If si for toyota camry you cand find on this blog where is cabin air filter is located and how to replace.
http://filterlocation.com/toyota-camry-cabin-air-filter-location/ Toyota Camry cabin air filter location
SOURCE: How to change the HEPA cabin filter in a 2006 Honda Civic
Open the glove box and there are push out tabs on the left and right side pop them out. Now watch it because you are about to dump the contents of your glove box on the floor. let the box hang freely from the lower hinge and look in the back. You will see a white panel that pulls out the panel has a tray attached with the filter element in it remove old element and replace with new 20ish bucks at the parts store lots more at the dealer. re-install filter tray and reverse your removal steps to re-install. Recommended approx 15k or annually
SOURCE: Difference between an Air Filter and Air Conditioning filter
The air conditioning filter that your manual speaks of is known as a ''cabin filter'', it is much differant then your engine air filter. It filters the incoming air into your vehicles interior. So if someone has told you to replace your ''air filter'' they are more then likely speaking of your ''engine'' air fitler. You should check your engine air filter every oil change. If it shows signs of dirt, then replace it. Hope this helps =)
SOURCE: Cabin air filter location 2003 F250 6.0L crew cab pickup
hey jack open the back door and look up top where the hinges are and that should be the one for the back and the front if it is not up under the hood where the wipers are then check up under the dash
SOURCE: How to I replace the cabin air filter in my 2008 MC C300
Remove the three torx screws using a torx-20 screwdriver...pull back the padding in the footwell...there is tab holding the left part of the plastic piece, use a flat-head screwdriver
to pop it out...you may need to disconnect the light connector, and the cigarette lighter connection.. Once the plastic piece is out, you will see a large white box, the filter is
inside this box. There are two yellow clips that need to be slided to the
left/right. The box then pops out from below and the folded-filter will fall
right out
Good luck..i hope this helps..please rate me a fixya.
SOURCE: MB 2008 C300 cabin air filter where
under hood,over battery, when facing windsheild top left by firewall
1.While holding the glove box (A), remove the glove box stop (B) on each side. They pop out with flathead screwdriver.
2.Remove the filter lid (A) from the blower unit, then pull out the first dust and pollen filter (B). Slide the second filter to the left, and pull it out.
Remove the filter (A) from the housing (B), and replace the filter.
Install the filters in the reverse order of removal.
make sure arrow are facing the same
