Question about Panasonic Televison & Video
Distorted picture and sound on plasma tv
We have a Panasonic Viera plasma tv with seperate set top box, only about 12 months old. Recently the picture and sound have become increasingly distorted. The picture has squares of distortion and the sound is quite 'electronic' sounding. It started a little bit across the bottom of the screen and is moving up with more distortion in the sound. We have no problems with watching DVDs or pay tv, it is just the free to air channels. I hve tried reinstalling the channels thru the set top box (Topfield TF4000T) but it did not help. I have checked the cables to see if they are loose, but all appear okay.
  • 10 Answers
SOURCE: Plasma TV
Try to reset the TV to factory defaults and see if that helps. Record your color settings and any other setting your have in your config before dong this because all will be lost.
Posted on Jul 25, 2007
  • 286 Answers
SOURCE: Picture full of lines and flicker
Zdenko did an excellent job. Voltage regulators and the capacitors on the main boards and in the power supplies are always suspect. Some times you can narrow down the culprit buy purchasing a can of freeze spray. Let the TV warm up and try freezing suspect components to see if this causes a reaction. Thermal problems can often be found in this way.
Of course, if you're not able or willing to replace components on the circuit boards, you can always replace the main board or power supply board after determining which is causing the problem. These parts should be available at your local Viewsonic service provider at a reasonable price.
Posted on Feb 14, 2008
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
  • 225 Answers
SOURCE: just out of warranty Dell TV W3706MC,two years old
Sounds like a bad video board. No easy way to fix a bad video board. It needs to be replaced. That is why the repair shops will not fix it; they do not stock video boards for all models. And it is a pain to track one down all of a sudden. Once a warranty is up, you are running on bonus time. Electrical components have a definite lifespan. It is possible to recover some money by selling it "as-is" online somewhere. You could get 200-400 for it broken, pretty easy I suppose.
Posted on Nov 14, 2008
  • 20 Answers
SOURCE: 42 LG Plasma picture distorted and flickering
replace the control module.
Posted on Mar 11, 2009
Panasoics plasma viera rv will not auto tune telling us to insert aerial already in Model TH-P50X20Z
The manual for this TV can be found here. If you are watching broadcast television, or cable TV service that does NOT require use of a set top "cable box" tuner, you would connect the coax cable from the UHF / VHF antenna or cable into the ANT cable connector on the rear of the TV as shown on page 8 & 9 in the manual.
You would then tell the TV setup to scan for available channels as shown on page 12 of the manual.
If you are using a seperate tuner - like those supplied by Cable TV, Dish, DirectTV, Satellite, etc. you should use (1) the HDMI 1, 2 or 3 inputs (HD) 720P and up; (2) the RGB inputs of AV2 for best picture quality 720P or better (HD), (3 & 4) the AV1 & AV3 (on the side next to HDMI) for 480i and possibly 480P (SD) and finally the ANT connector for 480i. If you have a computer that offers VGA jack to connect to an external monitor, use the PC connector on th erear of the TV to send it HD images.
Page 27 & 28 detail manual channel editing.
Mar 14, 2013 | Panasonic Viera TH-50PX80U Plasma TV
12 blinking lights on panasonic TH42PX75U
12 blinks on the Th42PZ75U model is indicating the Audio has an issue and is preventing the set from powering up. The A board will need replacement. You can get the A board from www.tvrepairworld.com
Feb 09, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
Apr 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
The pictures are mostly green - like instead of black it shows green
It's called Cyan and it's sound like you are having a problem on your D-board. Look for capacitors bulging out and replace first if not then order D-board
May 01, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Plasma TV Picture Periodically Blurry/Color is Distorted
This sound more like a cable issue. Also check the leads going from your cable box to the set/ If you are using component cables one of them may be loose.
Apr 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
We had a vertical line about 2 inches wide and going from top to bottom on our 42 inch viera that was a light green-barely interfering with picture. Now that area has gone black while the rest of the tv...
It is either the plasma panel itself or a connection problem, either way it will need to get serviced. Suggest you find receipt and phone Panasonic.
Cheers.
Sep 25, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Distortion on people faces
What does a dvd look like played on it? If it's the same then there is something wrong with the TV. If a dvd looks good - no color problem - then it's the sat box that needs replaced.
Mar 25, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic Viera
vga board is bad ot the components on it are blown out.
May 08, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Plasma TV
Jul 14, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Open Questions:
Televison & Video Logo
609 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
