Question about Pinnacle Studio Version 12 for PC
Cant view video when editing and when i render, export error
"During editing with pinnacle 12 I can t view my video through the player, and when i want to render my video, export error pops up"
    President:
  • 828 Answers
When you have that problem to view your video, render your video format properly like example using an extension of avi or mpeg...
Posted on Jun 17, 2009
What does ng studio has stopped working mean?
It's a program error. It basically means that the program has ceased to function properly. It could be that when you try an export a certain type of file it causes a problem with your system and so it crashes. You could try exporting in a different format. If the problem persist there are two options. One is to contact Pinnacle. Sometimes they have an update that corrects the problem. The other alterative is to re-install the software. Sometimes when you get a crash the software can become corrupted and so needs re-installing.
As with all video editing software save your work often. As crashes are common place to most software of these types.
Jun 03, 2015 | Pinnacle Studio 17 Plus - Windows
I am getting the Export failure (render error) 0/3518@00:00:00 just trying to export my movie on pinnacle 14. can you help?
I had this error too. I homed in on the error by putting markers along the timeline (using the M key) and then trying to render between different markers (e.g. between begining and 01 works, but beginning and 02 fails, therefore issue is between 01 and 02). I eventually found the problem was having a stabilise effect combined with a cross fade. Removing the stabilise effect fixed it. It's annoying that the error message (at frame 0) was not where the problem was. Note that copying and pasting the entire timeline didn't work for me. Good luck with this
Mar 06, 2011 | Pinnacle Studio Ultimate 14 for PC
Export:error:real time c:\users\owner\appdata\local\microsfolder\render\my movie 848e009f\alternate\render\my movie 848e009f\dvd\studiosequence\temp' Help - what does this mean? What should I do?
Hi and Welcome,
If you are experiencing Export Errors using Studio, the following FAQ should help:
1. UPDATE TO THE LATEST PATCH:
Click here for the latest Studio 12 patch
There is no patch available at this time for Studio 14
2. ENSURE BACKGROUND RENDERING COMPLETES:
Allow the green bars that appear over clips that have had filters, transitions or other effects added to complete before going to the Make Movie stage.
3. ALWAYS REINCODE ENTIRE MOVIE
If after installing the latest version of Studio, the Export Error persists and you are attempting to create a DVD, then in Studio click on the Setup pull-down menu and select Make Disc. On the top portion of the Make Disc tab make sure there is a check in the box for the setting "Always re-encode entire movie", then click the OK button. Create the DVD again.
4. DELETE AUXILIARY FILES
Delete the auxiliary files before rendering. To do this, go to File >> Delete Auxiliary Files. This will bring up a window to chose which auxiliary files will be deleted. Select the option to delete the files for the current project. Once this is done, try to output the project.
Oct 12, 2010 | Pinnacle Studio Ultimate 12 for PC
On Pinnacle Studio 12 plus, during the 'Make Movie', some of my still photos go black for several seconds and then reappear in time for the transition or just before the transition. This is then burnt like...
Hi and Welcome,
Click on set up>video and audio preferences>unchecked background rendering>click on "used this codec for background rendering>click and choose MPEG2 for best output to disc. Now click on project preferences>click on delete button and then choose delete auxiliary files for all project and then click okay.
Setup again video and audio preferences enable full resolution preview and click okay.
Another is,
click on the completed project in the timeline, go up to "Edit," click on "select all" in the dropdown menu, then RIGHT click anywhere in the now-highlighted project and select "Copy."
Now go back up to "file" and click on "New Project." Your current timeline will close (don't worry. It's saved,) and a new blank timeline will open. Left click anywhere in the new timeline, then right click and select "paste."
After a terrifying period when you think nothing is happening, your entire project will suddenly appear in the new timeline.
Save it with a new name, then try rendering again.
Regards,
Oct 09, 2010 | Pinnacle Studio Ultimate 12 for PC
I have pinnacle studio 12 plus when i am publishing the movie it gives a export failure rendor error so i took out all the transitions and then only published half. I checked off the background thing...
Hi
In pinnacle studio as the movie is being rendered, the cursor moves along with it, this way you can find out at what point in the rendering process, the program stopped.
when you get the Pinnacle 14 Export Error; Real Time at some frame, then you know that, that frame may be damaged, so cut a few frames before and after where the cursor stopped, and try again.
if the rendering process stops a few times during the compilation, keep cutting those pieces and try again.
i hope that helps
Thanks
Jason
Az Audio Visual Services
Video Conversion Service - Free Shipping North America Wide
http://www.azaudiovisualservices.com
Aug 17, 2010 | Pinnacle Studio Plus 12 for PC
My pinnacle 12 project opens as an empty project in pinnacle 14
Welcome to Fixyah,
Suggest for that if ever that the project wont open to your Studio 14 go back to your Studio 12 and then render it as File and used either AVI or MPEG then after that import that to your Stduio 14 the re edit the video again,.
Regards,
Joey
Dec 14, 2009 | Pinnacle Studio Ultimate 14 for PC
Black Screen on Pinnacle Studio 12 when i preview a transition ?
I found with pinnacle 12 if you turn of the hardware acceleration and turn off the full-res preview,in video and audio preferences it speeds up transitions and text effects tremendously
Aug 14, 2009 | Pinnacle Studio Ultimate 12 for PC
Make movie keeps timing out, render error
I have also been running into an MPEGENCODER.DLL error about 1/2 way through my 20 minute movie. I am able to Make Movie with a 6 minute version, but hitting this error time and time again. I have removed Virus protection and all unessential system tray loads; defragged drive; downloaded newest Windows drivers; downloaded newest NVIDIA drivers; running Win XP Pro SP3, Intel 3GHZ, 1GB RAM, 76GB/10K spin drive.
Jul 01, 2009 | Pinnacle Studio Plus 12 for PC
Editing and burning a dvd pinnacle ... dvd stops playing
Render then BURN AVI Save to the computer. View the file. If AVI is clean burn DVD if not
Redo. Add more RAM in your computer & Apply Higher Video Cards
Sep 27, 2008 | JVC TH-A25 System
I CANNOT BURN MOVIE TO A DVD
I have had similar messages with Pinnacle 9 (dives you mad :() The solution is to download the latest upgrade version from Pinnacle's website. Pinnacle 11 seems to be bug free.
Jun 30, 2008 | Pinnacle Studio AV/DV version 8...
Pinnacle Studio Version 12 for PC  Logo
884 people viewed this question
Top Pinnacle Computers & Internet Experts
Alun Cox
 Ian Kayhan
Ian Kayhan
Josh Levin
Josh Levin
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
