Question about Electronics - Others
My USB port is not working
P4 HCL Computer: Pen Drive, Mouse or any kind of USB support not responding.
  • 1,555 Answers
You have not mentioned wether earlier your usb was working or not. Anyways this can occur due to 2 reasons either disabled or driver outdated so you require to right click on my computer select properties then device manager and scroll to the bottom in device manager if you find usb with a red cross then its disabled right click on it and enable it. If this is not the case then tell me *********** board i'll give you the link to the latest driver.
Posted on Jun 17, 2009
Computer not recognizing hard drive. Seems to be a problem with usb connection. Can I put the drive into another enclosure?
Definitely you can try with different enclosure, and it will work in any enclosure... But before buying a new enclosure it would be better if you try to connect the hard drive in a different computer to isolate where the issue is...
Jan 02, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
My both usb ports r not wrking n hangs when eithr card reader or pen drive is inserted bt works well when tata photon usb port or mouse port or key board port is inserted ?model- EMACHINES E275
Sounds like your laptop's USB ports are not capable of providing enough power to operate your card reader or pen drive. I suggest you buy an active USB hub (one with external power source, rather than the one which draws power from the laptop's USB port), & attach your card reader and/or pen drive to that USB hub.
Nov 28, 2010 | Acer Computers & Internet
When i insert pendrive in my two three machines, machines get hang completly. i have tried same pen drive in other machine it works fine. I am using quick heal antivirus. please fix my problem its urgent...
Hi.
Kindly first check if your mouse works fine with the USB port if it does not then the issue is with the USB port which can be replaced . This happens due to short in the USB port board.
Feb 08, 2010 | IBM ThinkCentre S50 8183 - P4 3 GHz...
System hangs by inserting pen drive
does other usb devices work fine on the same system please check if your pen drive is working fine on some other pc/laptop if it is working fine then you have to check with your usb ports.
Jun 09, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Bluetooth keyboard and mouse stopped responding on Dell Dimension E520
try to insert another usb drive on the port.it the usb works then probably the bluetooth transmitter is faulty. If the USB drive also does not work... then probably the USB port of the computer damaged.
Jan 15, 2018 | Dell Wireless Keyboard Optical Mouse w0147
System hang when i insert pen drive
solution..
1) Check The USB Port for Damaged, Bend Or Broken Pins.
2) Check The Pen Drive For Physical Damage.
3) Try The Pen Drive In another USB Port. (i.e. if u r using the pen drive in the FRONT PANEL USB PORT than try it in BACK PANEL USB PORT)
4) Try The Pen Drive In Another System.
5) Tye Another Pen Drive.
6) If All Above Is Fine Then Format The PEN DRIVE.
7) Try The PEN DRIVE now.
8) Is Issue Still Persists Then..
9) Uninstall the CHIPSET/MOTHERBOARD DRIVER COMPLETELY and then clear %temp% & prefetch files and Restart Your System.
10) Install The Latest CHIPSET/MOTHERBOARD DRIVER and ANY AVAILABLE FIRMWARE for the motherboard..
May 22, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Kingstan 2 GB pen drive
try to put it in another computer..if it is recognized,then the usb version of your laptop differs from the sticks version..if not...means that the memory stick is damaged..
good luck
bye
Feb 03, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb drive is not deteded when plug into PC
Dear sir I am using kingston 2 GB USB pen drive it is suddenly not detected with my HCL leaptop. Plz kindly help me
Jul 01, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Electronics - Others Logo
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
