Question about Hitachi Televison & Video
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Unable to record to VCR from Alba LCD TV(LCDW16HDF with integral digital tuner.TV has one scart socket.It offers Digital and EXT-1 options.In EXT-1,with scart lead to AV1 Can bring up VCR menu.Can play back tape recorded elsewhere.Have tried using AV1 and AV2 sockets on VCR,VCR set to AV1 or AV2,different scart cables,second model of the TV,nothing seems to get signal from TV to VCR.
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Posted on Jun 19, 2009
How do i hookup a sanyo vhr h607 to my television
Unless the VCR has a digital tuner the only way to record off the TV will be to connect it by a scart socket and cable. However to record you would have to watch the TV show you are recording. An alternative is to get a set top box, which are fairly cheap and connect that to the VCR. Some VCR's have two scart sockets one for the TV and a spare one. You can connect the box via the spare one. When setting the recording you will have to select AV2. If the VCR has only one scart socket you might need a scart switching box.
Oct 17, 2014 | Sanyo VHR-H607 VHS VCR
Unable to pickup digital tv signals even with amplified digital aerial
You may not have a digital tuner in the tv / vcr. There are digital tuners available that solve the problem. They connect to the digital antenna and then to the tv through A/V cables or thru a coax antenna input to the tv.
Jan 05, 2014 | Alba Televison & Video
Can't tune Alba 7395 VCR into a Goodmans GDB12XIT Freeview box
Has the box got a scart socket? If it has connect the VCR to that via a scart lead. If the alba has two scart sockets then use the second one. When recording set the channel as AV1 or AV2.
If you don't have enough scart sockets to connect your TV, VCR and Box, then get one of these Scart Switching Box from places such as Amazon or Argos.
Jan 14, 2013 | Televison & Video
Recording on vrdvd4005
Dear Diane
This problem is possible due to to aera going over to digital transmisstions
you will need to have a tv with digital tuner built in , if this so connect a scrat lead from your tv to to the scart socket on you dvd recorder , then with the remote control for the dvd select the scart in put this button maybe call input selector or source. in this condition you will only be able to record the progam that your are watching. if you tv does not have a digital tuner fitted you will need to obtain a digital box. If you purshase one with two scarts sockets then one can be connected to the dvd and one to the tv again only the programe being watcch can be recorded> two digital boxes will be required if a different programme than the one watched is requird to record. Hope this will Help Regards Derrick
Dec 14, 2011 | Sansui VRDVD4005 DVD Player/VCR
My VCR/DVD, freeview box and non digital tv will show prerecorded video and DVD but will not record (or if it has it will not display). Could it be that the set up is not wired up correctly? The freeview...
Unless the Freeview box has two tuners then your going to have problems anyway when you want to record something and watch the non-digital TV at the same time. The solution is simple get another Freeview box (they are around £10 at the moment on E-Buyer.Com) get a box like this:
grubhead_17.jpg Available on Amazon (Scart switching box). This plugs into the TV or you can connect via one of the freeview boxes. Whatever works best.
The VCR has the other Freeview box connected to the second scart. (select AV2 when setting the channel to record and set the box to the channel you want to record) the first scart from the VCR plugs into the above box. When you want to watch press the switch.
By the way if the VCR has PDC on it set it to off, as it no longer works with digital.
Aug 21, 2011 | Televison & Video
My vcr recorded my shows before i switched to a digital adapter now i cant get it to record anything ive tried everything
If the digital adaptor is connected to your TV, then the VCR will not get any signals to record. The VCR will also have to be converted, by adding another digital box, unless the first box has two digital tuners! You can connect another box if the VCR has two scart sockets, the second box connected to the other scart socket. To record after connection, leave the box on, set to the channel you want to record, and set the timer on the video. However when selecting the channel to record make certain that you select the scart socket with the box connected to it. Also make certain (if the VCR has it) PDC is set to OFF as it no longer works.
This way you can record shows while watching anothe channel.
Jul 16, 2011 | RCA VR525 VCR
I live in the United Kingdom and we are in the process, area by area, of converting our TVs from analogue to digital. My area was converted to digital in May. Since when my VCR will not function - it...
If the video does not have a freeview tuner it will not be able to record. There is a solution! All you need to do is get a freeview box, Argos have an Alba model for around £18 at the moment, Connect it via a scart to your video, if it has to scart connectors use the second one, often marked AV2. Then when you want to record, turn the box on to the channel you want to record, set the record timer, but change the channel to AV2 for the recording. That should then record the station, while you watch the other channels. If the VCR has only one scart, you can get a scart switching box, as shown below, from places such as Amazon.
Jun 21, 2011 | Televison & Video
I have an Alba 32880hdf freeview tv. I cannot record freeview programmes to my panasonic NV-FJ 780 vcr which has 2 scart sockets. I have no problem recording the teresteral channels. Can you help pls
Hi Victor,
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | Televison & Video
Connect VCR without tuner to record from television
If it has a scart, you can get a scart lead to connect it to your TV. You would need to set the VCR to the Scart socket, IE: AV1 etc.. to record. You wouldn't be able to change channel on the TV, to watch another channel while recording though. If you had a set-top box, you could connect that up to the scart of the video then record, while you watched another channel on your TV.
Feb 06, 2010 | Televison & Video
How do i set up atv without inbuilt digital a seperate digital box and a video recorder?the tv digital tuner and video all have scart leads.Should the aerial cable go to the video or digital box?
Aerial to digi box first then video then tv (not strictly necessary)
Depending on what you want to do with the vcr and the digi minimum scart connection is
digi to video - video to tv
Nov 08, 2009 | Computers & Internet
Televison & Video Logo
353 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
