Question about Russell Hobbs 10617 Glass 2-Slice Toaster
Russell Hobbs 10617 led bar
The toaster elements heat but only one led turns on occasionally and the lever doesn't stay down. Any idea what the problem may be ?
Also, do you have an advise regarding the procedure to open up this toaster
Thank you
Fred
  • 4 more comments
  • Anonymous Jan 23, 2008
    LED BAR CANNOT BE ADJUSTED AND THE TOASTER ARM DOES NOT STAY DOWN
  • Anonymous Mar 30, 2008
    popper does not stay down ...
  • Anonymous Jul 10, 2008
    The lever doesn't stay down. Do you have an advise regarding the procedure to open up this toaster?
  • Anonymous Sep 01, 2008
    LED bar cannot be adjusted and lever won't stay down, toaster still toasts if you hold lever down. This has happened before and usually toaster resumes operation after removal and cleaning of crumb tray but this has not worked this time.
  • chloe1910 Oct 21, 2008
    Russell Hobbs 10617 Glass 2-Slice Toaster lever will not stay down
  • Anonymous Mar 16, 2014
    lever does not stay down
    Scholar:
  • 51 Answers
Well.
Heres my two bob... This is not a solution but may help someone.... I copied this from my post to another question dealing with the same toaster and problems... Also, I noticed that, in simo_tomic post, he refers to the chip in question as an 63AB1B , whereas mine the label was blank or ground off.
I havent found a source for these yet. Anyway.... onto original post...
I've tried to repair one of these toasters today.
It would intermittantly work, eg led lights would work, and the toaster would actually stay down.
Most of the time however, no lights, no toast staying down.
By removing the power cord and re plugging it in, occasionally the leds would light, then the toaster would work, until it stopped again.
FIRST A WARNING! YOU CAN KILL YOURSELF IF YOU PULL APART A TOASTER, THE VOLTAGES ARE DEADLY, IF YOU DONT KNOW WHAT YOU ARE DOING DONT OPEN IT! GET AN EXPERT OR GET A NEW TOASTER.
I pulled it apart, which was a pita as they used 8x non standard screws on the bottom.
On the pcb board where all the leds are, there is a large 18 pin chip, labelled MCU.
I believe that this is the culprit, as all diodes, resisters, caps seem OK. The thermister is ok.
By shorting two of the pins on the mcu, the leds would light up, and the toaster would actually keep the toast down, and therefore work.
However, the B**stards at Russell Hobbs have chosen not to label that chip, or have ground off the label, to make it harder for people like ourselves to repair.
Plus the fact that they use security type screws to keep us out.
This should be criminal, as it just encourages waste.
For futher info, I shorted pins 4 and 5 briefly, (ie looking at the toaster, the 4th and fifth pins on the top/far side of the pcb board, counting from the right hand side).
When I short these pins the toaster leds light and it works, not a permanent fix however.
Anyone know a suitable replacement for the MCU in this unit?
Posted on Jun 16, 2010
  • 1 more comment
  • Reiner Schwab Jun 08, 2012
    Hi Josh,
    could you please help me to identify the type of the eight screws on the bottom? Do you have the supplier and article number?
  • Josh Jan 04, 2014
    Sorry for the (extremely) late reply... no.... in short. Sorry. :) I can no longer remember.. some kind of security torque screw... ie a star shape with a central pin.
  • Anonymous May 12, 2016
    I'm in Australia & have a Russell Hobbs Glass. The MCU on mine is marked 16C56-02. FYI output from transformer 12V AC 130mA.
    Scholar:
    New Friend:
  • 67 Answers
May have screws on the bottom and the loader knob usually has to be pried off. Place soft wood like a ruler against the housing and pry carefully from side to side with a large screwdriver. After working on it, plug it in outside to a ground-fault ac plug on a fireproof surface to test.
Posted on Nov 30, 2007
Toaster won't turn off
its broken, retun it to the place you brought it and demand a refund
Nov 22, 2013 | Russell Hobbs 18117 4-Slice Deluxe Toaster...
Russell-Hobbs 18140 4 slice compact toaster
See the diagram attached:
You will see the fuse you will problema 1) Ground 2) Live wire touching the chassis 3) Heating elements in short 4) Control Relais in short. 5) Test Diodes,You must test every components.God bless you
May 17, 2012 | Russell Hobbs 18140 4-Slice Compact...
I have a 10617 2-slice glass toaster which has recently had 4 leds permenantly on. I cannot lower or increase this. Also, the lever will not stay down.
Hello, jon
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 16, 2011 | Russell Hobbs 10617 Glass 2-Slice Toaster
I need a user instruction manual for a Russel Hobbs RHM25L Microwave Oven
You can download the instruction manual by clicking on the following link.(http://www.russellhobbs.co.uk/pdf/product_236_14356.pdf ).Please don't forget to rate me if satisfied.Good Luck.
Jun 08, 2011 | Russell Hobbs 10617 Glass 2-Slice Toaster
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
Microwave does not heat food up. Oven bakes perfect cakes.
Check magnatron Fuse (The big one) if not probably the magnatron tube.
Aug 11, 2009 | Russell Hobbs 10617 Glass 2-Slice Toaster
Lever does not stay down
Buy a new toaster.
After a week or two return the broken toaster to the shop saying it won't work and ask for a refund.
Oct 30, 2008 | Russell Hobbs 10617 Glass 2-Slice Toaster
Russell Hobbs 9209 Classic toaster
I had the same problem which I managed to solve. The electro magnet that holds the toast lever down takes its power from a poor joint.
Remove the bottom of the toaster. You will see 2 wires encased in a heat proof sleeving going from the small circuit board. One of these wires dissapears up inside the heating element board about mid way along the board. You will now have to remove the metal covering by twisting 6 tabs. This is best done by taking off the black knobs you use to push the toast down - if you can - I couldnt, so I had to use long nosed pliers to bend the tabs and then with difficulty, remove the metal cover. YOu should now see the terminal that the wire is connected to. It is this connection that fails either between the wire and coonnector or connector and heatin element on the reverse side. I put a small bolt through the hole and used a nut to tighten the pressed fitting. I didnt use solder because I thought that it would just melt!
Anyway, my toaster worked after that. Russell Hobbs failed to give me any advice at all.
I hope that has helped.
Neville
Welwyn Herts
Aug 25, 2008 | Russell Hobbs 9209 Classic 4-Slice Toaster
User Manual
Here's a user's manual from Russell Hobbs that gives preliminary steps for a very similar product. It is in PDF form.
http://www.russellhobbs.co.uk/pdf/product_57_10617.pdf
Jan 27, 2008 | Russell Hobbs 10617 Glass 2-Slice Toaster
Russell Hobbs 10617 Glass 2-Slice Toaster Logo
1,069 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
