After loading paper "paper set again" error message appear in wepro HQ-2600 printer.I replace paper tractor and clean all the censor but problem remain.How can I resolve this problem
  • Anonymous Mar 23, 2014
    set paper again
Cheng 8 pin cable. For Paper sensor.
Posted on Aug 12, 2010
    New Friend:
  • one solve of my problem accord wep printer hq 2600 high speed dmp after loading paper printer on then go print job
Posted on Mar 23, 2014
Error: printer error. turn off then on again. for details, see your documentation.
Hi I have a similar problem with Epson px660, it does not complete the self test after powering on then it flashes all lights with a printer error of fatal code 0x71, can you assist me kindly.
Best regards
Mar 13, 2015 | Office Equipment & Supplies
Load error
When trying to print on continuous stationery, the display may show "Online Single Load". This will occur if the printer is expecting to print on single sheet paper even though you may want it to print on continuous paper. To clear the error follow this procedure. • Take the printer off-line by pressing the Online key • Press the Setup key • Press the key under "Paperway" in the display • Select Tractor 1 (or Tractor 2 if fitted/required) • Press the key under "Set" • If the job still refuses to print try loading the printer with a single sheet of paper to clear the command. To do this remove the tractor feed paper and close the cover on top of the tractors but not the outside cover. You will see a guide into which put a single sheet of paper and press the key under "Load" in the display. • The printer should commence printing. If it does not, then press and hold the key under "LF/FF" to eject the single sheet. Now follow the instructions above again to select the Tractor. The display should read "OnLine Tractor Load". Load the tractor fed paper into the Tractors and press the key under "Load". The printer should now be ready to print. Check your software settings for the correct paper path type. Ensure that the display does not show "Manual" otherwise you will have to clear this error in the same manner as you have for Single sheet
Dec 06, 2011 | Tally Dot Matrix T2265C Printer
Printer Canon LBP3300, When was printer it show "Load custom paper in manual feed slot". Have try to slot manual feed but also cant work. Please help to solve this problem. thanks
Load Legal paper in Cassette 1.
If you want to print using only one piece of paper currently loaded in the Manual Feed Slot, click [Resolve Error].
If you want to feed paper from the cassettes, remove the loaded paper from the Manual Feed Slot.
Dec 14, 2010 | Canon LASER SHOT LBP 3300 Printer
I have a Tally T2245 with load error. ASF-R
Sounds like the paper path has been changed I guess you are using the front Tractor (tractor 1) to load continuose paper.
You need to go into the menu and change the paper path back to Tractor 1.
Disconnect the pritner from the computer system, and power the printer off and back on again to clear the buffer.
  • This should change the paper way back to Tractor 1
    Jun 23, 2009 | Tally T2245 Matrix Printer
    Error message request to load paper when paper is loaded. Appears that it doesn't detect paper or can't pick it up.
    I recommend you to follow the instructions given in HP web-site only to ensure the proper functionality of your product.
    Please Click Here and follow the instructions to check the functionality.
    If problem still persists Click here and follow the instructions to clean paper rollers using Cleaning kit.
    May 26, 2009 | HP Photosmart 2575 All-In-One Printer,...
    Show the load paper error
    There is a paper motion switch behind the tracter feed assembly that might be stuck. Check that and also clean arround the tractor assembly.
    Jan 01, 2009 | Printronix Line Matrix P5005B Printer
    Tally T2250 Matrix Printer does not pull up paper to be printed
    I would guess you are getting error messages on the diplay to tell you what the bleeping noise is about....Please read this message.....
    I would guess the message is something like LOAD SINGLE, and you are using tractor feed paper. If this is the case the paper path on the pritner has changed and needs to be changed to Tractor 1 again.
    To do this;
    • Stop any prin jobs gong to the pritner
    • If the printer has data in its buffer, power the printer off and back on again to clear this data
    • Ensure the printer is OFFLINE
    • Press the SETUP button
    • Press the button under ADJUST
    • Press the button under PAPER WAY
    • Use button 2 or 3 to change this to TRACTOR 1
    • Press SET
    • Place the pritner ONLINE
    You should be back in action, if not post the message you see on the printers LCD display.
    Dec 18, 2007 | Tally T2250 Matrix Printer
    170 people viewed this question
    k24674
    jasbo
    jasbo
    Marvin
    Marvin
