Question about Samsung TXN3071WHF 30" TV
Every time i change channels on my tv the screen size changes Can you please tell me what I need to do to rectify this problem Many Thanks
  • 52 Answers
Your channel display mode is set to auto i'd say.
Go into menu and find >
TV System.
Go to
Display Mode.
go to
Aspect Mode.
now you may choose what aspect you would like to watch you tv in.
You will have
4:3 PS
4:3 LB
16:9
and
Auto.
I go with one of the first two, as 16:9 is widescreen and Auto is a bit random as you found out. These are only rough guidelines as i don't own a Samsung TV. But all setting are mostly the same on all TV Sets.
Hope this helps,
Hughie.
Posted on Jun 17, 2009
How do I change the picture size?
You can change the picture size by using either the TV remote or the cable box remote (which ever you are using). Just go into the TV settings option, scroll through the different options that adjust everything from color and tint, sound, contrast, etc, and you should find one for changing the screen size (my Sony TV can be changed from normal, and wide, to wide zoom).
Sep 19, 2014 | Celcus LED40S0913FHD 40" LCD TV 1920x1080,...
A simple question - My new 42" LG tv is fine -
You should be able to change the aspect ratio to fit the size of your screen. This will be the 16:9 4:3 16:10 settings.
You can access these by going to MENU---> PICTURE -----> Select ratio that works----> exit out and watch TV.
IF this will not fix it you need to look into the signals being fed to the TV as sometimes they can have a funny effect on the output picture. Some cable boxes will alter the picture and then it won't come out right on the TV. If it is all inputs doing this tho then changing just the Aspect ratio on the TV should solve the problem.
Jun 07, 2011 | LG 32LG30 32 in. LCD HDTV
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
Apr 13, 2011 | Insignia IS-LCDTV32 32 in. Television
The aspect ratio on the HD channels are full screen - which is correct. However all other channels have the incorrect aspect ratio. (reduced size) A solution please???
Many times HD channels will come in more clear, but with a smaller picture or widescreen view. There should be a button on your remote called 'wide' or 'zoom' and it will let you adjust the size on the fly. If you adjust the view while watching an HD channel, and you switch to a standard channel, you will have to change the ratio back. For other information and help with LG TVS visit http://www.lg.com/us/support. Thanks
Mar 31, 2011 | LG 42SL9000 42 in. HD-Ready LED TV
Ticker along bottom of screen for news channels and sports channels is being cutoff along the bottom. That is, the ticker moves right to left and I can read it but the bottom 10-15% of the letters is...
I might need a little more detail to solve this problem - I suspect the problem is an incorrect setting on your cable/satellite receiver (assuming you are using one), but let's start with the TV.
Firstly, switch the TV on and select a channel where you can see the ticker. Then press the "FORMAT" button (above the red REC/CONNECT button) on your Mitsubishi remote control. This will change the screen aspect ratio and the current setting will be displayed on screen. Each time you press the FORMAT button the screen size should change.
The screen aspect ratio settings for your TV are STANDARD, EXPAND, ZOOM, STRETCHED and NARROW. Press the FORMAT button repeatedly until "STANDARD" is displayed on the screen. If the ticker is still cut off, you need to change the aspect ratio setting on your cable/satellite receiver.
Please note: If the TV will only allow you to select STANDARD, this is not a fault. It simply means that the aspect ratio cannot be changed on the TV because it's displaying a picture from an external source, i.e. a cable/satellite receiver.
You should then look for a button on the front of your cable/satellite receiver or the cable/satellite remote control marked "FORMAT" or "ZOOM". When you have located this button, try pressing it repeatedly until the ticker is both fully on the TV screen and the picture covers the entire screen.
If you don't have a FORMAT or ZOOM button for your cable/satellite receiver or you are unable to set the picture size correctly, leave the TV set to STANDARD and then reply to me with the brand and model number of your cable/satellite receiver. I will then be able to assist you with finding the correct picture settings and give instructions on how to set these correctly.
I hope this helps - please post back here if you need further assistance.
Regards,
BElectric
Jan 15, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Tv size keep changing
Thanks for coming to Fixya with your issue.
Allow me to try and understand your issue fully does the TV change size when you switch to a HD channel?
What happens is if a channel reception is interfered with, or the signal is too low to produce a HD channel you size will go from HD to standard DEFinition.
Now if the signal is good ether from the cable box or from the antenna then we are talking a decoder issue. So I need to know as far as clarification goes.
1. When does this happen
2. Does it happen on all channels
Thanks for your questions please do update me with more information so I can get back to you with a positive in depth answer.
Thanks for using Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 18, 2010 | Samsung LN46C550 TV
On Sony 36 iinch Trinitron TV, when I go to HDTV channels the picture size changes to widescreen. How do I adjust back to full screen on HD? I tried the "no zoom" button but that doesn't work. Cannot...
Please note that all HDTV channels project wide screen pictures. You can still go to settings and then picture mode and change the format to 4:3/full mode.
Aug 28, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Horizontal Black Bars on HD channels?
You can change aspect ratio by remote. I hope it will be solve
Apr 02, 2017 | Dell W4201C 42 in. Plasma HDTV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Open Questions:
See all Samsung TXN3071WHF 30" TV Questions
Samsung TXN3071WHF 30" TV Logo
110 people viewed this question
Jerry Greenberg
Jerry Greenberg
