Question about 3DO Warriors of Might and Magic for PlayStation 2
Stuck on Wariors of might and magic
I am on the enroth quest level and need to fing the green and red gem to get to the next level. I found the red one but i cant find the green one so where do i find it?
    Problem Solver:
  • 16 Answers
Got to gamefaqs.com and read an faq itll help so you dont have to come back
Posted on Jul 10, 2009
Should green "compressor on" light always be on?
read the user manual
the light may only come on when the compressor is working
talk with a service agent for the unit and ask them
Dec 29, 2016 | Magic Chef Freezers
Adjust the color in a hitachi 43F300
The below convergence procedure was copied from: http://www.espnhd.com/voice/showthread.php?t=3736
Manual Convergence for the Hitachi
1) Receive an NTSC signal.
2) Press Magic Focus to begin magic focus
3) Press magic focus again during the magic focus process to get the ?stop? screen
4) While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and
the service grid (64 point grid)
5) When you first get in here? I believe red is the selected color by default (it is flashing).
6) To choose other colors to converge, use the following buttons on the R/C:
a) ?STATUS? - Green
b) ?0? - Red
c) ?ANT? - Blue
7) Start from the center of the screen and work your way out on one color at a time. I adjusted red across the
whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
(a) Use 4, 6, 2, and 5 on the R/C to move the cursor position(dotted lines).
(b) Use thumb stick to move the convergence point color.
** There have been other posts in here to tape together the color filters found in the Avia DVD to help converge
lines more easily. I have used this method, and it works well for adjusting to a greater detail. Basically, you put the
red filter next to the green and adjust your red to the green line both horizontally, and then vertically. Then you do
the same with the blue next to the green. Some people recommended you should be at normal viewing distance. I
did mine from just a few feet back from the set. Maybe my eyes aren?t as good? maybe I just felt like it worked
better this way. There are some other posts also recommending using binoculars. I think it?s great that people
suggest things to make the process easier? but my girlfriend would think I was insane if she saw me with
binoculars on the couch adjusting the convergence. I don?t know? whatever works best I guess.
8) I did not adjust the green at all. I use the green as the guide and did not adjust the location of any green point.
This is highly suggested unless you have geometry problems.
9) When going along the lines and adjusting, you may run into the problem of getting an ?S? curve on the line.
You?ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the
line between the points will not straighten out (it bends between the points). To fix this, the manual recommends
going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is
also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in
(13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 - ?coarse?
7x5 - ?medium?
13x9 - ?fine?
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press ?STATUS? 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press ?0? 5 times
3. (13x9) Press ?ANT? 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point? depending on where
you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ?grids? on the edges of the screen, press the PIP CH button
on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence
as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed
to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write
displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
WARNING: YOU MUST DO THE FOLLOWING STEPS TO COMPLETE MAGIC FOCUS
INITIALIZATION!!! THERE HAVE BEEN MANY POSTS THAT PEOPLE HAVE HAD PROBLEMS
WITHOUT DOING THIS STEP BECAUSE THEY LOOSE MAGIC FOCUS!
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Press PIP MODE and then PIP CH to initialize Magic Focus. The initialize operation starts and several
windows appear during this operation. It takes about 30 seconds or less.
18) When green dots appear, initialize operation is finished.
19) Turn power OFF.
21) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just
to make sure the magic focus still works (and that you did the last few steps properly)
Hope this helps
Dec 15, 2007 | Hitachi 43F300 43" Rear Projection...
Whilst try to complete the warped soul gem quest on skyrim on the playstation 3 I place the gem in the converter use the spell the in tells me to take the gem to the final converter and I've been to e
Hi, this is a popular Skyrim quest bug and I'm not sure if its been adressed on the PS3. But If you have a game saved before this point in the Arniel's Endeavour quest, checkout this link:
Arniel's Endeavor - Skyrim PS3 Bug Fix
Hope this helps.
