Question about Tomtom GO 300 GPS Receiver
Red cross on sd card on startup
I found a tom tom1 with no sd card - borrowed my dads sd card to see if it worked and it came up with the tomtom sign then the picture of the tomtom with the sd card coming out then a red cross appearing on the card, kept trying it but still the same. After putting the sd card back in my dads tomtom the same happened to his?????
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 171 Answers
You can not use a sd card from one TomTom and put it into another TomTom. The operating system on the card is coded for each individual TomTom device. First try doing a reset with the card installed on your dads TomTom. The reset hole is on the bottom of the TomTom marked reset Use a streightened paper clip, insert the paper clip into the hole until you feel a click then hold it in for 20 seconds. If that didn't work and you have a card reader insert your dads sd card into the reader and make a backup of the everything on the sd card. Just copy and paste everything on the card to a folder on the desktop you have created on your desktop. Next delete everything on the sd card EXCEPT the maps and ttgo.bif or ttgo.bak file. Now that you have made a backup and deleted everything on the sd card except for the maps and ttgo.bif or ttgo.bak open TomTom Home. TomTom Home should see your card and install the operating system back onto the sd card. If it doesn't you may have to insert the sd card back into your dads TomTom and connect it to the pc. It may take a few times of doing this to get the latest operating system back onto your dads TomTom. You can do the same for your TomTom, but you cannot use any thing bigger than a 2 gb sd card. Do not get sdhc cards they won't work. This will only put the operating system for your TomTom onto the sd card. When you have installed the operating system onto your device it will say "no maps found", you will have to buy the map from TomTom..
Posted on Jun 18, 2009
You will have to input the product key that came with your dad's unit. This will allow you to use his sd card. Hope this helps
My tomtom fell on the floor and i get aflashing red and white cross. How do i correct this and get my device working again?
Internal memory was damaged when dropped.. OR the SD card if it has one. Replace the sd card and copy data over from back up
Feb 23, 2013 | Tomtom ONE XL GB Car GPS Receiver
Tomtom shows a red cross over the SIM card and will not turn on.
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now need to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your SD card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the SD card
It should now work
Apr 23, 2010 | Tomtom ONE GPS Receiver
Tomtom 1 v3 wont read new sd card help
Take special not of part 6
1. Remove the SD card
The card needs to be formatted properly first that's all,
2. formatting is better done in a card reader.
3. Right click on it and select format select FAT32 as the files system
4. Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
5. You now ned to select your tom tom which will also show as a drive.
6. In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
7. Then just copy ALL the files from the tom tom to your sd card
8. DO NOT USE CUT AND PASTE !
9. Once all the files are on switch off the tom tom and insert the sd card
It should now work
Sep 15, 2009 | Tomtom ONE XL GPS
Tom tom go 510 won't go ............
I red cross usually indicates an SD card problem.
With most tomtom's usually removeing the SD card and powering up will resolve the issue.
If not then a HARD reset without the SD card may be called for.
If it does prove to be an SD card error then formatting in a proper card reader using FAT32 as the file system and then copying the files back over from the tomtom usually does the trick.
Or format and restore from a back up to the card. can work too.
It may also mean that a files might have been deleted or become corrupted.
Aug 29, 2009 | Tomtom Go Plus GPS Receiver
When I turn on there is only a cross over the SD card.
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Jun 14, 2009 | Tomtom One XL GPS Receiver
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
Help
Hi, i did the same thing with my tom tom 300 go, i fixed it by borrowing my mothers sd card from her tom tom 710, i put the card into a card reader and copied the hole card to my computer then copied it back onto my sd card out of my tomtom then put in mine and bingo it worked with all the fetchers that her tom tom had and the updated maps it still said it was a 300 but had the 710 stuff try this it worked for me it should work for you.
Mar 08, 2008 | Tomtom GO 300 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
485 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
