12. Leave the watch somewhere it is likely to get good radio reception. In a few minutes, you will see its hands start to move to the correct time, and they will eventually get there and your watch will be working again.
Nov 10, 2007 | Watches
Bulova Watch Logo
32 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