Dec 02, 2013 | PlayStation PS3 Elder Scrolls V: Skyrim...
Fracino little gem coffe machine manual
visacrem intternational limited
FRACINO COFFEE MACHINES
THE LITTLE GEM
INSTALLATION INSTRUCTIONS
.REMOVE PLASTIC BUNG & FILL TOP TANK WITH COLD WATER TO TOP (N.B WATER SHOULD BE SOFTENED)
.PLUG MACHINE IN & SWITCH ON AT MAINS
.TURN MACHINE ON (ON/OFF SWITCH ON SILER PANEL JUST UNDER FRONT RED PANEL- NEXT TO GROUP)
.RED NEON AND AMBER NEON LIGHTS WILL ILLUMINATE AND THE MACHINE WILL START TO FILL
.OPEN STEAM VALVE (TURN RIGHT HAND BLACK HANDLE ANTI CLOCKWISE)
.WHEN WATER LEVEL REACHES THE YELLOW LINE ON THE SIGHT GLASS THE LIGHT WILL GO OFF AND
THE MACHINE WILL CUT OUT
REFIL THE TANK AND THEN TURN THE ON/OFF SWITCH OFF AND WAIT 5 SECONDS TURN THE ON/OFF
SWITCH BACK ON THE MACHINE WILL CONTINUE TO FILL
.WHEN THE WATER LEVEL REACHES THE TOP RED LINE ON THE SIGHT GLASS THE RED LIGHT WILL
GO OUT THE AMBER LIGHT WILL REMAIN ON UNTIL THE WATER REACHES THE CORRECT LEVEL AND THEN
GO OUT
.THE MACHINE WILL NOW START TO HEAT THE WATER WAIT FOR STEAM TO COME OUT OF THE STEAM TUBE
(BETWEEN 5-10 MINS APPROX) AND CLOSE THE STEAM VALVE (TURN RIGHT HAND BLACK HANDLE CLOKWISE)
.WAIT FOR THE PRESSURE TO COME UP TO 1-2KG/CM3 (PRESSURE GAUGE ON FRONT OF MACHINE BETWEEN
THE TWO BLACK HANDLES)
.THE MACHINE IS NOE READY TO USE
.PUT EMPTY FILTER HOLDER INTO THE GROUP AND FLUSH WITH WATER BY TURNING ON RED SWITCH NEXT
TO PRESSURE GAUGE AND LETTING WATER RUN THROUGH THIS PROCESS WILL TAKE SOME TIME AND USE
APPROXIMATELY HALF PINT OF WATER THE GROUP AND FILTER HOLDER SHOULD BE HOT - CHECK BY
TOUCH IF THEY ARE NOT HOT LET WATER CONTINUE TO FLUSH THROUGH UNTIL THEY ARE AND THEN
TURN RED SWITCH OFF
.MAKE A TEST CUP OF COFFEE THIS FIRST CUP WILL PROBABLY BE COLD BUT AS YOU MAKE MORE CUPS
OF COFFEE THEY WILL GET HOTTER IF POSSIBLE LEAVE THE MACHINE TO STAND FOR APPROX 30 MINS
BEFORE MAKING COFFEE THIS WILL ENABLE IT TO WARM UP AND PRODUCE COFFEE AT THE CORRECT
TEMPRATURE.
HOPE THIS IS WHAT YOU WERE LOOKING FOR ITS WHAT THEY GAVE ME WHEN I GO MINE FROM THEM.
IF NOT HERES A LINK TO THE PARTS MANUAL AND CATALOG
http://www.fracino.com/technical/parts.html
http://www.fracino.com/machines/hand-fill-coffee-machines/little-gem.html
http://www.vendingexpress.co.uk/uploads/pdf/product-fracino-little-gem-automatic_4e7a1df44be5d.pdf
Jan 20, 2012 | Coffee Makers & Espresso Machines
Unlock Code For FATE?
