2wire Router
Problem for 2wire (1000-400108-001) Router
Could not find ATM circuit
By coops2007 on Nov 01, 2007
i have a 2700HG-B router it was working fine until Monday,now i cant get the internet to work and when i go through diagnostics i come to PVC connection : could not find an ATM circuit. please help
Comments:
Nov 05, 2007
- Internet works though when back on old modem
Same Problem
May 16, 2009
-   could not find ATM circuit-   TomHighRidge
Jun 30, 2008
-   I have been having lots of issues and have been ping-ponged back and forth between my ISP and Bell Canada. We started having connection issues in the early spring that escalated to the point we couldn't get online and couldn't ignore it anymore. I spent 3 hours between 2 ISP techies only to be told it was my modem (DLink DSL)... and that was after doing a totally useless system restore!! So off I went to my local ISP provider and got another modem (2wire) multi-port DSL modem. We logged on and promptly lost connection. We have since replaced the phone line to the jack, the phone jack in the wall, all of the filters, and even tried the outside jack the phone tech uses to test the line...we keep losing connection. Sometimes not for an hour, sometimes every 15 seconds... no pattern or reason. We had a phone company tech out and he said the line was running "too fast" and lowered our speed from 6008 Kbps to 3000 Kbps and told us that was the problem...that the line couldn't maintain signal and kept dropping out. As soon as he left, we lost connection. We then drilled a hole in the side of the house and put the modem (6ft) telephone line through to connect directly to the phone company test jack, and still lose connection. We had another Bell Canada tech out and he checked the box on the pole, the line, and put our phone # over to a dedicated pair of it's own, and as he was leaving we lost connection. He then came back and said the line was testing fine, it was the ISP's problem. I went into the diagnostics for the 2Wire modem and have rec'd the message about not finding an ATM Circuit. I had no idea what this meant, and called the ISP tech support...explaining EVERYTHING again, and he didn't know what any of the diagnostic stuff meant. So, I searched Google and found out that the ATM circuit is the data transfer technology used to transfer data and it allows both "ends" to speak to each other before information is sent. Not finding a circuit means it can't "talk" between the ends. Further searching told me the ATM circuit is located at the SERVER end which means it is the ISP server that has, or controls the ATM circuit. So, now I am at the point of the chicken or the egg... is it the Bell Canada line that is defunct and can't find what it needs, or is it the ISP end that keeps copping out and the Bell line can't find it? Anyone have any other thoughts solutions? I tried switching back to my other modem (DLink) with no luck... we would get signal but not for very long. I now know more about this stuff than I ever wanted to... why can't I just have an uninterupted life? -   novelideas
May 17, 2008
-   ISP
RE INSTALLED 2WIRE ROUTER
CHECKED ALL CONNECTIONS
RAN DIAGNOSTIC TEST
USED INSTALLATION PROGRAM
STILL THE SAME ANSWER; NO INTERNET;; NO ATM CIRCUIT-   EMILYSPRINGS
Mar 17, 2008
-   Im using 2 wire Router and suddenly for no aprent reason the Internet went off. After running the diagnostic test following problem was found
"Could not find an ATM circuit"
If I use my normal modem then I can use my internet with no difficulties.
Plz help me out-   csmanacuk
Solution #1
posted on Nov 02, 2007
Somewhat Helpful)
BigZ1981
Rank: Master
Rating: 83%, 40 votes
I have this same router from AT&T. First thing you need to do is make sure all phone line devices have filters on them. If that doesn't work, try a different phone jack. It could be the internal wiring on that phone jack that's causing a connection disruption (this happened to me with the jack in my room). If that still doesn't work, then call your ISP's tech support line. They'll check their network status & make sure the servers in your area aren't down for any reason, which could be a strong possibility as the ATM circuit is located at the servers. Otherwise, there could have been a screw-up on their part, which they need to correct on their side. The only way to resolve these latter issues are by calling your ISP.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 07, 2009
Very Helpful)
scottmeadows
Rank: Apprentice
Rating: 100%, 5 votes
This Issue Pertains to your line being connected to a bad DSLAM port in your ISP's "Central Office" I am a computer technician, and have dealt with this issue about six times, two of which were on my lines. there is nothing to troubleshoot, stop power cycling, you are wasting your time, call your isp techs and have them get thier ***** out there to the office and fix your line.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #3
posted on Oct 26, 2009
Not Rated)
Lahuntress
Rank: Wiz
Rating: 89%, 39 votes
i had the same problem and it wasnt the modem .. att technician had to come and fix it .it was a line issue .it was not newher in my network it was the actual physical line with the dry loops and it makes it difficult to diagnose but the techie fixed it..
Was this helpful?
Yes
No
Solution #4
posted on Oct 09, 2009
Not Rated)
macomatic
Rank: Master
Rating: 75%, 2 votes
ATM circuit issue is on ISP side. Solution #2 is the correct answer. nothing you can do but complain
Was this helpful?
Yes
No
Solution #5
posted on Apr 28, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I've run into this problem myself a few times, I have the same router type. After you've checked the filters and tried a different jack, shut down the router, then shut down every computer connected to the router. Bring the router back up first, then restart the computers. Unless the problem is on your isp's end, this should take care of the issue. If it doesn't work, hit up your tech support. Hope it helps.
Popular Solutions for 2wire Router
Questions and Unsolved Problems for 2wire Router
Do you recommend 2wire (1000-400108-001) Router?
Answer
Answer
I have a 2Wire 2701HG-B Gateway router. How do I check if UPnP is enabled?
Answer
Can I hook up a router with ethernet and wireless to my Westell Model E90-610030-06 DSL2+ Router to... (More)
Answer
I have a dovetail jig but dont know how to use it
Answer
My 2wire modem keeps saying cannot find an ATM thing and no matter what I do it will not conect to... (More)
Answer
how to get chatspace workin on a netgear 2wire router
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Routers Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
