Question about Tricity Bendix WDR1240W Front Load Washer / Dryer
Tricity Bendix WDR1240W Condenser dryer problem
The dryer does not heat the load in the drum although the top of the machine gets really hot this happens in both the low and high heat settings. the drum turns ok.
  • jwren Dec 05, 2007
    Thanks for all your help, my dryer is now working. there was a piece of the unit sealant wrapped round the fan bendix. Jwren
  • 146 Answers
Check the fan that is supposed to blow the hot air into the drum. It may be seized or jammed. It should be situated on the top of the outer drum. You will need to remove the top cover from the machine and identify the blower fan.
Posted on Nov 01, 2007
  • Fernando Carlos
    Fernando Carlos Nov 03, 2007
    Did you check if the fan is running? Let me know what you found. When the machine is in dry mode, test if the fan motor is getting full voltage.
  • Hardip Randhawa Feb 17, 2013
    Hi Fernando, i have this machine,the clothes are hot but comming out damp, any ideas please.
Continues to blow the high temp stat. I clean the blower and replaced the venting. I also replaced the heating coil the dryer heats up for a load and then it stopss heating. I test the high temp stat
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Feb 17, 2015 | Dryers
Frigidaire gleq442ces0
I had this same problem 3 weeks ago, and here is what I found.
The dryer was so clogged with lint it could not dry the clothes. I had to take the whole machine apart and clean all the lint out. I found the felt around the drum was worn out, and that was allowing the lint to go everywhere it shouldn't. With the felt replaced and the lint gone, it worked well.
Be blessed.
Jun 23, 2013 | Dryers
Cmd146 dryer heating top chamber but not in drum
It sounds as though the fan motor is faulty, usually these motors distribute the heat from the heater box into the drum. Because the heater box is getting hot I doubt if the fault is the thermostat so it may well be the motor or associated wiring
Mar 29, 2017 | Candy CN146 Front Load Washer
An average load in the dryer is taking about 90 minutes to dry, which I think is way too long. I've check the vent and it is clear and air flowing through. Although there is some warmth to the... is an attached layout of your machine.
Usually with your indications it is something with the blower fan. So hot ar is not sent from the heating elecment to the drum. BUT before you start ordering parts, check the simple things first. Check to make sure that the dryer vent to open from the machine to the outside. That would also restrict air flow and cause your indications.
Jun 20, 2011 | Estate EED4400WQ Dryer
Dryer taking to long to dry
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
Ge profile dryer drum turns but therte is no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Oct 27, 2010 | GE Dryers
Dryer wont heat up the elemnt tested good
Make sure BOTH hot legs of your 220 are active. Sometimes, one half of your circuit breaker will trip. When this happens, you will have 120 volts to your drum motor, but an open circuit to the heating coils. Just re-set your breaker by cycling it off and on again. Otherwise, check for continuity of the thermal switch (in line to coils).
Oct 30, 2009 | Whirlpool LTE5243D Top Load Stacked...
Fridgidaire GLET1041AS1
Unplug unit! Remove top screws and pull off top lid of dryer. Heater terminals should be at top right. Use ohm meter to check resistance. If ohms won't display, then your heater unit probably has an open circuit. For instance, my GLET1031 has a reading of 12.5 ohms.
Sep 30, 2008 | Frigidaire GLET1031 Top Load Stacked...
Dryer shuts off after a few minutes, Maytag model pye2000ayw,vent is clear, top of dryer over heating elemnts gets very hot.
the heating element may be going out on it...if its getting too hot you may risk having a fire.i would have a tech look at it and not take any chances
Aug 10, 2008 | Maytag Dryers
Aquarius 1200 wd62 - Dryer not working
Most likely it is some sort of blockage in the vent, although it could be a bad blower. Check the lint filter and vent openings for a blockage.
Jul 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Tricity Bendix WDR1240W Front Load Washer / Dryer Logo
308 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
