Question about Car Audio & Video
Peugeot 206 53 reg stereo compatability
Hi
I have a 53 reg 206 and I'd like to replace the Clarion stereo with a Sony.
Is there an interface connector that will allow me to continue to use the Clarion steering wheel-mounted remote with the new Sony head unit?
Any suggestions welcome!
  • Jean-Paul du Toit Jun 17, 2009
    Thanks! Trawling the net hasn't turned up much more info.
    Genius:
  • 1,341 Answers
I don't think it's that easy to find unless the stereo clearly specifies it..I have the same problem too and have given up..
Posted on Jun 17, 2009
  • heeman mohun Jun 17, 2009
    I told you that as I have been through this since last year and I have not got any alternative to replace my radio so that I can have have steering control..
Anyone help I need the radio code for peugeot 206 51 plate serial code for stereo CL0410269200, thanks
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
Jul 05, 2011 | Interface Adapter For Stereos
Need to know what the pins are on the connector blocks on a Clarion PU-2358A (peugeot RD3) carv cd/radio
Is this site of any use as it shows many pin arrangements
www.tehnomagazin.com/Auto-radio-car-connector/CLARION-Car-Radio-Wiring-Connector.htm
Jan 01, 2011 | Car Audio & Video
How do your lock in your radio code on a t reg peugeot partner van after entering in the code.
It all depends on the actual MAKE and MODEL of your radio
Most Peugeot radios are made by Blaupunkt , Philips or Clarion so check this site for your actual instructions ( Click on the radio MAKE and enter Peugeot in the Search box)
http://www.radio-code.co.uk/code-entry-help.php
Jul 16, 2010 | Car Audio & Video
I had a Clarion 6 Disc CAA-355 in my car which got wet and is no longer working. Can I buy the same model again. If so where from and for how much or is there another model that will be compatible with my...
Great Clarion Disk Changer, 6 CDs CDC-655Z:
CDC655z Multi-Disc Changer - 6 -disc direct load mechanism. - 1-Bit D/A converter. - 10 sec. read ahead memory to prevent interruptions caused by shock and vibrations. - Non-stop play. - Optical Digital Output. - 0º to +90º mounting angle.
Great Multi-disk player. Works only with Clarion audio source units.
Selling b/c my deck player broke- I can give you the deck- maybe you can fix it. The model is DXZ-535, comes with owner's manual and remote.
Feb 25, 2010 | Clarion Car Audio & Video
Hi I have a peugeot 106 and I need the stereo code
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Radio Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
Jan 30, 2010 | Car APS95BT2 2-Button Code Learning...
Need code for a clarion pu-9971
i believe the only way to get this code is you have to call clarion and talk to someone from tech services and they will walk you through the steps in resetting the code.
Feb 16, 2009 | OEM Systems Car Audio & Video
Code for clarian stereo
I have a 206 cc with a built in clarion cd and radio, the cd player does not work. my girlfriend has a 307 with the same cd player.I want to swop them both over but when i do they both bleep! this must be the anti-theft device kicking in. How do i swop them? darren fom haworth
Feb 16, 2008 | Clarion ADX8255
Peugeot 406 factory fitted sat nav
If you have the factory fitted nav then this is an integrated system and you will need to get the clarion repaired. If you give me a call I can advise you how to arrange to have the unit repaired 0161 428 2020
Dec 18, 2007 | Car Audio & Video
Car Audio & Video Logo
263 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