Heal - Restores all of your health.
Gold - Gives you 500,000 pieces of gold.
God - Gives you ten experience levels and eight to your pet.
Fame - Adds 1000 fame points to your character.
Experience - Adds 5000 experience points to your character.
Dumpmap - Creates a text description of the current map to a maze.txt
file, which can be found in the game's installation folder.
Descend "#" - Descend a "#" of levels (input a number and remove quotes).
Ascend "#" - Ascends a "#" of levels (input a number and remove quotes).
Small - Chest Shows up but there is nothing in it.
Shrine Of Learning - Creates a Shrine that when activated generates a random negative
or positive effect on character stats.
Magic Anvil - Creates an Anvil that when activated grants you a random Negative
or positive magical effect on an item.
Fountain of Wellness - Creates a Fountain that when activated replenishes Both Health & Mana.
Fountain Of Stamina - Creates a Fountain that when activated replenishes Stamina.
Fountain Of Health - Creates a Fountain that when activated replenishes Health.
Fate Statue - Creates a statute that when activated you get either a unique Monster
or 2 Random Gems.
Fountain of Mana - Creates a Fountain that when activated replenishes mana.
Chest - Shows up but there is nothing in it.
Large Chest - Shows up but there is nothing in it.
small chest - Spawn small chest; cannot be opened
Storage trunk - Shows up but can't be opened in town (This might work in dungeons).
Weapon Rack - Shows up but can't be activated.
Health fountain - Spawn health fountain.
Levelup - Level up.
Blood - Blood will appear red when killing some monsters.
Noblood - Blood will appear normal.
Discoverall - Full map.
Town portal spell - Spawn town portal spell.
superior sapphire - Spawn superior sapphire.
[item name] summons specified item (any item);
example: town portal spell summons the "town portal spell";
superior sapphire summons "superior sapphire".
[Item Name] Summons an item near you. This cheat can summon artifacts, but not flawless,
superior, or exceptional versions of items.
[Creature Name] Summons a creature near you. Any creature you summon this way will exist
as an enemy monster; however, typing "Cat" or "Terrier" will summon a pet Levelup Gives
you one experience level.
Final Password:
Valkyr
Sep 06, 2009 | Video Game Consoles & Games
Ps3 says cannot start the correct hard disk was not found
try safemode
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Magic Chef MCWC8DSCT Wine Cooler
the magic chef is probably the ptc relay.to the left of compressor is a shield with 1 screw behind it .on top is the relay with 1 wire.wiggle it off .go to repairclinic.com...part#1206838
Nov 07, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
DOUBLE IMAGE HITACHI ULTRAVISION TV
Ok, I would suggest before you buy anything from anybody is to try to do a manual convergence.
a) ?STATUS? - Green
b) ?0? - Red
c) ?ANT? - Blue
3x3 - ?coarse?
7x5 - ?medium?
13x9 - ?fine?
19) Turn power OFF.
Oct 27, 2008 | Televison & Video
Convergence ICs
Well if you are not a repairman you should not do this kind of job yourself.
If you decide to service your TV, remember to keep it unplugged for one hour before working on it.
Check this link here to find sellers for the kit and illustrated procedures.
Here I am reporting convergence procedure from website above.:
" Manual Convergence for the Hitachi
a) ?STATUS? - Green
b) ?0? - Red
c) ?ANT? - Blue
3x3 - ?coarse?
7x5 - ?medium?
13x9 - ?fine?
19) Turn power OFF.
to make sure the magic focus still works (and that you did the last few steps properly)"
Perform full convergence procedure before replacing ICs.
To know if an IC has blown you should test the small fuse at the base of the IC.
Jul 13, 2008 | Hitachi 53FDX01B 53" Rear Projection...
3DO Warriors of Might and Magic for PlayStation 2 Logo
95 people viewed this question
Top 3DO Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a 3DO Video Game Console and Game Expert? Answer questions, earn points and help others
