Question about EnGenius EOC-3220 (EOC3220)
How long I will gain if I'm using 15dbi omni-antenna + 100W signal booster?
I have planned to deploy 15dbi omni-antenna with 100W signal booster, If I can gain more than 25 kilometers in 360 degrees maybe that's the best for me move-on. What are the possibility of disadvantages and advantages if I will going to used that certain specification?
Please help me I will give you 100% solved I sound interested.
Best regards,
  • 132 Answers
Here is a chart that will help you. with more info you can get more exact, but to answer what I think is your question, it would be about 1-3 miles. Without knowing the Mbps I can't be more accurate.
as far as advantages, theres no more than any other except for distance. Disadvantage...don't see any.
Posted on Nov 02, 2007
Is there a antenna or a booster that i can use in the house
There are many antenna systems available for Off-the-Air broadcast TV. It depends on space available mainly. There are internal (inside the home) and external mounted systems. Some external antenna can be mounted in the attic as well. External antenna are usually larger and cable of receiving signals from longer distances. They are either directional (point in one general direction at a time) ir omni directional (can receive signals from 360 degrees without physically aiming or pointing the antenna). They also can come with amplifiers/signal boosters, motors (to rotate the antenna for better recepton without manuall shifting it yourself). You can add splitters ti provide signals to more than one TV at a time. The number if channels you receive can depend on many variables so, depending on your location, how far away from the broadcasting antennae you are, and how you mount your antenna, the number of channels & quality of receive signals will vary.
Good news is there are websites on the Internet that can help immensely, so you don't to hire an electrical engineer!
Apr 25, 2017 | Televison & Video
Is dual band booster is supported for Australian mobile band network?
Yes, dual band booster is supported for Australian mobile band network. It can be used for an outdoor direction aerial or for indoor spaces like home. This is the same style aerial supplied comparing other network system. The antenna can be set in an all-weather casing. The high gain system panel is perfect for wall-mount applications. This antenna works the 850MHZ, 900 MHZ, 1800MHz and 3G 2100 system frequencies (Australia and NZ telephone arranges) and is good with most portable sponsor packs.
Mobile Phone Signal Booster Best Signal Repeaters in Australia
Apr 18, 2017 | Dual Cell Phones
Is that a little 2.4GHz antenna on the reciever? Have you tried using another antenna? (If its replaceable)
On the other hand, try converting signal from omni-directional to directional.
One can increase the range of the transmitter/receiver pair by using a high gain directional antenna. Home-brew instruction for making a high gain antenna can be found at:
May 27, 2013 | Audio Players & Recorders
How do I strengthen my wireless signal? I am using a Linksys router.
The easiest is to replace the small antenna with a higher gain one. You get some very effective 8+ db gain omni directional antennas for linksys on ebay, amazon etc.
If you are in one direction you can also use a Yagi antenna (Directional) with high gain (20+db gain)
Normally the problem is not just the router, but the connecting device as well.
Keeping in mind you have 2 way comms between 2 devices. The router and say a laptop. ideally you should upgrade both antennas. As the best antenna on an Linksys AP will not fix a weak laptop signal. (it will transmit better, and receive better, but the laptop should also transmit and receive better)
Hope it helps
Mar 29, 2011 | Linksys Wireless-G Broadband Router
I have "Rabbit Ears" anntena and wish to tune the TV channels please.
This is low gain vhf antenna. this type of vhf anntena is used strong vhf signal area ony.any way you may try to roate the antena to recivicing signal. other wise you can use vhf booster.
Aug 03, 2010 | Televison & Video
I'm trying to set the digital channels on my durabrand tv and i get the message that digital channel signal strength is low. what do i need to do?
If you are using a regular antenna to receive the signal, then you would need to either find a signal booster of some sort, or improve the antenna. There are many antennas out there for the digital era, most of them are set-top multi-/omni-directional ones, but they have their limitations. Unfortunately to get a better signal, typically an outdoor antenna is needed, or a large expansive one in the attic.
Nov 19, 2009 | Durabrand DWT1905 TV
Wireless Internet not getting enought signal strength
Yea there are high gain antennas. Here are some on a site i would recommend
The more you spend the more purchase you will get. Go for one with a high dBi. Also be aware that you may want an omni-directional one if you want the signal to be boosted in all areas
May 05, 2008 | Computers & Internet
Compatibility with Sitecom wl 031
This 10dBi omni directional antenna enables you to very easily extend the range of your wireless network. By linking the Omni Antenna to your wireless router, you gain the benefits of an optimum wireless signal while minimising the number of ‘dead spots’ (points in your home where the signal is either weak or lost).
However it does not fit the following types of routers,modems and accespoints:
These antenne's will also fit other brands of wireless products that use an SMA connector
Jan 29, 2008 | NetGear WGR614 Wireless Router
EnGenius EOC-3220 (EOC3220) Logo
197 people viewed this question
Top EnGenius Computers & Internet Experts
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
